Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
93 Explorer 4.0 Fuel System Problems
Reply
Thread Tools
Old 04-28-2011, 06:59 PM   #1
a_cmc_2b
Rural South Mississippi
1993 Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Question 93 Explorer 4.0 Fuel System Problems
Could you good folks enlighten me on all the things that might cause a fuel pump to not pump on a 1993 Explorer? Any diagrams or specs would be great also. Is there a downloadable oem repair manual available? If this is covered in another thread i'd be grateful for any & all links.
I don't want to drop the tank unless I have to.
I have removed the Fuel Filter & get no fuel while turning the engine over.
I checked the inertia(?)switch & it wasn't thrown.
I swapped one fuel pump relay with another one(under hood on passenger fender).
I tried to see if there was a fuel pump fuse under the dash but the fusebox cover is gone.
Thanks in advance for any and all help.
a_cmc_2b is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-28-2011, 07:48 PM   #2
Roadrunner777
Bemidji, MN
94 4x4 Sport 88k
Vehicle Specs
Quoted: 14 Post(s)
It's fuse 18 in the box under the hood. I'll be back later if nobody adds anything to this, but the fuel pump circuit is pretty easy. See if you can get someone to turn the key, while you have a finger on the fuel pump relay and see if it's clicking for you.
Roadrunner777 is offline   Reply With Quote
Old 04-28-2011, 08:18 PM   #3
a_cmc_2b
1993 Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
Originally Posted by Roadrunner777 View Post
It's fuse 18 in the box under the hood. .
Thanks, it wasn't blown.
Old 04-28-2011, 08:58 PM   #4
Robert Nick
Brentwood TN
'92 4WD XLT / 2000 Mounty
Vehicle Specs
Quoted: 0 Post(s)
It might be the pump itself. I would drop the tank and bench test the pump with 12VDC.
__________________
Nick
Robert Nick is offline   Reply With Quote
Old 04-28-2011, 09:12 PM   #5
a_cmc_2b
1993 Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
Is there not a way to test the pump without dropping the tank?
Anyone got the wiring diagram for the fuel pump circuit?
Old 04-28-2011, 09:16 PM   #6
MrShorty
Spanish Fork, UT
92 XLT and '87 Bronco II
Vehicle Specs
Quoted: 10 Post(s)
I've found that the wiring diagram in Chiltons is adequate for the fuel pump circuit. If you don't have a print manual, you can access an electronic version by registering with autozone's website.
As noted above, the fuel pump circuit is a pretty basic DC circuit. Once you know you have a good ground and have 12 V to the pump, if the pump isn't going, then the pump is bad.
__________________
Mr. Shorty
92 XLT 4x4
87 Bronco II XLT 4x4
'98 Chev K1500 Suburban SLT 4x4
MrShorty is offline   Reply With Quote
Old 05-01-2011, 09:19 PM   #7
a_cmc_2b
1993 Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Ok, picked up a new pump and sock at the parts house today, got the tank dropped but cannot get the fules lines disconnected. What's the special trick? I have a set of plastic tools that i've used on other vehicles and even to take the fuel filter off of this Explorer.
If you have a part number or picture of the exact tool you use that works well please post it.
Old 05-01-2011, 09:59 PM   #8
a_cmc_2b
1993 Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I'm using choice number 2 from this thread
http://www.explorerforum.com/forums/...d.php?t=237368
Reply
Tags
filter, fuel pressure regulator, fuel pump, inertia switch, sock
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
