Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
TPMS-resetting after tire replacement
Reply
Thread Tools
Old 04-10-2011, 09:04 AM   #1
popojoe24
NJ
'05 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i had all 4 tired replaced at Midas, and they were unable to reset the tire pressure monitoring sensors. now i get an error message "Tire Pressure Default", and there is a constant TPMS warning indicator on my dash. i read that i may have to purchase a special magnet in order to reset them myself. any suggestions? thanks
popojoe24 is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-10-2011, 03:41 PM   #2
Gay-briel
Auburn, Maine
04 Sport Trac XLT Premium
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Sensor Training
NOTE: The tire pressure sensor training procedure must be done in an area without radio frequency (RF) noise.
RF noise is generated by electrical motor and appliance operation, cellular telephones, and remote transmitters.
1. Turn the ignition switch to the OFF position.
2. Turn the ignition switch to the RUN position three times, ending in the RUN position. Do not wait more than two minutes between each key cycle.
3. Press and release the brake pedal.
4. Turn the ignition switch to the OFF position.
5. Turn the ignition switch to the RUN position three times, ending in the RUN position. Do not wait more than two minutes between each key cycle.
6. The horn will sound once and the TPMS indicator will flash if train mode has been entered successfully. If equipped, the message center displays "TRAIN LEFT FRONT TIRE". Place the magnet on the valve stem of the LF tire pressure sensor. The horn will sound briefly to indicate that the tire pressure sensor has been recognized by the TPMS module.
7. Within two minutes after the horn sounds, place the magnet on the valve stem of the RF tire pressure sensor.
NOTE: If the TPMS module does not recognize any one of the four tire pressure sensors during the tire training procedure, the horn will sound twice and the message center (if equipped) will display "TIRE TRAINING MODE INCOMPLETE". If this occurs, the entire procedure must be repeated from Step 1.
8. Repeat Step 7 for the RR and LR tires.
When the tire training procedure is complete, the horn will sound once and the message center (if equipped) will display "TIRE TRAINING MODE COMPLETE".
it uses a magnet like this
should be easy to do, im surprised Midas couldn't do it
__________________
2004 Explorer Sport Trac XLT premium 4.0L auto 4wd
1995 Ranger XLT ext cab 3.0L auto 2wd
2005 Jeep Liberty Limited 3.7L auto 4wd
2001 Ranger XLT reg cab 2.3L auto 2wd--SOLD
1999 Ranger XLT reg cab 2.5L manual 2wd--SOLD
Gay-briel is offline   Reply With Quote
Old 04-10-2011, 03:56 PM   #3
Glen4X4
Lewistown, Pa
2000 XLS
Vehicle Specs
Quoted: 3 Post(s)
Take it to Pepboys if you have one close they have the tool to do it and only takes 5mins
__________________
96 Explorer XLT Gone
03 Silverado 1500 LS 4X4
00 Subaru Outback Limited SDN
Glen4X4 is offline   Reply With Quote
Old 04-10-2011, 08:31 PM   #4
popojoe24
NJ
'05 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
thanks guys.
Old 04-15-2011, 07:55 PM   #5
stuartr
Richlands, VA
2002 Mercury Mountaineer
Vehicle Specs
Quoted: 1 Post(s)
Where can you get the magnet?
STU
__________________
Mountianeer family I have a 2002 and she has a 2008. Both AWD V6.
stuartr is offline   Reply With Quote
Old 04-16-2011, 09:03 AM   #6
2002GreyHD150
DFW, Texas
2004 Mountaineer 4.6L AWD
Vehicle Specs
Quoted: 1 Post(s)
I see posts like this & wonder:
* what in the WORLD the tire tech is doing to the TPMS Sensors while mounting the tire?
* Are they mounting static weights too close to the Sensor?
* What can cause the NEED for this?
I ask these questions, because I had the 4th set of brand new tires installed @ Walmart of all places just a month or so ago. I know for a fact they went through nothing at all to "reset" the TPMS. The 2nd & third set of tires I took the tires & wheels to a tire shop I called on for my business. The Monty was 60 miles away.
I've never had to do this, but I see posts about it every 6-8 months.
Just curious if one of our resident Techs can explain why.
Rob
2002GreyHD150 is offline   Reply With Quote
Old 04-16-2011, 09:22 AM   #7
jrford
Birmingham, MI
'10 Sport Trac
Vehicle Specs
Quoted: 2 Post(s)
not a tech resident, but are the shops putting in new ones? they might make a couple of bucks on the deal.
I know when i mounted 5 new tires, i had the shop mount one of their new ones, couldn't program it for the life of me. Bought a used one of fleabay which worked great.
__________________
Jim
2010 Mercury Mountaineer Premier, V8 AWD, 35k
2010 Sport Trac Limited, V8 4WD, 80k
2004 EB Quad Buckets V8 AWD, 105k
jrford is offline   Reply With Quote
Old 04-16-2011, 09:28 AM   #8
Ronin8002
Virginia
2008 XLT Ironman
Vehicle Specs
Quoted: 127 Post(s)
Quote:
STU
Amazon or Ebay.
http://www.amazon.com/OTC-OTC38334-P...2963988&sr=8-1
http://cgi.ebay.com/OTC-Magnet-Tpms-...item2310003037
I am told that any big magnet will work though. You could use one from the back of an old blown speaker.
Ronin8002 is offline   Reply With Quote
Old 04-16-2011, 09:44 AM   #9
waskly
Crooklyn NY!
Vehicle Specs
Quoted: 4 Post(s)
Rob
if after mounting tires you get a tpms light 99.99% who ever dismounted the old tires, also dismounted the sensor or broke it.
it is correct the tpms sensors are programed to the vehicle. there is no reason to reprogram them less they are replaced.
__________________
Quote:
Originally Posted by imp View Post
How do you get someone's "quote" to become your "signature"? imp
waskly is offline   Reply With Quote
Old 04-16-2011, 10:12 AM   #10
2002GreyHD150
DFW, Texas
Vehicle Specs
Quoted: 1 Post(s)
^^^ as I said... what in the world is the installer doing to see everyone having to reprogram all the time... LOL
Installer breaking them makes perfect sense. I know on the old Ford Band-style sensors, when we refinished wheels they had to be removed to bake the powdercoating on the refinished wheels. We had to replace sensors all the time cuz the bands would desimate the sensors.
My wife's Monty has the valve stem style sensors. Unless the tech is just careless, they should never hit the sensor with a tire iron/bar.
Rob
Old 04-16-2011, 10:56 AM   #11
stuartr
Richlands, VA
Vehicle Specs
Quoted: 1 Post(s)
How about if you change tire size. My wifes mounty has TPMS and I am going to a bigger tire when I buy before winter. I have been wondering about the sensors. I would figure 25psi is 25psi no matter what size tire it is. But not sure, I think it is 25 they cut on at. Hers have came on a couple times. One tire has a very slow leak. Oh ya, which kind do the 08 mountys have the bands or valve type? If the valve type I guess you can't change valve stems when you change tires can you? How do these things work anyway the vehicle must pick up a RF sig. from them I guess.
STU
__________________
Old 04-16-2011, 11:04 AM   #12
Ronin8002
Virginia
2008 XLT Ironman
Vehicle Specs
Quoted: 127 Post(s)
tire size doesnt matter to the sensors. As far as how they work they send out an rf signal to the vehicle's computer.
Old 04-17-2011, 05:40 PM   #13
stuartr
Richlands, VA
Vehicle Specs
Quoted: 1 Post(s)
That is what I thought, thanks for the answer.
STU
__________________
Old 09-25-2013, 05:10 PM   #14
LIrican
Annapolis, MD
2014 Ford Explorer Sport
Vehicle Specs
Quoted: 59 Post(s)
Hey everyone....
I purchased rims and tires from CarID with new TPMS sensors.
I'm having a hard time getting them paired or programmed to the truck. I've been to 2 Ford dealerships and tried a local tire shop who at least attempted to get them to sync.
They said they could read them on their tool but couldn't get the truck to read them.
has anyone had any success getting aftermarket TPMS sensors paired?
Brand: ORO-TEK
LIrican is offline   Reply With Quote
Old 09-25-2013, 07:06 PM   #15
Ronin8002
Virginia
2008 XLT Ironman
Vehicle Specs
Quoted: 127 Post(s)
Assuming you are talking about your 2012 Limited in your profile...you might get a more helpful response if you post in the 2011 and newer forums.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
