Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
How did you move the flywheel to tighten all torque converter bolts?
Reply
Thread Tools
Old 04-14-2011, 03:01 PM   #1
lbrowne
AB, Canada
01 blazer lt
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
That crank pulley is a pain to get a socket on and a breaker bar to turn the motor manually.
__________________
2001 blazer LT (beater - now that I've tried one, the Explorer is far superior)
lbrowne is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-14-2011, 03:49 PM   #2
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
Are you snaking the breaker bar from the top or the bottom? Cauz its usually easier if you go from under the vehicle.
__________________
...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 04-14-2011, 03:51 PM   #3
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
balancer retaining bolt
Using the balancer retaining bolt to rotate the flexplate is the best method. If you're at the correct angle laying under the left front of the vehicle and have a light shining on the starter motor opening in the bellhousing you can see the nuts on the flexplate while turning the balancer nut. At least I could on my 2WD Sport.
2000StreetRod is offline   Reply With Quote
Old 04-14-2011, 06:56 PM   #4
lbrowne
AB, Canada
01 blazer lt
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
What size is that bolt on the crank pulley?
I think if I used a deep socket I can get the breaker bar on it.
__________________
Old 04-14-2011, 07:17 PM   #5
KC90
Kootenay's
'99 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
The crank bolt should be a 19mm if I remember correctly. Once you get the flexplate-torque convertor nut centered in the starter hole you can just rotate the crank every 90 degrees
KC90 is offline   Reply With Quote
Old 04-14-2011, 10:24 PM   #6
lbrowne
AB, Canada
01 blazer lt
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Shes all good boys thnx for your help. Almost done here now.
Finish er up tomorrow.
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
