Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
Air flow stuck on defrost setting.
Reply
Thread Tools
Old 04-06-2011, 11:27 PM   #1
GLS
Pasadena CA
2002 Explorer Sport Trac
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have a 2002 Ford Explorer Sport Trac. Regardless of where the control knob is positioned all air, be it heat, air from the outside or air conditioner is coming through as if it was set for defrost. I heard a clunk type noise as I was switching the knob from the floor to defrost position and think something broke inside the heating/air control system - perhaps a lever or door. Has this occured to anyone else and is there a solution for an avid do it myselfer?
GLS is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-07-2011, 04:53 AM   #2
ncranchero
Co-moderator
Denver,NC
ncranchero's Avatar
'94 F150 4x4 SWB 4.9L
Vehicle Specs
Quoted: 28 Post(s)
Clunk is not a good sign..........
I can round up some HVAC info for you if you'd like it. DEFROST is the default setting it goes to if vacuum is lost. Check your vacuum supply lines.
You have mail.
__________________
'14 Transit Connect 2.5L 16 Valve DOHC Duratec
'02 Escape XLT 3.0L 24 Valve DOHC Duratec 160k
'94 F150 4x4 4.9L/5-speed 160K miles,
How to post photos
ncranchero is offline   Reply With Quote
Old 05-01-2011, 04:02 PM   #3
rblackw474
saraland al
01 sport trac
Vehicle Specs
Quoted: 0 Post(s)
US
I have a 2001 with the same Prob. what can we do?
rblackw474 is offline   Reply With Quote
Old 05-01-2011, 04:42 PM   #4
ncranchero
Co-moderator
Denver,NC
ncranchero's Avatar
Vehicle Specs
Quoted: 28 Post(s)
Check your vacuum lines for a break or crack, first thing.
__________________
How to post photos
Old 09-07-2011, 01:26 PM   #5
karaynn
mnsasser@gmail.com
mnsasser@gmail.com
Vehicle Specs
Quoted: 0 Post(s)
vacuum leaks
Do you happen to have a vacuum diagram of the 1996 ford ranger? I have a vacuum line that is disconnected and I can not seem to find where it goes. Its the line coming from under the blower motor towards the air filter. Everything appears to be hooked up to something except this one. May have been white and discolored greenish.
Thanks,
Marty -- aka karaynn
karaynn is offline   Reply With Quote
Old 10-27-2012, 05:25 PM   #6
Creekdweller
Missouri
2002 Ford Ranger 4X4 XLT
Vehicle Specs
Quoted: 0 Post(s)
No matter where I turn the knob for air flow control, the air comes out of the defrost. How do I find info on the vacuum lines to see if there is a leak?
Creekdweller is offline   Reply With Quote
Old 11-04-2012, 07:45 AM   #7
mustang6878
Iowa
'03 Sport Trac 4X4
Vehicle Specs
Quoted: 17 Post(s)
This older post fixed my problem, hope it helps you...
http://www.explorerforum.com/forums/...d.php?t=192842
mustang6878 is offline   Reply With Quote
Reply
Tags
air flow, defroster, heater air flow
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
