Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2006 - 2010 Explorer Mountaineer 4th Generation > Stock 2006 -2010 Explorers
Notices
Stock 2006 -2010 Explorers Stock 2006 -2010 Ford Explorer Forum. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Rear hatch panel and handle removal
Reply
Thread Tools
Old 06-10-2011, 03:06 PM   #1
dennism3
BC Canada
1997 EB 5.0L 2006 Ltd 4.6
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
I don't know if this is valuable but on our 2006 Ford Explorer Limited we had a hint of rust on the crimping/weld at the bottom of the hatch door and at the bottom of the plastic black hatch handle so....
I removed the interior panel:
Window must be open. 2 screws/bolts on the right lower pull handle. Then just start pulling/prying the panel off. It has metal v clips in slots. Only note is be gentle and the side pillar area beside the glass should not be pulled straight off the back but towards the glass a bit. Those clips are not perpendicular to the door but need to be pulled sideways.
Exterior chrome handle:
The exterior chrome is removed with the 4 bolts visible(rust covered in my case, to be replaced with stainless. Then the Ford emblem is still attached to the door and keeping the handle attached. I had the interior panel off so cut a slot in the plastic moisture guard(it was not sealed in several places anyway!!! ) and put my hand in and pressed on the side of the plastic clip and chrome exterior handle came out. I believe you could just pry up and the plastic plug/clip might release without breaking.
Now to sand and touch up the paint where a little rust is showing. Using wool/oil?? to spray inside the door and cover it with oil/wax to maybe prevent further rust inside the door. Seal up the plastic moisture barrier which let rain? in when back window was open or if window leaks a bit(don't know which) .
I'm not a handy guy so maybe this is a piece of cake to others but not to me. Maybe it'll help someone.
dennism3 is offline   Reply With Quote
( Join the Elite Explorers )
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
