Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
93 Explorer Radio swap.... what happened?
Reply
Thread Tools
Old 04-23-2011, 11:08 PM   #1
Aussie Canuck
B.C.
93 Explorer XLT
Vehicle Specs
(Original Poster)
Attempting to swap out the factory radio with my new CD player in my 93 exploder.
After cutting the wires from the back of the truck harness only to realize i could unclip it from the factory radio, I re-connected the wires to the harness. I bought a wiring harness from walmart hooked up my CD player to the harness, clipped it into the truck harness aaaaanndd.... #### all. NO POWER, doenst light up, just sits there and pisses me off.
So i figure id hook up the old radio for now as something is better than nothing. Old radio gets clipped in, lights up but has NO POWER! No clock no sounds, shit all. Everything is in the factory harness as it should be, been checked and re-checked. Checked all the fuses..... WTF did i do!
Aussie Canuck is offline   Reply With Quote
Old 04-23-2011, 11:16 PM   #2
StryctNy9e
Beaverton OR/ hayward CA
1993 XLT Exploder
Vehicle Specs
Did you pull the fuses before you gut the wires? may have blow a fuse.
__________________
Stryctny9e's 1993 Ford Exploder XLT
on the menu.... Snorkel...Gauges.... Rhino line roof....Manual Hubs 32x11.50 M/T
http://www.explorerforum.com/forums/...d.php?t=313060
StryctNy9e is offline   Reply With Quote
Old 04-24-2011, 03:52 AM   #3
huntman58
Raisin city calif.
1993 xlt 4x4
Vehicle Specs
When cutting the wires did you disconnect the battery or at lest pull any fuses related to it first? I ask as one wire is hot all the tie and one is hot with the key on and cutting then with the one hot can short things out big time. I know been there done that and learned the hard way.
May want to unwrap the wire harness and recheck all the wires again as more then once I have found a wire change color.
Also do you have an amp already in your system like a stock one?
Some radios have a built in fuse also on there boards it’s the old glass tube kind and if a single wire strand happened to get crossed that would be more then enough to blow it when you plugged it in and tried to turn it on.
Also recheck all the fuses in the fuse holder as more then once I have thought one was good by looks only to test it and find it blew on the edge were I could not see it.
huntman58 is offline   Reply With Quote
Old 04-27-2011, 03:51 PM   #4
Aussie Canuck
B.C.
93 Explorer XLT
Vehicle Specs
(Original Poster)
I disconnected the negative from the battery. I didnt pull the fuses before hand as the battery was disconnected. After i re-connected it and found out it lit up but had no power i went and re-checked all my fuses but they are all fine.... dont know what the hell is going on but I dont like it. No factory amp in my truck either just the regular speakers. I assume I have some power to my CD player as it spits out a cd when i plug it in but there is no diplay, no lighting up, no static or any type of sound at all and the factory tape deck doesnt display or turn on anything = (
Old 04-27-2011, 04:21 PM   #5
Roadrunner777
Bemidji, MN
Roadrunner777's Avatar
94 4x4 Sport 88k
Vehicle Specs
Does the factory head unit have DNR on it?
Roadrunner777 is offline   Reply With Quote
Old 04-28-2011, 01:56 PM   #6
Aussie Canuck
B.C.
93 Explorer XLT
Vehicle Specs
(Original Poster)
Dnr???
Old 04-28-2011, 02:49 PM   #7
Roadrunner777
Bemidji, MN
94 4x4 Sport 88k
Vehicle Specs
It might have said DNR on the front of the stereo unit, if so, there is a hidden amp. DNR Dolby Noise Reduction
Old 04-29-2011, 03:47 PM   #8
Aussie Canuck
B.C.
93 Explorer XLT
Vehicle Specs
(Original Poster)
Had a closer look at the factory tape deck. It says Dolby Systems on the tape flap and goes on about Noise Reduction System under license by Dolby, however, when i check my fuses box there is no fuses for the special Dolby amp. I have the original sound system operating guide and I have the basic stereo cassette, not the high level audio system with the amp, however it does have the Dolby B noise reduction feature.... Could this be what is screwin up my cd player and not letting it have any power?
Part Number -19B132- Midline AM/FM Cassette Player.
Im almost thinking somehow some wires got crosses when connecting them back to the original harness. This is what I have from the grey clip with the wires coming out the left and the clip on the right.
Slot 1 - Empty
Slot 2 - Empty
Slot 3 - Black/Green = Radio Ground
Slot 4 - Orange/Black = Radio Display
Slot 5 - Lt. Blue/Red = Panel Illumination
Slot 6 - Yellow/Black = Radio Power Feed
Slot 7 - Black (small) = Vehicle Chassis Ground
Slot 8 - Lt. Grey/Yellow = Memory Feed
Assuming all of that is right then could I not just bypass the entire clip itself and straight wire my aftermarket cd player right to my truck wiring?
Old 04-29-2011, 06:01 PM   #9
Aussie Canuck
B.C.
93 Explorer XLT
Vehicle Specs
(Original Poster)
Son of a biscuit! After yelling at my truck, and screaming at it and crying a lil bit I decided to re-check all my connections again. Now before we all say anything I already know im dumb, so lets just make that clear. If ya need an example of my stupidity.... my ignition and constant wires from my cd player to the after market harness were loose. Two quick cuts and reconnections and the thing works like a charm. Factory stereo doesnt work for some strange reason but my cd players does and thats all that counts! Thank to all those who tried to help =)
Old 04-29-2011, 06:40 PM   #10
lynchy wa
Down Under Beer Explorer
Albany, Western Australia
lynchy wa's Avatar
2004 XLT V6 4x4
Vehicle Specs
I know SFA about hooking up stereo's but I reckon it was the crying that finally fixed it for you mate! Good stuff.
__________________
Me-Greg Lynch,Henson Performance,half hornet scoop,blue cobra stripes,Irvin bullbar,red heeler alarm(my dog),K&N,skid plate
2 1/2" exhaust,265/70/17 AT's,1.25" wheel spacers front,1" wheel spacers rear,CB+dual whips/1981 FLH Heritage Edition-Pamela
My wagon Uma
lynchy wa is offline   Reply With Quote
Old 04-29-2011, 08:21 PM   #11
Aussie Canuck
B.C.
93 Explorer XLT
Vehicle Specs
(Original Poster)
Cheers! Tomorrows job.... speakers!
Old 04-29-2011, 09:23 PM   #12
StryctNy9e
1993 XLT Exploder
Vehicle Specs
Dont feel too stupid, I think we have all done that before, I know I have.
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
