Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Advtrac /ABS issue
Reply
Thread Tools
Old 04-14-2011, 04:33 PM   #1
natlmatch
North houston
2005 XLT Explorer
Vehicle Specs
(Original Poster)
Advtrac /ABS issue
Hello all,
Had the weirdest problem I've ever encountered with my Explorer today. I was driving my 145,000 mile, well maintained, 2005 4.0L 2wd Explorer on a level, dry road today doing about 40mph. I had just begun braking normally for a red light ahead, everything was routine. About 100 feet from the light, I was slowing down thru about 20 to 25mph when all of a sudden the ABS started kicking back thru the brake pedal (it felt like it was the front driver’s side wheel that was locking up). I continued to brake the truck until it came to a complete stop; got out to see if there was anything on the road behind me like oil or debris that would have caused this...found nothing. I got over into the right lane, drove slow and then heard a low squealing-chirpy sound which seemed to come from under the hood but near the drivers side wheel area, this lasted for about 15secs and stopped as suddenly as it started. I pulled over again, looked under the hood and wheel area...saw nothing. I started moving again and about a minute later the "Check ADVtrac" message came on the truck's L.E.D. screen so I turned it off and continued driving nice and easy for another 5 miles w/no further issues.
Now, I'm not much of a mechanic so I think I'm headed off to Ford for some diagnostics but wanted to see if anyone has experienced anything like this before, please?
I appreciate all replies,
Regards,
NM
natlmatch is offline   Reply With Quote
Old 04-23-2011, 10:47 AM   #2
cyress
Sudbury, Ontario
04 Explorer LTD V8 4x4
Vehicle Specs
Yes I have had this problem too, but everything is closed today. The exactl same problem you have, I had as well. It felt like something was under my vehicle or trying to stop me. I am going to see a Ford dealership on Monday, I will let you know exactly what happened then. Hopefully its just a sensor or a dirty sensor, so it is not much to change
cyress is offline   Reply With Quote
Old 04-27-2011, 06:34 PM   #3
natlmatch
North houston
2005 XLT Explorer
Vehicle Specs
(Original Poster)
Dk Exp
Cyress,
Check this page out..read down near the bottom, a few "pros" chime in:
http://www.justanswer.com/ford/353ej...time-turn.html
Regards,
NM
Old 04-27-2011, 08:22 PM   #4
04 EDGE
Westland Michigan
Vehicle Specs
Sounds like either a wheel bearing or one of the wheel speed sensors is bad. The only way to check it is to do a live data scan while driving. One of the sensors will drop out to zero while the others will still read when coming to a stop. This will cause a false ABS event and activate the ABS module. Sometimes rust builds up under or around the sensor causing this.
04 EDGE is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
