Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
How to replace water pump
Reply
Thread Tools
Old 04-02-2011, 05:56 PM   #1
Jason94sport
South FL
93 Sport 2WD 5 speed
Vehicle Specs
Quoted: 50 Post(s)
(Original Poster)
I have my radiator, fan, fan clutch, TS & hoses all out for replacement.
Would replacing the water pump be a good idea? And how do you do it? The manual I have is useless. I read several different posts about it saying I need to remove the alt, & compressor brackets, & pullies I'm reading conflicting info.
I'm not sure if that's for the 4.0L OHV engine or not.
Thanks
__________________
1993 2WD Sport 5 speed
BBK TB, Flowmaster Force II Cat Back, CAI
Pioneer HU, Clarion speakers, RF R300 powered 10" sub
Jason94sport is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-02-2011, 06:01 PM   #2
mehedgec
'93 XLT
Vehicle Specs
Quoted: 0 Post(s)
Remove the bolts and pull it off.
mehedgec is offline   Reply With Quote
Old 04-02-2011, 06:15 PM   #3
Anime
EF YEAH!!
Anime's Avatar
2016 EX Sport Concept
Vehicle Specs
Quoted: 187 Post(s)
If you have all that off, the water pump is nothing more than loosening all of the 10mm bolts holding it on, cleaning off the old gasket/sealant, and putting on another one. I do suggest using some Permatex Water Pump & Thermostat Housing sealant, as the wimpy paper gaskets by themselves don't seem to seal very well, and I have yet to find a decent stand-alone gasket with rubber or something to make a watertight seal. Let the sealant get tacky, stick on the water pump, let it sit awhile, then tighten the bolts to spec. I usually let the sealant fully cure overnight before reinstalling everything and filling up the system with coolant.
If it's the original Motorcraft pump, you might be better off NOT replacing it and saving your money. I've gone through three GMB pumps from NAPA (lifetime warranty) after replacing the OEM one for cooling issues that later turned out to be belt/thermostat related. I've also had a heck of a time keeping the pump bolts tight...though this may have been a coolant issue (leaked with new Prestone Deathcool formula, doesn't seem to seep anymore with Zerex G-05).
Overall I say it's hard to beat a Ford pump/thermostat/fan clutch combo. You can go aftermarket in a pinch but I don't think there's anything better in terms of build quality and durability than the OEM Motorcraft water pump. Maybe that's why Ford wants $175+ for a new one.
On the other hand, if you're replacing everything else with aftermarket stuff, you could always get a new pump now ($50-60) and keep the other one as a backup.
__________________
"I think man has always gone where he has been able to go, and I think that when man stops going where he can go, he will have lost a lot. Man has always been an explorer. To me, there's a fascination in thrusting out and going to new places. It's like going through a door because you find the door in front of you." - Michael Collins
Anime is offline   Reply With Quote
Old 04-02-2011, 06:44 PM   #4
Jason94sport
South FL
Vehicle Specs
Quoted: 50 Post(s)
(Original Poster)
Ok I I shouldn't have to remove anything else to get the water pump out? I was getting conflicting info on that. I may not replace it. Didn't have any problems that I could see. No leaking or noises. Just replacing the cooling system stuff since FL weather can be rough. The coolant was a murky color & the TS was stuck open the fan clutch was bad & fan cracked & the hoses were all deteriorated inside & hard as a rock.
Old 04-02-2011, 07:04 PM   #5
Anime
EF YEAH!!
Anime's Avatar
Vehicle Specs
Quoted: 187 Post(s)
Is there anything in front of the pump blocking your access to the bolts or from pulling it directly forward? If not, there's no reason to remove anything else. The directions for removing alternator and compressor brackets are likely either for absolute perfect access...or just to trump up labor charges for the time to do such a repair.
You'll have to make the call on the pump. You can keep it on there and just flush the system with distilled water first before filling with coolant which will clean it some, remove the pump and check it out and replace with a new gasket & sealant, or just replace with a new pump while you're in there anyway.
I'd suggest using either Zerex Original Green or Zerex G-05 (both available at NAPA) for the coolant. Prestone and other similar "universal" coolants worked ok for cooling and kept the system quite clean, but seem to have been the cause of the leaks and seepage I had from gaskets and things, plus I think it ate away at some of the radiator/reservoir plastic.
__________________
Old 04-07-2011, 02:35 AM   #6
oldmodman
West Los Angeles, Ca
92 XLT 4X4
Vehicle Specs
Quoted: 0 Post(s)
Here is a link to the water pump sticky.
http://www.explorerforum.com/forums/...d.php?t=273723
Lots of good info & pictures.
oldmodman is offline   Reply With Quote
Old 04-07-2011, 07:43 AM   #7
Jason94sport
South FL
Vehicle Specs
Quoted: 50 Post(s)
(Original Poster)
Thanks, I saved the link.
I could not find that for the life of me. I knew it was around....
I wound up not replacing the water pump. I didn't want to open a can of worms. It still works fine. If it fails, it fails & I'll replace it at that time.
I bought the same fan clutch tool as in the DIY. I can take everything back off if I need to.
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
