Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
05 4.0 explorer electrical issue?
Reply
Thread Tools
Old 04-29-2011, 08:51 PM   #1
FamousAmos
NY
2005 Exlorer
Vehicle Specs
(Original Poster)
Thanks to another thread I found here searching for a fix to a problem I was having with my windows/locks. Long story short it was 2 broken wires in the rubber boot in the door. I unhooked the battery so I could fix the 2 wires. Cut to the chase get everything back together and go to start the truck and it goes into failsafe mode and at one point a "test mode". Also the little wrench light is on.Everything works fine in the failsafe mode except you get nothing from the gas pedal. It had ran just fine all morning. After reading some other posts I replaced the battery which it needed anyways. I thank all in advance and please bare with me I am by no mean mechanically inclined.
FamousAmos is offline   Reply With Quote
Old 04-30-2011, 09:40 AM   #2
swetrid
Reading Pa
2001 Eddie Bauer
Vehicle Specs
Clean the throttle body.
__________________
Resident Ford Tech for the last 17 years, 2001 Eddie Bauer 5.0L, Cherry Bomb Cat back, 2010 Ecoboost Flex
swetrid is offline   Reply With Quote
Old 04-30-2011, 01:07 PM   #3
FamousAmos
NY
2005 Exlorer
Vehicle Specs
(Original Poster)
I will give that a try thanks. Any clue why I am having this issue.
Update 1 hour or so later. The cleaning appears to have solved the problem the truck starts normally now. However the service engine light remains on.
On a side note I had to unhook the the broken wires in the door boot the wires that are broken are for my power locks and windows. Do I need to unplug the battery to fix the wires?
Old 04-30-2011, 03:58 PM   #4
swetrid
Reading Pa
2001 Eddie Bauer
Vehicle Specs
The light will go out if you clear codes with scanner, disconnect the battery or after so many key cycles without the problem showing up.
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
