#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
'97 Mercury Mountaineer. Shift at high RPMs.
Reply
Thread Tools
Old 06-07-2011, 04:16 AM   #1
Nitases
Seguin, TX
'97 mountaineer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thumbs down '97 Mercury Mountaineer. Shift at high RPMs.
I have a '97 Mercury Mountaineer 2WD. It runs great esp. when cool or cold. However, when it warms up I have to get the RPMs up to 2500 and let off on the throttle before it will shift into all gears. There is intermittent times when it will shift fine when warm but I can't figure it out. It did get progressively worse about it running fine before warm up...that is it took less time before malfunction over time. I've checked TPS, fluid/filter, VSS and the voltages required for them. It doesn't slip, it just doesn't shift unless I throttle back. Does anyone know why. Damn online mechanics don't know diddly squat. I've told them same info. I even tried CARTALK but they don't answer. Probably because they don't know either.
Nitases is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-07-2011, 06:38 AM   #2
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
engine & transmission?
Which engine and transmission are in your vehicle?
You may have low line pressure which is more apparent when the ATF is warm. If you have a 5R55E you could have a blown out valve body separator plate gasket or a worn EPC solenoid.
2000StreetRod is offline   Reply With Quote
Old 06-07-2011, 10:26 AM   #3
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! I've moved your thread into the transmission section.
BrooklynBay is online now   Reply With Quote
Old 06-07-2011, 08:02 PM   #4
swetrid
Reading Pa
1999 Eddie Bauer
Vehicle Specs
Quoted: 4 Post(s)
I think 97 Mountaineer only had 5.0L engine. I believe you have internal seal or piston concern that gives you those symptoms. Also double ck the fluid level.
__________________
Resident Ford Tech for the last 17 years, 1999 Eddie Bauer Explorer, 1987 Mustang GT, 2013 Focus ST
swetrid is offline   Reply With Quote
Old 06-08-2011, 07:23 AM   #5
98 5oh XLT
Clackamas, Oregon
98 XLT AWD X "Loki"
Vehicle Specs
Quoted: 0 Post(s)
LB Did that when I first bought her. She was a little low on fluid, i topped her off and have had trouble free motoring since. I second the fluid comment.
__________________
Russ F.
1998 Ford Explorer XLT v8 AWD "Loki Bandit"
Click to see progress on Loki Bandit
1996 Ford Bronco XLT 351w 4x4(DD)
Bandits steal the show!!!!
The Fun Hump Day Radio Show
98 5oh XLT is offline   Reply With Quote
Reply
Tags
mercury, mountaineer, rpm, shift point, throttle response
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
