Code 32 (Pinpoint Test G: LFC 32/DTC B1932 — Driver Air Bag Module Circuit High Resistance or Open)
Excessive resistance across Pins C232-2, Circuit 614 (GY/O) and C232-3, Circuit 615 (GY/W) can be caused by:
a poor connection or corrosion where the air bag sliding contact connects into the main wiring harness. The air bag sliding contact connector at the base of the steering column may have excessive resistance between the male and female terminals in the connector. Also, corrosion may occur on the terminal crimps on both the air bag sliding contact terminals and the main wiring harness terminals.
an open circuit or high resistance in the air bag sliding contact windings inside the air bag sliding contact.
an open circuit or high resistance in the wiring harness in either Circuit 614 (GY/O) or Circuit 615 (GY/W).
an open circuit or high resistance in the driver air bag module. Do not attempt a direct resistance measurement of the air bag module. Follow the diagnostic procedure to determine if the air bag module resistance is higher than normal.
Ford Motor Co service manual
