Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Compression problem.
Reply
Thread Tools
Old 06-06-2011, 10:39 AM   #1
94explorerjunk
atl/ga.
1994 explorer xlt
Vehicle Specs
(Original Poster)
Have a 94 explorer xlt. 2 days ago started losing major rpm's going up a short 45 degree hill. this occured a couple of more times on the way home. changed plugs because it was needed and I know the muffler has a major hole in it. almost forgot, easy start leaving work and stopped at ingle's for fuel. one more stop and the truck wouldn't start without a boost. the climbing problem happened afterwards. coming to work today i noticed that if i backed off the gas a little when the rpm's drop then i could hit it again and the truck would climb. any solutions or checks?????
94explorerjunk is offline   Reply With Quote
Old 06-06-2011, 10:07 PM   #2
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Welcome to this forum! I've moved your thread into the stock 91-94 section.
BrooklynBay is offline   Reply With Quote
Old 06-06-2011, 11:04 PM   #3
That-Guy
94 Explorer
Vehicle Specs
it sounds like you are running lean. Sounds like you might need a new fuel pump.
That-Guy is offline   Reply With Quote
Old 06-07-2011, 09:16 AM   #4
Roadrunner777
Bemidji, MN
Roadrunner777's Avatar
94 4x4 Sport 88k
Vehicle Specs
Backing off and it works better, that does play into poor fuel delivery. It can also be a vacuum leak.
Roadrunner777 is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
