Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
explorer manual transmission trouble
Reply
Thread Tools
Old 04-12-2011, 02:14 PM   #1
greenexpolorer
pinckney, MI
94 ford explorer sport
Vehicle Specs
(Original Poster)
Exclamation explorer manual transmission trouble
hi i have 94 ford explorer sport 4x4 with a 5 speed and having a trans problem when i shift into 3rd it always grinds but all the other gears shift fine the miles on it are 233000 miles. i think it is the Synchronizers for the gear sorry i cant spell very good
greenexpolorer is offline   Reply With Quote
Old 04-12-2011, 07:44 PM   #2
Anime
GREEN SCREAM!!
Hattiesburg, MS
Anime's Avatar
'93 Sport 4x4
Vehicle Specs
It's likely the 2nd-3rd syncros as you say, but it's pretty rare for those to be the ones to go, usually it's the 1st-2nd that goes, or sometimes reverse as well. Could be forks, too.
If it's slightly tricky to shift into other gears as well, or downshifting to lower gears is an issue, it might just be the clutch master or slave cylinder going. In any case if you're going to drop the transmission for a rebuild or syncro replacement, it'd be worth your while to replace the slave cylinder while you're in there, and inspect the clutch and pressure plate for possible replacement as well. Anything transmission related is best done while it's already out, rather than trying to save a buck by getting whatever life is left out of it.
__________________
"I think man has always gone where he has been able to go, and I think that when man stops going where he can go, he will have lost a lot. Man has always been an explorer. To me, there's a fascination in thrusting out and going to new places. It's like going through a door because you find the door in front of you." - Michael Collins
Anime is offline   Reply With Quote
Old 04-12-2011, 08:17 PM   #3
greenexpolorer
pinckney, MI
Vehicle Specs
(Original Poster)
more information
reply to Anime: when i bought the truck the guy just put a new clutch in it cause he blew up the old one and the clutch i don't think was bleed correctly when you idle and engage the clutch it don't happen until half way up from the floor or it could be the master or slave cylinder for the clutch is going. it just 3rd that i grind upshifting and downshifting.
Old 04-13-2011, 05:18 AM   #4
unclemeat
Richmond, VA
unclemeat's Avatar
91 sport
Vehicle Specs
When mine broke, it was third gear. The sycronicers on both sides and the third gear had to be replaced. The gear cracked on the inside near the shaft.
unclemeat is offline   Reply With Quote
Old 04-13-2011, 07:31 PM   #5
Anime
GREEN SCREAM!!
Hattiesburg, MS
Anime's Avatar
'93 Sport 4x4
Vehicle Specs
Just because it has a new clutch doesn't mean it has a new slave cylinder. It could still be the old slave going out, a rush clutch job, or still just an internal tranny issue with the syncros/forks.
You'll have to decide if you want to try just replacing the master first, or dropping the tranny for a new slave and to check the clutch, or just spring for a rebuild or have whatever needs replacing taken care of.
Doing a real good job bleeding the clutch first would definitely be on the list of stuff to try before the other stuff though.
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
