Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > New Members - Photo Gallery- Explorer Registries - Features - Reviews > New Member Introductions
Notices
New Member Introductions The place for new members to introduce themselves to our family of Ford Explorer enthusiasts Welcome aboard!!
2000 explorer sohc, obd shows lean in both banks
Reply
Thread Tools
Old 03-31-2011, 05:59 PM   #1
aaron7095
romulus Mi
2000 explorer xls sohc
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Angry 2000 explorer sohc, obd shows lean in both banks
I have a 2000 explorer 4.0 sohc its a recent purchase ..I found out that the motor was swapped for a sohc, it had an original ohv.I put a k&n airfilter on it and changed the oil twice... Since day 2 I have been getting what sounds to be lifter noise at a cold start ..buts disappearps after engine gets to operating temp.Nothing has fixed that this far.. now I also am getting p0171 and p0174 codes both banks lean.Could I have a dirty maf sensor..or clogged catalytic convertor? When I changed the plugs the porcelain was near melted and it always has a burning kind of heated exhausted smell? ?
The truck runs great no driving symptoms does seem to lack power.
I read that oiled air filters cause maf issues. And no I do not believe it is a vaccum. Or intake leak
aaron7095 is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-31-2011, 06:14 PM   #2
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Vehicle Specs
Quoted: 933 Post(s)
OBD Codes P0171 and P0174
This code is a very common code to the Explorer Sport and Sport Trac. It is normally the elbow that is located under the throttle body. It tends to crack on the bottom and needs to be removed to examine it. You can replace it with a small piece of heater hose that is 5/8 inch. But heater hose is a quick fix.
The hose will soften and collapse causing other problems. Purchase a PCV elbow or the replacement part from a dealer. (Motorcraft KCV190)
swshawaii is offline   Reply With Quote
Old 03-31-2011, 07:35 PM   #3
swetrid
Reading Pa
1999 Eddie Bauer
Vehicle Specs
Quoted: 4 Post(s)
Intake gaskets
__________________
Resident Ford Tech for the last 17 years, 1999 Eddie Bauer Explorer, 1987 Mustang GT, 2013 Focus ST
swetrid is offline   Reply With Quote
Old 03-31-2011, 08:51 PM   #4
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
reprogrammed PCM?
Was the OHV PCM replaced with a SOHC PCM or reprogrammed for the SOHC when the OHV engine was replaced?
Are the lean codes a recent occurrence or have they been there since the engine swap?
2000StreetRod is offline   Reply With Quote
Old 03-31-2011, 08:56 PM   #5
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 417 Post(s)
Welcome to this forum! I would also suspect the intake gaskets as previously suggested.
BrooklynBay is online now   Reply With Quote
Old 04-02-2011, 02:48 AM   #6
Sams01XplrSprt
Southern Cali Explorer
Newport Beach California & Bay Area California
Sams01XplrSprt's Avatar
2001 Sport (sold)
Vehicle Specs
Quoted: 4 Post(s)
welcome aaron
__________________
2001 Ford Explorer Sport 4.0 sohc engine. Mods include: dual 40 series flowmasters & high flow k&n air filter & removed silencer & yellow fog lights (sold for $1,800) as of 2-26-12
Sams01XplrSprt is offline   Reply With Quote
Old 04-02-2011, 04:43 AM   #7
ncranchero
Co-moderator
Denver,NC
ncranchero's Avatar
'94 F150 4x4 SWB 4.9L
Vehicle Specs
Quoted: 28 Post(s)
My money is on the elbow. Much easier/cheaper to check it out first anyway.
Ditch the K&N IMO FWIW.
__________________
'14 Transit Connect 2.5L 16 Valve DOHC Duratec
'02 Escape XLT 3.0L 24 Valve DOHC Duratec 160k
'94 F150 4x4 4.9L/5-speed 160K miles,
How to post photos
ncranchero is offline   Reply With Quote
Old 04-02-2011, 10:46 AM   #8
swetrid
Reading Pa
1999 Eddie Bauer
Vehicle Specs
Quoted: 4 Post(s)
I dont think they use the elbow you are suggesting on 2000. They use that on newer sohc sport trac, sport and ranger intake manifolds.
__________________
Old 04-02-2011, 03:19 PM   #9
ncranchero
Co-moderator
Denver,NC
ncranchero's Avatar
Vehicle Specs
Quoted: 28 Post(s)
He only said the OHV was replaced by a SOHC, not stating what year the SOHC was from. Thus my concurrence with swshawaii.
__________________
How to post photos
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
