Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
2001 Sport, Torque Converter stuck to flywheel
Reply
Thread Tools
Old 04-10-2011, 07:08 PM   #1
lbrowne
AB, Canada
01 blazer lt
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
I bought a donor truck for its transmission and other parts. The motor is seized.
We dropped the trans today and the torque converter appears to not want to seperate from the flywheel... I already cracked off the tip of one screwdriver lol...
I thought those would come out with the trans...
__________________
2001 blazer LT (beater - now that I've tried one, the Explorer is far superior)
lbrowne is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-10-2011, 07:23 PM   #2
drdoom
VA
2005 Eddie Bauer 4.6L 4X4
Vehicle Specs
Quoted: 343 Post(s)
I assume you removed the bolts?
drdoom is offline   Reply With Quote
Old 04-10-2011, 08:38 PM   #3
snoranger
Jackson, NJ
snoranger's Avatar
94 limited on 35's
Vehicle Specs
Quoted: 68 Post(s)
Quote:
Originally Posted by drdoom View Post
I assume you removed the 4 nuts?
Fixed that for you.
__________________
94 limited: 4.0l, 5spd swap, 6" skyjacker lift, 35x14.5 thornturds, 4.56s. 5.0 swap started (94 cobra 5.0, zf 5spd, np205)
95 xlt: stockish (SOHC swap, 30,000miles and I blew up the 3rd 4r55e...now collecting parts for a Cummins swap.)
Cummins 4BT swap thread
Ranger bed trailer build
snoranger is offline   Reply With Quote
Old 04-10-2011, 08:49 PM   #4
lbrowne
AB, Canada
01 blazer lt
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Is it that obvious this is the first auto trans I ever removed? lol
How do I get at these bolts? Remember, anything engine-wise can'y move. She's locked solid.
__________________
Old 04-10-2011, 08:57 PM   #5
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
pull trans without torque converter
Since you can't rotate the crankshaft because the engine is seized then you won't have access thru the starter motor opening to the 4 nuts that attach the flexplate to the torque converter. You will have to separate the transmission from the engine leaving the torque converter attached to the flexplate. Once the transmission is removed you can access the torque converter nuts.
2000StreetRod is offline   Reply With Quote
Old 04-10-2011, 10:19 PM   #6
lbrowne
AB, Canada
01 blazer lt
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Quote:
The transmission is removed already. Where do I get at these nuts?
__________________
Old 04-10-2011, 10:40 PM   #7
wood1
North of Edmonton
'93 XLT, Cayman Green RIP
Vehicle Specs
Quoted: 0 Post(s)
You may have to drop the crank to get that converter off of the flywheel if you cannot turn the engine. The converter has studs that protrude from it and go through holes in the flywheel. The nuts are on the engine side of the flywheel.
The Ranger Station has this nifty exploded pic... you can see the 4 studs on the converter
http://www.google.ca/imgres?imgurl=h...%3Divns&itbs=1
__________________
Ribs. I had ribs for lunch, that's why I'm doing this.
List of useful TTB Threads
wood1 is offline   Reply With Quote
Old 04-10-2011, 11:48 PM   #8
snoranger
Jackson, NJ
snoranger's Avatar
94 limited on 35's
Vehicle Specs
Quoted: 68 Post(s)
Quote:
Sometimes (depends on the engine, flywheel, and vehicle) there is enough room to sneak in between the flywheel and the block, with an open end wrench. Loosen each nut a few turns, pull the converter out a little, then repeat until the converter is free. I know the 5.0 T-bird I pulled the trans out of, there was just enough room.
__________________
Old 04-11-2011, 01:30 PM   #9
lbrowne
AB, Canada
01 blazer lt
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
I probably just reuse the one that's in my 2000 since it appears to be working fine.
__________________
Old 04-11-2011, 01:37 PM   #10
wood1
North of Edmonton
Vehicle Specs
Quoted: 0 Post(s)
As long as there isn't any nasty crap in it from your old transmission blowing up you should be fine.
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
