Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
good idle rough accel or rev
Reply
Thread Tools
Old 04-17-2011, 11:10 AM   #1
red94ltng
Cheyenne,Wy
1994 xlt
Vehicle Specs
(Original Poster)
Okay first of hello everyone my first post on this site figured i might see if anyone has a quick answer to my problem before i dig into it and replace a bunch of stuff i dont need to bought a 1994 explorer last year it starts and idles fine sitting in neutral or park acc past 2k makes it want to choke out and same with it in gear got it home at 35mph or so and left it for a project when it would get a little warmer i have pulled the codes a while back mostly 02 sensor codes
well decided today it was starting to get warm and time to mess with it there are a few vac lines missing on drivers side next to throttle body and exhaust is of course so rusty i cannot take it apart to check cats mass air looks clean and no restriction i can see in intake area up to intake of course have not replace plugs or fuel filter yet is there a port to check the fuel pressure on these if so where or do i bother just looking for a place to start any info would be helpful maybe even a vac line diagram for the drivers side next to tb thanks ahead of time
Aaron
red94ltng is offline   Reply With Quote
Old 04-17-2011, 12:58 PM   #2
Roadrunner777
Bemidji, MN
Roadrunner777's Avatar
94 4x4 Sport 88k
Vehicle Specs
I suppose I would plug any open vacuum lines, see if it makes a difference. If not, I might check fuel pressure and volume.
Roadrunner777 is offline   Reply With Quote
Old 04-17-2011, 01:11 PM   #3
red94ltng
Cheyenne,Wy
1994 xlt
Vehicle Specs
(Original Poster)
put lines on both spots it looks like lines should be in no changes where is port to check fuel pressure and what is it supposed to be
Old 04-17-2011, 01:15 PM   #4
Roadrunner777
Bemidji, MN
94 4x4 Sport 88k
Vehicle Specs
It's on the passenger side of the intake, pointing out towards the airbox. 30PSI is a good number. There is a great thread on this, I'll post it if I find it.
Old 04-17-2011, 01:23 PM   #5
Roadrunner777
Bemidji, MN
94 4x4 Sport 88k
Vehicle Specs
And here it is, 1st Generation Fuel System 101 (or something like that):
http://www.explorerforum.com/forums/...+fuel+pressure
Old 04-17-2011, 01:32 PM   #6
red94ltng
Cheyenne,Wy
1994 xlt
Vehicle Specs
(Original Poster)
okay ill read it just checked my fuel pressure was hitting 35psi
Old 04-17-2011, 01:38 PM   #7
Roadrunner777
Bemidji, MN
94 4x4 Sport 88k
Vehicle Specs
Look for a test on the throttle position sensor. It sounds like this engine is going lean on you.
Old 04-17-2011, 02:04 PM   #8
red94ltng
Cheyenne,Wy
1994 xlt
Vehicle Specs
(Original Poster)
thaks for the info read up on the tps ill have to get a voltmeter and test it out guess ill keep driving the Lightning to work until then
Old 04-17-2011, 02:37 PM   #9
Roadrunner777
Bemidji, MN
94 4x4 Sport 88k
Vehicle Specs
Be sure to get a volume test on the fuel if you didn't do that. You can have an essentially clogged filter or a pinched line, and still get pressure, until you start drawing off of it. I think that was in the thread. Anyway, yup, good luck!
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
