#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Tow Rig Forum
Notices
Tow Rig Forum Towing, hauling, boats, campers, trailers etc... Trailer hitches, weight distribution, hitch ball, safety chains, tow bar and brake controllers. Discuss it all here!
Can I pull travel trailer?
Reply
Thread Tools
Old 06-03-2011, 12:48 AM   #1
steffel
Arnold,MO
2005 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have a 2005 Ford Explorer with the 4.0L V6.
I would like to know if I would be able to pull this trailer a couple hours away from my home.
MANUFACTURER Autumn Ridge
MODEL YEAR 2009
MODEL 181CK
WEIGHTS
GROSS VEHICLE WT RATING (GVWR) 5,800 lbs.
UNLOADED VEHICLE WT (UVW) TBD
CARGO CARRYING CAPACITY (CCC) TBD
HITCH WEIGHT TBD
MEASUREMENTS
LENGTH FEET 23
OVERALL LENGTH 23 ft. 1 in.
EXTERIOR HEIGHT 9 ft. 8 in.
EXTERIOR WIDTH 8 ft.
INTERIOR HEIGHT 6 ft. 8 in.
WHEELS/TIRES ST205/75R 14C
BODY
SLEEPING CAPACITY 7
OPERATIONAL
FRESH WATER CAPACITY 50 gal. including water heater
GRAY WATER CAPACITY 26 gal.
BLACK WATER CAPACITY 26 gal.
AIR CONDITIONER BTU RATING 13,500
FURNACE BTU RATING 19,000
WATER HEATER CAPACITY 6 gal.
PROPANE TANK CAPACITY (2) 20 lb. tanks
AXLE QUANTITY 2
EXTERIOR STORAGE Yes
Please let me know what you think I should do. Do you think that I would be able to handle this trailer?
steffel is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-03-2011, 07:22 AM   #2
MountaineerGreen
Towing Moderator
North East Arkansas
MountaineerGreen's Avatar
2012 F150 4x4
Vehicle Specs
Quoted: 8 Post(s)
My first thought is no, with the independent rear suspension, class II hitch and v6, its stacked against you.
MountaineerGreen is offline   Reply With Quote
Old 06-03-2011, 08:34 AM   #3
steffel
Arnold,MO
2005 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I forgot to put his in the first post but I have the class III/IV tow package on my truck. Looking in the manual it says that the 4.0L SOHC with a Class III/IV hitch Max trailer weight is 5380lbs and Max GCWR is 10000lb. With some mods do you think that I could make the ride a little easier.
Old 06-04-2011, 07:30 AM   #4
MountaineerGreen
Towing Moderator
North East Arkansas
2012 F150 4x4
Vehicle Specs
Quoted: 8 Post(s)
Quote:
Changing the hitch does not constitute a "tow package". A tow package vehicle has lower axle gearing, an additional transmission cooler.
If you added a trans cooler and brake controller and keep it out of OD, you can probably do it, but you are on the edge of what you need to be towing.
Old 06-06-2011, 10:07 AM   #5
jrford
Birmingham, MI
'10 Sport Trac
Vehicle Specs
Quoted: 0 Post(s)
imo its looking a little weak, even with the stock Tow package, the 3.73 gears will help. But that V6 would be a little thin looking at the numbers. Your right on the tow limit, but thats a big camper, don't forget to add frontal area to the calc - that would put you over the limit. If you just wanted to pull it once or twice a year maybe. . .weekly no way.
something like AR-ONE 16BH would be fine. . .only 2,500lbs, little smaller though.
__________________
Jim
2010 Mercury Mountaineer Premier, V8 AWD, 35k
2010 Sport Trac Limited, V8 4WD, 80k
2004 EB Quad Buckets V8 AWD, 105k
jrford is offline   Reply With Quote
Old 06-06-2011, 10:32 AM   #6
skeeter123
2002 XLT 4.6L
Vehicle Specs
Quoted: 0 Post(s)
Just to be sure I'd check the weight #'s as posted on the sticker on the driver's side door. Sometimes people install aftermarket Class III/IV tow-hitches onto vehicles not built with all the tow-package options.
And remember that water is 8lbs/gallon; i wouldn't be filling that reservoir up before the trip....
skeeter123 is offline   Reply With Quote
Old 06-21-2011, 10:26 PM   #7
thebrakeman
Canton, Michigan
2006 Mercury Mountaineer
Vehicle Specs
Quoted: 80 Post(s)
Assuming you actually have the Class III/IV tow package, then you have 10,000 lbs GCVWR (combined weight rating). Most travel trailers have a lot more cargo capacity than you will every really use. So you need to find out what the trailer weighs when loaded (if you already have the trailer), or add 800 lbs to the published dry/empty weight as a good typical estimate.
Subtract the estimated trailer weight from 10,000 lbs, and that is what your loaded Explorer can't exceed. Subtract the empty weight of the Explorer, leaving you with your passenger an truck-cargo capacity.
You'll probably need to keep the trailer to no more than aroud 4500 lbs to have any hope. But do the math.
__________________
thebrakeman ('70)
DW ('71), DD ('99), DD ('01), DD ('05)
2006 Mountaineer Premier V8 AWD w/Tow Package, ScangaugeII
Cashmere/Camel Interior, navigation, power 3rd row
2004 Surveyor 261T Hybrid Travel Trailer (27 ft)
Equal-i-zer 10,000 lb 4-pt Sway Control WDH
thebrakeman is offline   Reply With Quote
Old 01-12-2016, 12:46 AM   #8
jurisgnostic
2004 explorer
Vehicle Specs
Quoted: 1 Post(s)
we seem to have a tow package but not the transmission cooler. if i replace the transmission, which still works but has heat damage, and put in a cooler, then below 3000 pounds should be fine?
jurisgnostic is offline   Reply With Quote
Old 01-12-2016, 12:21 PM   #9
thebrakeman
Canton, Michigan
Vehicle Specs
Quoted: 80 Post(s)
Quote:
Recommend you start a new thread, if this is actually a serious post.
__________________
thebrakeman ('70)
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
