Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2011 - 2017 Ford Explorer 5th Generation Explorer > Stock 2011 - 2017 Ford Explorer Discussion
Notices
Stock 2011 - 2017 Ford Explorer Discussion 2011 - 2017 Ford Explorer reviews, problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost.
Emergency hazard flashers on a 2011 Ford Explorer.
Reply
Thread Tools
Old 06-06-2011, 05:18 AM   #1
Rowan928
AL
2011
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Have just purchased a 2011 Ford Explorer and cannot find the emergency flashers. Needed them desperately at 3:00 this am when taking a family member to the hospital... WHERE ARE THEY? !!
Rowan928 is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-06-2011, 06:07 AM   #2
Ilikemice
Midlands, UK
Ilikemice's Avatar
'99 XLT
Vehicle Specs
Quoted: 8 Post(s)
Welcome! Is it the red triangle In the middle below the navigation screen? That's just going from a pic though.
__________________
1997 UK spec
1999 XLT "Meerkat"
Ilikemice is offline   Reply With Quote
Old 06-06-2011, 09:49 PM   #3
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 427 Post(s)
Welcome to this forum! I've moved your thread into the stock 2011 Explorer section.
BrooklynBay is offline   Reply With Quote
Old 06-06-2011, 10:18 PM   #4
bobby299
Missouri
2012 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Reminder: that's what ambulances are for. And hazards do not exempt you from traffic laws. Just sayin'. Hope all is well with your family member
bobby299 is offline   Reply With Quote
Old 06-06-2011, 11:43 PM   #5
Loganfilm
Santa Monica, CA
'11 Limited 4WD
Vehicle Specs
Quoted: 0 Post(s)
You'll find it when you start messing with your MFT unit. It's where your finger wants to rest while you're inputing things and you'll trigger it all the time by accident until you get used to it. Poor design.
Loganfilm is offline   Reply With Quote
Old 06-07-2011, 08:56 AM   #6
aarmchair
toronto, ontario canada
2011 xlt, FWD,ltr,tow,nav
Vehicle Specs
Quoted: 0 Post(s)
agreed - for the first little while everytime i went to use MFT i set off the hazards - especially if my wife used it from the passenger seat. Her bracelet kept hitting it.
not the best spot for this - on top of the screen would be much better.
aarmchair is offline   Reply With Quote
Old 06-07-2011, 09:48 AM   #7
jrmexplorer
2011 Limited
Vehicle Specs
Quoted: 29 Post(s)
As other have said, its the red triangle below the MFT screen. It doesn't look like the hazards - it looks like a little recessed sticker, but it is - it's a capacitive touch button which I find very tricky to turn on (except - as others have said - when I'm playing with MFT) and trickier to turn off.
jrmexplorer is offline   Reply With Quote
Old 06-07-2011, 11:18 AM   #8
02Sploder
Minnesota
'02 Eddie Bauer V6
Vehicle Specs
Quoted: 0 Post(s)
I thought my eject button on the CD player and the hazard button were faulty at first. They only seemed to work sporadically or if I pressed extra hard. What I've found that works consistently is to hold your finger on the button for a little bit (maybe a 1/2 second or so). This must be as intended - it makes sense to prevent accidental turning on of the hazards or ejecting a CD (although I've still accidentally turned on the hazards a handful of times). These are the only two buttons I've found so far that act this way.
02Sploder is offline   Reply With Quote
Old 06-07-2011, 12:43 PM   #9
stook2001
Durham, NC
2011 Limited 4WD
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Totally agree! I hit it all the time by accident.
stook2001 is offline   Reply With Quote
Old 06-07-2011, 09:32 PM   #10
dco43054
cmh
16 XLT
Vehicle Specs
Quoted: 192 Post(s)
Quote:
Page 325 of your owner's manual?
Quote:
HAZARD FLASHER CONTROL
The hazard flasher should be used
when your vehicle is disabled and is
creating a safety hazard for other
motorists.
The hazard flasher control is located
on the center of the instrument
panel. The hazard flashers will operate when the ignition is in any
position or if the key is not in the ignition.
Press the flasher control and all front and rear direction signals will
flash.
Press the flasher control again to turn them off.
Lots of good info in there.
dco43054 is offline   Reply With Quote
Old 06-08-2011, 07:45 AM   #11
russell bruesch
new buffalo michigan
2011 limited 4wd
Vehicle Specs
Quoted: 1 Post(s)
ITS so easy to accidently brush against it when manually operating the 8 inch mft screen and turn it on,but not so easy to turn it off. It takes repeated hard presses to turn the dam thing off. I have tried lightly touching it to hard presses and sometimes it takes several seconds to find the right combination to turn it off. Its a distraction as my eyes are off the road and i am swearing at the damm car.
russell bruesch is offline   Reply With Quote
Old 06-08-2011, 09:39 AM   #12
darth_hangover
'11 Limted (on Order)
Vehicle Specs
Quoted: 0 Post(s)
Quote:
FYI, my dealer told me that every other control is touch sensitive, but the hazard button is, apparently, "heat" sensitive so just holding your finger on it for a bit should trigger it, not pressing it...
darth_hangover is offline   Reply With Quote
Old 06-08-2011, 11:14 AM   #13
BethesdaEC
Ellicott City, MD
2011 Red Explorer Limited
Vehicle Specs
Quoted: 0 Post(s)
Quote:
It is not heat sensitive, they just put a timer on it so you don't brush against it and turn them on. You have to hold it for about a second.
BethesdaEC is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
