Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Torque specs for front wheel bearing replacement
Reply
Thread Tools
Old 06-11-2011, 10:33 AM   #1
elcruzmissle
Colorado Springs, CO
2004 eb 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I dont ever honestly post but i research a lot on here. Everyone has a good hub replacement walkthru but few have the torque specs which are needed to finish the job. Heres what chilton says for the 2004 (02-05 gen);
To install:
Installation is the reverse of the removal procedure.
Observe the following torques:
Upper ball joint-to-wheel knuckle nut: 38 ft. lbs. (52 Nm)
Lower ball joint-to-knuckle nut: 129 ft. lbs. (175 Nm)
Tie-rod end-to-knuckle nut: 52 ft. lbs. (70 Nm)
Hub-to-wheel knuckle bolts: 83 ft. lbs. (112 Nm)
Anchor plate bolts: 83 ft. lbs. (112 Nm)
Axle retainer nut: 184 ft. lbs. (250 Nm)
Check and, if necessary, align the front end.
Always install new:
Wheel hub-to-wheel knuckle bolts.
Cotter pins.
Castellated nuts.
Upper ball joint-to-wheel knuckle nut.
Axle retainer nut.
Hopefully that helps everyone since i had to take the knuckle off and go to a shop with a press to get mine out.
elcruzmissle is offline   Reply With Quote
( Join the Elite Explorers )
Old 07-02-2011, 10:40 AM   #2
elcruzmissle
2004 eb 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Also if you removed the Sway Bar end link on either side to replace the CV axle then the torque is 18 lb-ft
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
