Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
How to bypass door ajar switch for liftgate glass
Reply
Thread Tools
Old 03-30-2011, 02:08 AM   #1
btld
Cedar Park, TX
2002 Eddie Bauer V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
The door ajar error shows up frequently. So I replaced all the door ajar switches for all doors and the liftgate glass. I thought I solved the problem. But it showed up again, especially if I drove on bumpy roads, and I usually heard some subtle loose liftglass moving sound. So I stopped the car. I open and close each door to see if it kills the door ajar message. As I suspected, the liftglass is the one causing the door ajar error. Since I already replaced that switch, it might be some mechanical mounting problem with the liftglass. Ford issused some service guides on this mechanical design problem. I don't want to repair the glass now, since, for me, it still feels safe.
So what I want to do, is to bypass the ajar switch in the liftglass. It's an over design by ford. If I splice the wire together, will the car think the door is closed? or the opposite.
Thanks for reading.
btld is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-30-2011, 06:00 AM   #2
eddiebauer18
New Jersey
2002 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
I have the exact same problem man
Posted via Mobile Device
eddiebauer18 is offline   Reply With Quote
Old 03-30-2011, 06:02 AM   #3
eddiebauer18
New Jersey
2002 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
to solve this problem is probably to get a diagnostic
Old 03-30-2011, 08:30 AM   #4
btld
Cedar Park, TX
2002 Eddie Bauer V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
My side mirror is also messed up by some jackass. When I get the mirror part, I will take time to repair all. I'll test which way to quiet this sensor in liftglass. It's so annoying.
Old 03-30-2011, 09:51 AM   #5
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Thanks for reading.
The switch either makes contact or breaks contact. Use a multimeter to check. Once you figure that out you are good to go. If the switch makes contact when the glass is closed, then splice the wires together. If the switch breaks contact when the door is closed, then leave the wires apart.
My door ajar switch for my liftgate glass doesn't work at all. It is on my list of things to take care of once the weather gets better. Where is this switch located? Any pointers on replacing it? Once I dive into this I can give you better info on bypassing it.
Check out my how to for installing signal mirrors. Good info there on replacing your mirrors.
Thanks - Rondo
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is offline   Reply With Quote
Old 03-30-2011, 09:52 AM   #6
eddiebauer18
New Jersey
2002 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
Mines is too, evrytime I hit even the slightest groove
Old 03-30-2011, 01:44 PM   #7
btld
Cedar Park, TX
2002 Eddie Bauer V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hi Rondo,
Thank you. The side mirror is easy, since I knew how to remove the assembly through door panel (3 screws hold it, just the same process like replace the door ajar sensor).
I will post the pics of how to dissemble the rear door panel. Just be careful. I break some plastic holding taps during the process. But I still managed to put them on securely. If you need to replace the sensor, (which I don't recommend, since no matter what, it still gives ajar error), you have to remove the rear door latch or some other stuff (I don't quite recall now) to access the switch. If you just need to quiet the sensor, just either splice wires (use quick splicer) or remove the connector and cover the connector by electric tapes. No need to remove the latches.
I wish there are no other isssues like transmission to mess with. Right now it drives and handles perfectly with strong V8. I've put mobil 1 and self flushed with volvoline vv360 transmission fluid (another long story, really PITA), new michelin tires, spark plugs (not easy for DIY, two of them cannot easily access, not like my previous Mazda 626 I4, finally sent to dealer for it). Another issue is the noise coming from rear differential. I cannot hear it. But the mechanic showed me the potential break down on the road. I can bear it now, since it will cost about $1200 to fix with a new one, until it breaks down.
Old 03-30-2011, 02:46 PM   #8
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Pics would be great. The problem I'm having is the dome lights don't come on when I open the liftgate. I would really like them to come on, so I suspect the liftgate door ajar switch.
Standing by for pics...................................
__________________
Old 03-30-2011, 04:40 PM   #9
btld
Cedar Park, TX
2002 Eddie Bauer V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Rondo,
There are two sensors in the rear liftgate. One is for the whole part, the other one is for liftglass. They are all behind the same panel. The one in the bottom (for the whole rear liftgate) is easy to replace.
Old 03-30-2011, 08:19 PM   #10
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Great, thank you!
__________________
Old 03-31-2011, 08:42 PM   #11
btld
Cedar Park, TX
2002 Eddie Bauer V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
This afternoon, I put the side mirror on passenger side with ease. I also silenced the sensor by splicing the wires together coming to the liftglass door ajar sensor. I found this without multimeter. When I disconnect the sensor (which means open circuit), door ajar shows up. So the other way by connecting them together means door is locked securely. I connect the wires by the quicksplicer, work fantastic.
The liftglass ajar sensor is only loosely attached by Ford's design. That explains why ajar error still there after replacing with a new sensor.
The photos below show how to remove the backpanel of rear liftgate.
1. Remove these two screws,
Uploaded with ImageShack.us
2. Remove these two screws
3. Then apply forces along the rims of the plastic panel. Be CAREFUL the plastic tabs around the upper, left and right edges are horizontal. So apply force in horizontal way for these. Otherwise you will break them like what I did the first time.
4. Loose the yellow clip that connect the latch with the rear exterior door handle. Then remove the latch mechanism secured by the three screws.
5. You can see switch for the whole door in this picture. It's easy to replace.
6. For liftglass switch, I also remove the 4 screws around the square metal brackets, in order to remove it. After that, I spliced the two wires together to silence the sensor.
7. Finally assemble them reversely.
Old 03-31-2011, 08:48 PM   #12
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Thanks for the pics. I really appreciate it!
__________________
Old 09-12-2011, 03:46 PM   #13
gw0001
Las Vegas
explorer 04 xls
Vehicle Specs
Quoted: 0 Post(s)
Bottom liftgate ajar switch
For anyone wondering how to remove the switch (as I did) you simply rotate it through 90 degrees and it pulls out. In my case I removed the liftgate catch by unscrewing the three star head bolts and pulled the catch away from the panel to give plenty of access - no need to disconnect the cable.
gw0001 is offline   Reply With Quote
Old 09-12-2011, 05:34 PM   #14
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
I was able to get my switch out by removing the bolts in the catch and twisting the switch out by hand. I had a sticky switch. I freed it up, lubed it and now my interior lights come on when I open the liftgate glass. Happy days.
__________________
Old 04-19-2014, 04:55 PM   #15
toddmc451
2004 Explorer
Vehicle Specs
Quoted: 0 Post(s)
Paperclips to the rescue! :-)
Thanks for the thread and the photos. This helped a lot. I especially appreciated the note about the horizontal direction of some of the cover retaining clips.
The thing I wanted to mention is that you do not have to make any permanent changes to the wiring if you want to bridge out these two switches (which is what I did). Since the circuit on the rear switches is closed when the doors are closed, all you need to do is disconnect the switch wires from the latch mechanism and shove a cut paperclip (U shaped) into the sockets of the cable connector. I did this for both switches. If you ever decide to replace the switches, just remove the paperclip before reconnecting the cable to the new switch.
toddmc451 is offline   Reply With Quote
Old 04-22-2014, 11:20 AM   #16
rocco123
Endicott, NY
rocco123's Avatar
1994 XLT & 2002 Limited
Vehicle Specs
Quoted: 23 Post(s)
This past weekend I just figured out that the switch can be removed from the assy. Been running with front passenger switch bypassed for months due to it being the cause of a dead battery. Cleaned and lubed the switch and it's all good now. I pulled back a tab on the door lock, then turned the switch to get it out.
rocco123 is offline   Reply With Quote
Old 06-02-2014, 04:28 AM   #17
Ivancito59
Luquillo PR (Active Duty Station in Belgium)
2010 XLT Sport
Vehicle Specs
Quoted: 0 Post(s)
US
This will be the same situation with a 2010? Im having the same issue.?
any help?
Ivancito59 is offline   Reply With Quote
Old 06-02-2014, 05:24 AM   #18
rocco123
Endicott, NY
rocco123's Avatar
Vehicle Specs
Quoted: 23 Post(s)
Probably is. U just need to tear into it and find the wiring to the switch.
Old 09-29-2015, 10:23 AM   #19
quitord
2008 Ford Explorer Limite
Vehicle Specs
Quoted: 0 Post(s)
Dk Exp Ford Explorer (2003) liftgate panel disassembly
Hello btld: I am having the same problem as others, liftgate open signal. Saw your post from several years ago and you had written down the steps to remove the liftgate panel along with the photo's. Unfortunetly, the photos have expired and I can not see them. Can you repost the photos.
This thing is driving me nuts and has killed by battery while I was on vacation. (Apparently alarm keep going off and dome light came on) Any help would be appreciated.
Jim
quitord is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
