AHHHH HA! I found it! I am going to go ahead and detail my experience to help anyone in the future! I called a few dealershps and got a few different answers, so I had to look some more for myself. On the 97 (so I assume 95 +) the relay is mounted on the same plate that the air filter box is! You have to remove the air filter box to get to it but that isn't hard. Now to by pass it:
This is on a 1997
1) remove cover and bottom to expose the wires. (it is the small one toward the fenderwall)
2) which wires are what:
BK/Y = Constant 12v
T/O = 12v swithed(by relay) to fog lamps
DB/LG = 12v switch (when this comes on the relay switches on the lights)
LB/BK = Ground - goes to instrument panel switch, then to ground
3) cut the DB/LG wire
4) connect a new wire to it about 12" long
5) cnnect this wire to the brown wire coming off the parking lamp assembly (that's the + for the parking lamps)
6) test it!
7) close it all up and roll!
How this setup works:
the relay is a switch that is "turned on" when power is directed to it. It then takes and directs power to the fog lamps. the way the switch is integrated to this is fairly simple. The ground wire from the relay does not go directly to the ground, it goes to the switch. The switch then controlls whether or not the relay can have a ground. So when the switch is on (allowing ground) and the parking lamps are on (sending the + side) the relay flips the switch and "POOF" you have light!
I hope I explained it well. I used the factory wiring because it is already 18-20 gauge and the lights came with no relay and wiring of similar gauge and the same size fuse, so I figured what the heck... But, please be careful when doing this and use the appropriate relay and wire gauge.
Edit 7/16/02 - Lost photo. however photo was just the location of the relay box. If you stand at the font of the truck and look at the air filter box. Then, move down to the mount for the box and look at the right (toward drivers side) of that mount there is a little box with wires going into it. That is the relay box.
