Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Transfer Case Output Shaft Oil Seal Leak - Remove and replace
Reply
Thread Tools
Old 04-23-2011, 07:32 PM   #1
esclamada
KCMO
'02 Mountaineer AWD V8
Vehicle Specs
Quoted: 28 Post(s)
(Original Poster)
Last fall I noticed that my transfer case is leaking oil, it's not that bad since it doesn't drip. I noticed that the area above the flange and U-Joint has lots of splatter and decided that this is a good spring project. I just did a flush and fill on my TC and rear diffs.
There was a time that I suspected that it might not be just the seal alone, maybe the rtv sealant was also leaking. So I run some test to verify what's leaking. I put duct tape on the seal halves and let it run for a week. The duct tape was clean, no leaks. So it's just the oil seal.
I also have the car inspected at a ford dealership telling them that the TC is leaking, they want to re-seal the whole thing for $750, if they found out other issues it will go up even more.
So I decided to just do the re-sealing my self (not the whole thing) At first I gave up because the driveshaft bolts will not let loose. So wrapped everything up and do more research and do it the next weekend.
Got a new seal and it's not leaking anymore. Hopefully I did it right and won't leak again..
Here's my pictures.
http://www.facebook.com/media/set/fb...10528882348605
esclamada is offline   Reply With Quote
( Join the Elite Explorers )
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
