EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Modified 2002 - 2005 Explorers
Notices
Modified 2002 - 2005 Explorers Questions related to modified 2002 - 2005 Explorers and Mountaineers. For Sport Trac and Sport models use the 1995-2001 forum. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
How to: 1.5" body lift for less than $50
Reply
Thread Tools
Old 08-31-2011, 10:40 AM   #141
Ronin8002
Virginia
2008 XLT Ironman
Vehicle Specs
(Original Poster)
Awesome man...be sure to post up some pics and any tips for the problems you had.
__________________
Mods: 265/70/17 Mickey Thompson Baja STZ on 17x8 Black Rock Viper 900B wheels, Bentley style grille, Raptor style LED grille lights, Pacer performance clearance lights, 30" 180W LED light bar behind grille, BTF upper control arms, Fox 2.0 5" travel emulsion coilover shocks in front/rear Truxx spacers, 1" body lift, front skidplate under radiator, recovery shackle mounts
My Rig:http://www.explorerforum.com/forums/...47#post3004247
Ronin8002 is offline   Reply With Quote
Old 08-31-2011, 09:35 PM   #142
Wills05xlt4x4
Ashland Va
Wills05xlt4x4's Avatar
2005 Xlt 4x4
Vehicle Specs
test drive completed
Quote:
Got it all done getting late but put it back to driveable status i will repost tomorrow sometime with the few tips I figured out and things I had to watch thanks again for all the help everyone especially ronnin
Still have all the trim to reinstall inside and want to go over all the bolts again after I drive some just for safety's sake
Wills05xlt4x4 is offline   Reply With Quote
Old 09-07-2011, 09:13 AM   #143
Wills05xlt4x4
Ashland Va
2005 Xlt 4x4
Vehicle Specs
ok install was very straight forward and as described in threads here are some pics
BTW- PB BLASTER THE BOLTS FOR DAYS PRIOR TO AND AN IMPACT PREFERABLY CORDLESS IS A MUST...
IMAG0107 by billyssingle, on Flickr
if your not running a lower fan shroud make sure you secure the radiator hose so it wont hit the belt...
IMAG0104 by billyssingle, on Flickr
heres where i jacked it up incase any one wonders i used both jacks myself at once
IMAG0102 by billyssingle, on Flickr
the threaded washer on front is much easier to get to if youve jacked up the side in question, then a wrench (1") fits the inside and bam its off...
IMAG0114 by billyssingle, on Flickr
i know its kindof ghetto but its a painted gloss black 2x4 stuck in the gap to givve step support........
and a before pic
Explorer first time stuck but this was crazy soft sand and I had just climbed a small deep hill by billyssingle, on Flickr
AND TADA AFTER!!!
IMAG0109 by billyssingle, on Flickr
Tires are shipping out today! cant beat the price with a stick
https://www.treadwright.com/p-71-265...dog-m-t-c.aspx
I also used a big zip tie to cinch up the last exhaust hanger thus making it sit up a bit more....
only issues were with center puck and had to jack rear up last on one side because i didnt trim rear bumper and it is pushing into it but looks fine.. also you need some grunt to bend front bumper lower mounts up that bolt it to frame but no biggie at all thanks again guys!
Old 09-08-2011, 05:54 AM   #144
bluebaboy
Sunshine coast queensland
2002 xlt
Vehicle Specs
AU ready to lift
hey all, about to attempt the lift to my girl's 02 x. Wondering if the 1.75 front lift and 1.5 rear is the same as both 1.5 , is it just a matter of cutting the blocks at 1.75. will this give it an even look or is the 1.5 lift front and rear enough. cheers blue
bluebaboy is offline   Reply With Quote
Old 09-08-2011, 07:45 AM   #145
Ronin8002
Virginia
2008 XLT Ironman
Vehicle Specs
(Original Poster)
Hey mate,
You could try doing the blocks at different heights but then the bolts that you re-use may not be long enough so you may end up having to buy a few more bolts.
I am not sure about how well a sloped body lift works but I know some people have done it on earlier explorers and it works OK for them. If you decide to go for it post up how it works for you in this thread.
The body lift does not level out the truck if you do them all the same height; the rake of the truck is due to the suspension. You can level it out with BTF strut spacers though, just get ones that are about 1/2" taller in the front than the rear.
__________________
Old 09-08-2011, 08:02 AM   #146
bluebaboy
2002 xlt
Vehicle Specs
AU
Hey mate,
thanks for that info, will just do the 1.5 lift as wasn't sure on what caused the rake.Will change the rake at a later date, but am odering parts and will let you know how i go with the lift. cheers in advance of me probably asking for some advice during lift.
Old 09-19-2011, 11:47 AM   #147
ExplorerKing01
flower mound tx
03 eddie bauer
Vehicle Specs
just ordered the blocks and bolts cant await to install it next week.
__________________
Kyle
2003 Explorer Eddie Bauer
1.5 body lift,5 inch 55 watt Pro Comp off road lights, air box mods, K&n air filter, PIAA 9006 Xtra Xtreme White Plus Bulb, Pro Comp tow hooks, baja bar, 6 inch 100 watt Pro Comp off road lights, custom skid plate, wilson 1000 magnet 62 inch whip, cb and pa system, more to come in the future
ExplorerKing01 is offline   Reply With Quote
Old 09-19-2011, 06:27 PM   #148
ExplorerKing01
flower mound tx
03 eddie bauer
Vehicle Specs
Hey guys I need some help taking the lower fan Shroud out I have unbolted it and everything that need to come off but just can't get the dang thing out of my ex any tip that would help thanks guys
__________________
Kyle
Old 09-19-2011, 09:23 PM   #149
Kazer
Saginaw, MI
Kazer's Avatar
2002 4.0 FX4
Vehicle Specs
im pretty sure the lower fan shroud is connected to a lower coolant hose aswell, not really sure though, my friend was tearing about the front end as i did the rest
EDIT: actually it might be held on by Christmas tree clips. make sure no hoses are connected to it then grab a hold of it and give it hell
__________________
-Steve-
Mustang GT's 17x8 +24 Offset, 245/65r17 Hankook Dynapro ATM RF10
BTF 2.25" front, 1.75" rear, 1.5" bodylift, Spartan Locker
The Mounds
2002-2005 Explorer Facebook Page
Kazer is offline   Reply With Quote
Old 09-19-2011, 09:51 PM   #150
ExplorerKing01
flower mound tx
03 eddie bauer
Vehicle Specs
I finally figured out how to take it out it was a pain in the butt.
__________________
Kyle
Old 09-19-2011, 09:53 PM   #151
Kazer
Saginaw, MI
Kazer's Avatar
2002 4.0 FX4
Vehicle Specs
ahh. did you figure out what was holding it in there? and sorry for the delayed response, i know how it can be waiting for an answer
__________________
-Steve-
The Mounds
Old 09-19-2011, 10:31 PM   #152
ExplorerKing01
flower mound tx
03 eddie bauer
Vehicle Specs
The hoses at the Bottom of the radieator. I took the top D
Fan shroud out. I was able to spin the bottom shroud to the top and take it out.
__________________
Kyle
Old 09-20-2011, 01:42 PM   #153
NJones04
Cape Cod, MA
'02 XLT 4.0L
Vehicle Specs
I found an explorer in my campus's parking lot and decided to park next to it and grab a few pics. I have the 1.5" BL and 265/75/16's on. The tires gave me about another 1.5" of lift, so 3" total.
Here's the pics...
http://www.flickr.com/photos/67733126@N07/6167086732/
http://www.flickr.com/photos/67733126@N07/6166548619/
__________________
2002 XLT 4.0L
Alpine Head Unit, Alpine 12" Type R, Alpine 500W amp
Brown wire mod, K&N Intake, 1.5" BL, black corner lights, 265/75/16 tires
Future Mods:
Grille Guard, Fog Lights
NJones04 is offline   Reply With Quote
Old 09-20-2011, 10:11 PM   #154
ross7070
long island new york
00 XLT
Vehicle Specs
2nd gen?
can this work on a late 2nd gen explorer?
ross7070 is offline   Reply With Quote
Old 09-20-2011, 10:39 PM   #155
Wills05xlt4x4
Ashland Va
2005 Xlt 4x4
Vehicle Specs
Quote:
Cutting the blocks yes but our bumper covers are mounted to body thus looking correct. The second gen bumpers just mount to frame so there would be a gap otherwise I'd imagine it'd all work the same plus there are no mechanical shifters to account for dropping into body when you lift it...
Old 09-26-2011, 09:20 PM   #156
ExplorerKing01
flower mound tx
03 eddie bauer
Vehicle Specs
hey guys i plan on installing the body lift on Wednesday. about how long did it take yall to install it and would i be okay with using only one floor jack or do i need 2. thank
__________________
Kyle
Old 09-26-2011, 09:26 PM   #157
Kazer
Saginaw, MI
Kazer's Avatar
2002 4.0 FX4
Vehicle Specs
took me and a friend 7 hours with no write up and yeah one jack and a 2x4 worked for us.
__________________
-Steve-
The Mounds
Old 09-26-2011, 09:34 PM   #158
renzAy34134
Fort Myers Florida
renzAy34134's Avatar
2007 Explorer Eddie Bauer
Vehicle Specs
did the three inch on my 07 and it took about 9 with multiple trips to the harware store. without all of it prob around 7 or so sounds right. One jack a couple of 2x4's and a buddy to help.
renzAy34134 is offline   Reply With Quote
Old 09-28-2011, 08:35 PM   #159
ExplorerKing01
flower mound tx
03 eddie bauer
Vehicle Specs
so i tried the body lift today and the explorer won and i just gave up. so im going to keep it at stock and get my buddys dad to do it for me later on.
__________________
Kyle
Old 09-28-2011, 09:03 PM   #160
Kazer
Saginaw, MI
Kazer's Avatar
2002 4.0 FX4
Vehicle Specs
whered you get stuck at? just keep posting up your snags and we (will, ronin, myself, etc) should be able to walk you through them
__________________
-Steve-
The Mounds
Reply
Tags
1.5" body lift kit, 1.5" bodylift-what you need, 2002-2005 body lift, 3rd gen body lift
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
