#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Proper way to jack up an explorer
Reply
Thread Tools
Old 05-05-2011, 02:41 PM   #1
watt9386
Croydon, Pennsylvania
94 xlt & 97 sport
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
I have a 94 explorer that needs brakes. I need to know the proper way to jack it up and not break anything. I have it sitting on jack stands on the radius arms. Help?
__________________
{sitting}94 xlt fixed trans, broke owner.
{Current}97 sport 187k. 01 sport gauges, TT, Shackles, 32x11.5x15 wrangler mtr's
I didn't know jesus wore camo and fixed explorers - spas
watt9386 is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-05-2011, 02:58 PM   #2
Baddecision93
Orrville, OH
92 XLT
Vehicle Specs
Quoted: 0 Post(s)
Jack stands on the radius arms are fine...How did you get it jacked up to get the jack stands under there?
Just reverse that.
Or are you asking about how to do the rear?
__________________
It's nothing time and money can't fix...
Trying to reverse rust, time, and the work of a crazy Amishman
My Explorer
Quote:
Originally Posted by DeRocha View Post
I can tell you Jesus is very popular when working on 10+yrd vehicles in the rust belt.
Baddecision93 is offline   Reply With Quote
Old 05-05-2011, 03:02 PM   #3
Reejerey
SLC UT
92 XL 2 dr 4x4 manual
Vehicle Specs
Quoted: 0 Post(s)
in the rear just put your jack under the pig if its a floor jack, if scissor jack that came with truck, on the tube near the shock mount is fine
Reejerey is offline   Reply With Quote
Old 05-05-2011, 03:39 PM   #4
watt9386
94 xlt & 97 sport
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Quote:
Just reverse that.
I used floor jacks underneath the I beams. Its sitting awkard on the RA though. I'm going to take a couple pics for you guys.
__________________
Old 05-05-2011, 06:06 PM   #5
Currency
Bedford Indiana
94 XLT 4x4
Vehicle Specs
Quoted: 1 Post(s)
Quote:
Mine came with a bottle jack. It hides where the rear window washer tank is located at.
As for jacking them up. I have always generally jacked the front up near the front tires, not sure exactly what you would call it. But it's the steel under the area where the front axles are at.
For the rear, I have always jacked mine up with one floor jack under the rear end. Trust me, I have jacked the rear up many a times, more so than the front because if I hit a hard enough bump my rear brake adjusters simply fall out
I have always placed jack stands under the frame. It is second nature to me but either way I have access to a lift which eliminates the need for jacks and jack stands.
__________________
My registry. http://www.explorerforum.com/forums/...d.php?t=257045
I may be interested in one or more first gen parts explorers. PM me if your not to far with pics and price.
Currency is offline   Reply With Quote
Old 05-05-2011, 07:11 PM   #6
Roadrunner777
Bemidji, MN
94 4x4 Sport 88k
Vehicle Specs
Quoted: 14 Post(s)
The factory service book shows the jack points for the 1994 Explorer using the bottle jack as:
Front: Underneath the shock absorber
Rear: On axle tube, 1/2 between pumpkin and springs
You can also use what I guess I would call frame outriggers just in back of the front wheel and just in front of the back wheel, and any of the structure between the two front spring towers.
Roadrunner777 is offline   Reply With Quote
Old 05-06-2011, 07:22 PM   #7
huntman58
Fremont calif.
2013 Dodge Advenger
Vehicle Specs
Quoted: 1 Post(s)
That’s the points I always use did not know they were what the book said to. I also always place the stands under the frame and the tire when off under the frame lying down also that way if the jack and the stand fail the tire is still there to keep it off the ground or my legs if ever needed. Can we say safety first.
Learned that when a high lift jack kicked out and a jack stand went with it both tires off the rear end of a full size truck and the rear end pumpkin landed on my long hair back then (I was young then and had hair unlike now old fart and almost no hair LOL) pinning me under the truck talk about needing to change shorts after wards. I was doing a add a leaf lift at the time. Now I make it a habit to add the wheels as an extra safety and it keeps them out of my way most of the time to boot.
huntman58 is offline   Reply With Quote
Old 05-13-2011, 11:03 AM   #8
alakers
casper, wyo
'94 4WD
Vehicle Specs
Quoted: 0 Post(s)
my recommendation is most definetely to buy a floor jack. the stock ones, work ... but they're such a pain !!!! If you get a floor jack, put it under the axle. front or rear. Use the differential ... that steel is meant to be abused and you really can't hurt it just jacking it up. Make sure to set your brake, block your tires. have a pepsi nearby, put it on a level surface. Don't fry bacon with your shirt off. Goodluck.
alakers is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
