| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Jasper Georgia
1991 XLT 4x4
Help with cold rough idle
I have a 91 Explorer and finally have the cooling system in order. New water pump, and radiator and thermostat. Flushed the system very well, and now its clean as a whistle and runs at the right temp.
However, 3 or 4 weeks after all this is done, it has started missing badly when its cold. After it reaches operating temp. it smooths out. I figure it may be a head gasket, but I really need some expert advice before I get into that. It did over heat one time, but according to the gauge, it didnt go critical. Probably a faulty gauge, right? Is there anything I need to check before I jump in with the head gasket? Sensors, relays? should I have it put on a diagnostic machine? As is the norm, money is tight, so anything that I can do at home without making it worse would be helpful. I did try plug wires, (no difference) and have the plugs to put in yet. Thanks for your time, |
#2 |
Silt, Colorado
'94 Explorer
Try the idle air control valve. This regulates how much air the motor gets at an idle. Also I'm not sure if you truck has it but the mass air flow sensor will really play heck with how the motor runs. I'm sure somewhere on here is procedure for cleaning and or replacing these.
__________________ 2002 Dodge 3/4 ton, cummins, 6spd. Little air little fuel lots of fun. 1994 Ford Explorer Can't seem to keep it going for a month. |
#3 |
Bemidji, MN
94 4x4 Sport 88k
The IAC is readily available on the upper manifold, look for pictures in other threads. When you experience the rough idle, tap on it a little bit, see if it gets better.
Check engine light on? If so, yeah, go to autozone or someplace and have them read out the codes, post them here. |
#4 |
Jasper Georgia
1991 XLT 4x4
Thanks for your help. I have cleaned the Mass Air Flow Sensor, (found directions here). I have also cleaned the IAC, (also learned here). When I tap on the IAC nothing changes.
Is the wire connector on the end supposed to move? It turns 1/8 inch or so, and feels loose. I dont know how this functions. Is it possible to have a vacuum leak from this end? I have checked all the vacuum lines including the one at the trans. by removing the panel in the floor between the seats. (yet again learned here). You people rock! |
#5 |
Silt, Colorado
'94 Explorer
If you think you have a vacuum leak take a can of carb cleaner and spray all the areas that you suspect to be leaking and spray them with the cleaner. if any makes it to the intake your motor will either speed up or if enough gets in may make the motor sputter. spray all around the intake and any vacuum hoses you can find maybe you will find something. Good luck.
P.S. I know you probably know but your motor needs to be running while doing this. Just trying to cover the bases. __________________ 2002 Dodge 3/4 ton, cummins, 6spd. Little air little fuel lots of fun. 1994 Ford Explorer Can't seem to keep it going for a month. |
#6 |
Jasper Georgia
1991 XLT 4x4
Thanks for the tip, and your time. I'll try it tomorrow, along with the Autozone suggestion and post the codes I get.
#7 |
Jasper Georgia
1991 XLT 4x4
Sorry, but havent gotten any codes yet. I was looking on line for parts just to see what I was up against depending on codes, and found an IAC new for 24.00 plus shipping. I figured it couldnt hurt to have it.
I have read in many posts here, that there could be an issue with intake gaskets? I dont know the repair history of my truck, but it has 188,000 miles on it. Is this something that I should do as preventive maintenance? Also, when I put my finger on the fuel line going to the rail, I can feel a thump every second or so. Is this normal? As soon as I get the codes, maybe some of this will become clearer. Thanks again for your time and suggestions. |
#8 |
Bemidji, MN
94 4x4 Sport 88k
Lower intake gasket... I guess it depends on how pro-active you want to get with the vehicle. I'll be doing mine in a month or so, just to know it is done and correct, and I won't have to address it in winter months. Be a good time for plugs and wires too. And rocker panels. And new bumpers.
#9 |
Jasper Georgia
1991 XLT 4x4
Proactive or self preservation. Not sure which at this point. Window motors, A/C, drivers power seat, door handles the to do list grows larger, but thanks to several people here, I have saved tons of money on labor and parts by doing the work myself.
#10 |
Jasper Georgia
1991 XLT 4x4
Finally got off my butt and checked the plugs. Low and behold one was broken. The porcelain under the electrode was broken and jammed up into it. The plug was fouled. The other 5 were burnt a light brown color. Now it runs like a top. Thanks for all your help.
| Tags |
| cold, head gasket, idle, rough |
| Thread Tools | |
