#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Window won't go up.
Reply
Thread Tools
Old 05-09-2011, 05:54 PM   #1
HOOB
cypress ca,
94 xlt 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US Window won't go up.
I have a 94 explorer xlt v6 My drivers window will not roll up could this be fuse if the other windows work I dont know if the motor has gone out but it had not began to slow down or any thing yet and I think it is getting power to the switch because when I push the switch the volts meter on the dash goes down a little also the door ajar alarm bell goes off alot and I have to slam the door hard to get it to shut off could these be related problems where do I start
HOOB is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-09-2011, 06:22 PM   #2
rookieshooter
Moderator Emeritus
Martinsburg WV
rookieshooter's Avatar
84 BII "Li'l Samson"
Vehicle Specs
Quoted: 2 Post(s)
I had a 97 X that the pass. side window went down but would not go back up.
Now this was years ago and I took the door panel off and found out that the switch that makes it go up reverses the polarity, what was neg is now positive and makes the electric motor turn the other way causing the window to go up.
So you might want to check the switch.
For a quick fix to go up I ran a temp wires from a batt. to the motor and reversed the connections. Never did get a new switch cause I got rid of it a few days later.
__________________
"2013,2012 & 2011Truck Nationals" At Carlisle Extreme 4x4" First Place winner.
2013,2012,2011 All Ford Nationals winner. 2X first 1X second
Featured in 2012 Bronco Driver Mag.
Petersen's 4Wheel mag ROTM. Voted 2008 Bronco II of Year
rookieshooter is offline   Reply With Quote
Old 05-09-2011, 07:37 PM   #3
HOOB
cypress ca,
94 xlt 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks Ill give it a go
Old 05-09-2011, 09:19 PM   #4
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! I've moved your thread into the stock 91-94 section. Check the wiring between the door, and the frame of the vehicle.
BrooklynBay is offline   Reply With Quote
Old 05-10-2011, 01:02 AM   #5
Champcar_Fan
No.Cali
1993 XLT 3
Vehicle Specs
Quoted: 0 Post(s)
You need new bushings for the motor. My 93 had the same exact symptoms. See this thread and you'll be set with $10-20 in parts.
http://www.explorerforum.com/forums/...d.php?t=145469
Champcar_Fan is offline   Reply With Quote
Old 05-10-2011, 03:50 AM   #6
YBCold
702 LΛ VGΛ NV / МΠΤΣΓΓΣΨ ΜΧ
91 ∟┬
Vehicle Specs
Quoted: 7 Post(s)
yeah try to get new bushings for the motor. or could be the switch is it moving up at all like it tries but doesnt make it or does the motor engage at all? i did the regulator on my aunts town car but i didnt use lock washers on the mounts now it doesnt move properly anymore gotta redo it
YBCold is offline   Reply With Quote
Old 05-10-2011, 11:46 AM   #7
94explorer
kernersville
94 limited 4wd
Vehicle Specs
Quoted: 0 Post(s)
i just had the same problem i went to advanced auto bought bushings and greese for 12 bucks cheap fix eh
94explorer is offline   Reply With Quote
Old 05-10-2011, 02:43 PM   #8
1ATony
EF Vendor
mass
1ATony's Avatar
92 explorer
Vehicle Specs
Quoted: 21 Post(s)
Quote:
Before buying anything. I would first purchase a test light to see if you have power to the switch and then to the motor in the door. If there's power to the motor then then window motor more than likely may have gone bad.
If there isn't any power to the switch as stated above check the door harness for frayed of broken wires between the door and body of the truck.
__________________
SHOP HERE FOR EXPLORER PARTS FREE SHIPPING!!!
1ATony is offline   Reply With Quote
Old 05-28-2011, 02:28 AM   #9
Makahveli
Denver, CO
'92 Sport and AMG 300CE
Vehicle Specs
Quoted: 8 Post(s)
I finally got around to checking into my passensger window that one day went up and that was that! Took a test light and tested power at the switch and the power was there, so then I switch switches from my drivers door to test the switch and work like it was suppose so they I knew it wasn't the switch. then tested at the wire connector/harness that goes to the window motor and found it funny as when you push up power goes through one side and when you push down it goes through the other side like rookieshooter was saying........so that being said I believe its the window motor for me........damn this really wasn't in my plans 1ATony I'll be calling you soon!
__________________
305/40r22 Nittos, KMC Rims, K&N, Granatelli MAF, BBK TB, Borla muffler & headers, Magnaflow Cat, 4" lift (Assorted Parts), 2 15" Eclipse Subs+Amps, 4.56 gear ratios, SCT 5 Program Chip, Warn Hubs, Paxton Supercharger SN2000, Port & Polished 95TM Heads+Lower Intake, 422 Cam, 30lbs Injectors, Snow Water Methanol Kit, Ready to Race!!!
IF YOU GOTTA BE A MONKEY BE A GORILLA
Makahveli is offline   Reply With Quote
Old 05-28-2011, 01:41 PM   #10
Wade99
Palm Harbor, FL
99
Vehicle Specs
Quoted: 0 Post(s)
9 times out of 10 (and this is typical with older Fords with power windows) it is the bushings in the motor. I get the "clunk, clunk, clunk" with the fronts when I go to work them down. From my Mustang experience I immediately knew what it was and got me some bushings. Have fun getting three new ones in AND the cover back on.
Wade99 is offline   Reply With Quote
Old 06-15-2011, 12:13 PM   #11
Makahveli
Denver, CO
Vehicle Specs
Quoted: 8 Post(s)
Well I bought a new motor for my passenger door on ebay and was only a lil over $30 and before pulling the entire regulator out I tested the new motor and now I assume its a wiring problem. Just like 6-7 yeras ago when the window last went up I find the same problem persist with even a new motor plugged in. The motor works when pushing the up button but not down at all and another downer is the controls won't work for the window at all at the drivers door...... Before taking this to the shop anybody knows what I need to or should do? I must note that I used a test light and had power coming out of both sides of the connecter when pushing up and down.....
__________________
Old 07-13-2013, 02:58 PM   #12
angela75
Belton, MO
94 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
My window issue on my 94 Explorer was I had to slam door to get to move. Now stuck in down position. BLAH
angela75 is offline   Reply With Quote
Old 07-13-2013, 08:47 PM   #13
slowtruggy
lumberton tx
slowtruggy's Avatar
1994 explorer
Vehicle Specs
Quoted: 4 Post(s)
On my 94 explorer xlt i had problems with my drivers window and it was i think they call it a one touch module its a little black box in the door its for when you push the button the window will roll down by its self i went to a pull a parts and got one works good now
slowtruggy is offline   Reply With Quote
Old 07-14-2013, 09:46 AM   #14
arco777
arco777's Avatar
1994 Explorer 2dr 4x4
Vehicle Specs
Quoted: 73 Post(s)
The door ajar chime is triggered by a pressure (pushbutton) switch mounted to the body. When the door closes, the metal of the door presses against the switch button on the body and breaks the chime circuit. There are two failure points of this part. One, sometimes the metal of the door bends (dents) where it hits the switch button, so it is not pushing the button in. This is fixed by pulling the metal back straight or adding a filler like JB Stick. Another failure is of the switch itself. These switches eventually go bad. You can easily unscrew the switch from the body, disconnect the wire connector, and replace it with a new or used switch.
There is no wiring shared between power window circuit and door chime circuit. The door chime wiring does not go into the door. Your two issues are mutually exclusive.
__________________
-1994 Explorer 2DR 4x4 - Explorer Express X-Spec swaybars/shocks, BBK throttle body, Dynomax exhaust, misc trans upgrades.
-2008 Mustang GT Bullitt #5560 - Brenspeed tuned
-1995 fullsize Bronco 5.8L - intake, exhaust and trans mods, cosmetic mods.
arco777 is offline   Reply With Quote
Old 07-15-2013, 07:32 PM   #15
angela75
Belton, MO
94 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
I am aware of the little black box on the window but no one could tell me what it was so could not find one. Will look again and hope it works. Thanks
Old 07-16-2013, 05:59 PM   #16
angela75
Belton, MO
94 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
Just a quick thank you to all suggestions. The simplest idea worked as I pulled the black control off and inserted a 25 fuse into lage area and YES it works. Sticking with that for now.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
