Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
HELP! 93 ford explorer wont start!
Reply
Thread Tools
Old 04-22-2011, 06:41 PM   #1
sonnyandveronica
Lubbock, Tx
93 explorer i think LL
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
My 93 ford explorer wont start. The engine turns but it wont start. I was told there is no spark. I replaced the module and the crank shaft sensor and it still wont start. I was told it could also be the computer but could it be anything else?
sonnyandveronica is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-22-2011, 06:53 PM   #2
andre 244
gatineau
92 93 97 99 2000more ford
Vehicle Specs
Quoted: 0 Post(s)
is check engine ligth if it go on when u turn key ? may have bad fuse or ecm relay
do you hear the fuel pump working
andre 244 is offline   Reply With Quote
Old 04-22-2011, 07:02 PM   #3
sonnyandveronica
Lubbock, Tx
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
no check engine light i was told the pump is working
Old 04-22-2011, 07:07 PM   #4
andre 244
gatineau
Vehicle Specs
Quoted: 0 Post(s)
whe to key is on you must have check engine ligth on the after about 3 second go off
if not youre ecm not geting any power
Old 04-22-2011, 07:08 PM   #5
sonnyandveronica
Lubbock, Tx
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
what is the ecm
Old 04-22-2011, 07:11 PM   #6
andre 244
gatineau
Vehicle Specs
Quoted: 0 Post(s)
engine contol module "computer" also call ecu engine control unit
Old 04-22-2011, 07:13 PM   #7
sonnyandveronica
Lubbock, Tx
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
The light does not come on so does that mean i need to replace the computer or what would cause it to not get power
Old 04-22-2011, 07:23 PM   #8
andre 244
gatineau
Vehicle Specs
Quoted: 0 Post(s)
here what you do turn key till dash lith are on check if check engine is on
if yes good sing
if not check fuse or you're bulb may be burnt out
if you can check if you have injector pulse by diconecting plug and put a 194 bulb it should flash when you try to start
Old 04-22-2011, 07:32 PM   #9
sonnyandveronica
Lubbock, Tx
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
The fuse to the check engine light or to the computer. And where is the plug to check the injector pulse. (what is that for)
Old 04-22-2011, 07:42 PM   #10
Slatch
2001 Sport Trac
Vehicle Specs
Quoted: 0 Post(s)
First thing I would check in your situation is the PCM relay. Look at your owners manual, it is located in the power distribution box under the hood. Swap it with another relay of the same style and see if there is any change.
Slatch is offline   Reply With Quote
Old 04-22-2011, 07:52 PM   #11
sonnyandveronica
Lubbock, Tx
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
in my owners manual under the power distribution box i cant find the PCM relay which one is it
Old 04-22-2011, 10:14 PM   #12
MrShorty
Spanish Fork, UT
92 XLT and '87 Bronco II
Vehicle Specs
Quoted: 10 Post(s)
Sometimes it is labeled EEC relay.
A wiring diagram (even the ones in Chiltons) will help you see how the PCM gets power. The EEC relay might be working because the fuel pump relay should require power from the EEC relay to run the fuel pump.
__________________
Mr. Shorty
92 XLT 4x4
87 Bronco II XLT 4x4
'98 Chev K1500 Suburban SLT 4x4
MrShorty is offline   Reply With Quote
Old 04-22-2011, 11:11 PM   #13
sonnyandveronica
Lubbock, Tx
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
So if it is not the eec relay what else might i want to check before going and buying a new computer.
Old 04-23-2011, 08:37 AM   #14
MrShorty
Spanish Fork, UT
Vehicle Specs
Quoted: 10 Post(s)
The rest of the PCM power and ground circuits.
__________________
Mr. Shorty
92 XLT 4x4
Old 04-23-2011, 09:52 AM   #15
sonnyandveronica
Lubbock, Tx
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Is there anything specific I should check or where and how should I check. And Thanks!!!
Old 04-23-2011, 01:20 PM   #16
MrShorty
Spanish Fork, UT
Vehicle Specs
Quoted: 10 Post(s)
Power circuit: I'd probably start at the PCM and make sure the three power wires have 12 V with the key on. If yes, then the PCM power circuit is good. If not, then move back to the relay and make sure it is closing. With your wiring diagram, continue up the power circuit until you find 12 V. The problem will be between the point in the circuit where you have 12 V and the point where you don't have 12 V.
Ground circuit. Assuming you have power to the PCM, grounds are usually best checked with a DVOM. Measure the voltage drop across the three grounds (positive lead at the PCM, negative lead at B-. There should be very little voltage drop (several mV at most). An ohmmeter could also be used with the PCM connector disconnected. There should be essentially 0 ohms resistance between the connector and B-.
__________________
Mr. Shorty
92 XLT 4x4
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
