Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Wheel bearing/ Starting Issue
Reply
Thread Tools
Old 04-29-2011, 11:30 AM   #1
bracyder
Vehicle Specs
(Original Poster)
Hi all,
Recently my brother began looking for a used vehicle and wanted an Explorer. We looked at quite a few so far some nice some rough. Recently we looked at a 2004 that was a very nice clean car at a Ford dealer, which leads me to my next questions. Upon trying to start the car the engine turned over but would not fire we tried three time and finally on the fourth time it did fire. I found this very odd being and have done some research on why it didn't fire only to fond it could have something to do with the throttle body and a hole. Has anyone seen an issue similar to this?
Next, while test driving the car there was a hum in the left rear that sounded like a large tread tire hum. I am familiar with noises cars make and fairly mechanically inclined but this seemed to stump me as it really didn't sound like a wheel bearing going out. However, after reading some post and talking to some others familiar with the explorer wheel bearings sound like they are a typical problem.
In closing the vehicle is a 2004 Eddie Bauer AWD with 100K miles. Anyone with advice and knowledge is appreciated.
bracyder is offline   Reply With Quote
Old 04-29-2011, 03:24 PM   #2
guilateen
RI
02 mounty awd 4.6
Vehicle Specs
ford dealer should know better definitely hubs , dont get the 6cyl underpowed,not as reliable, and not more efficient as the 8. as for firing up no clue bet it was a 4.0 though. make sure cd player works, rear springs not cracked mainly an 02 problem. pay close attention to tranny shift points any hesitation run away . the rear ends r known for making a whine or howl noise there r a few threads on it
guilateen is offline   Reply With Quote
Old 04-29-2011, 11:17 PM   #3
jakedrew
wisconsin
04 xlt
Vehicle Specs
is it all wheel drive or automatic 4x4? i personally would stay away from the "awd" one as I heard from a few here about issues.
As to tell if it is a rear end issue, get it warmed up( like 5+miles) get up to 55 ish, let off the gas, get on the gas slightly and if the noise comes and goes it is a ring and pinion issue.
Wheel bearings- them make noise all the time. I have a 04 xlt v8 and had the rear end done at 55k miles ( now howling a little again at 73k but I dont care) had 3 wheel bearings done ( 1 front and both rears). I did the front and the rears I took to ford as I dont want to mess with that. I have all the tools/ shop space but rather pay to have them done.
also the blend door actuator is a known issue. ford wants 600- 1000$ to fix, there are directions here to fix it for under 75$.
This is the best place to be. you will find any info you are looking here.
jakedrew is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
