| Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions. |
Thread Tools |
#1 |
Wannabe Elite Explorer
92 xl
high altitude help
i just moved to colorado right outside iof denver. i have a 1992 explorer and moved here fro arizona. since i got here the truck runs a little rough, high idle and does not accelrate or run as good as it did in arizona. what are some things i can do to get my performance back. i have already pulled the little grey lego type chip called the octance booster or whatver. it helps some but still high idle, and does not go up hill at all really, you almost need to floor it and it doesnt accelerate it just holdss a speed.
#2 |
Bemidji, MN
94 4x4 Sport 88k
Put the octane clip back in, it retards timing and will cost you both power and mileage. You might try disconnecting the battery for 30 minutes to force the computer to relearn idle. I guess I will leave it to others in high places for comments...
I know a long time ago I drove a pinto from SF to tahoe all the time and I did 3 things that helped get up the mountain. First, I opened up airflow as much as I could with aftermarket air filters. I might, in this instance, just maybe give one of those conehead deals a shot. Next, I opened up exhaust, I put a header on the pinto, put a short flowthrough muffler on the end of the header and called it a day. And, I opened up the jetting on the holley-weber a few sizes. Of course, none of this would pass CA inspections today, but that was back in 1980. And, I'm not sure how to translate that to your situation. I'd make sure the Cat converter was in good shape, maybe open up the exhaust with some better flowing components. I don't think the jetting is relevant to fuel injection. Your Mass... Hey, wait. Yeah, clean your mass airflow sensor and see what happens. That's the part that is supposed to compensate for thin air. I'd do that and then reset the computer. Last edited by Roadrunner777; 06-11-2011 at 06:05 PM. |
#3 |
Germantown, MD
cheapest solution: lighten the truck
__________________ »»»»»...how'd the moon get there, how'd the moon get there? |
#4 |
92 xl
Well i have a flow master exhaust already. Cold air intake.and why put the chip back I n if the truck runs betterwith out it in.
#5 |
Belen, New Mexico
1994 XLT 4x4
I'm around 4500' here at the house and I regularly travel to Albuquerque which is the same elevation as Denver. Follow Roadrunners suggestion and disconnect the battery for 30 minutes or so. That'll cause the ECU to lose the learned operating parameters and force it to relearn new parameters at the higher altitude.
The reason it runs better with the octane shorting bar removed is because the truck is still using the learned fuel map, ignition timing, and everything else from the lower altitude. When you removed the shorting bar, you retarded the timing by 3°, so put it back then disconnect the battery cable for at least 30 mintues. Afterwards, when you reconnect the battery cable it can take up to 10 miles of varied driving (idling, slow acceleration, fast acceleration, cruising, etc.) to relearn new parameters. |
#6 |
Denver, CO
'92 Sport and AMG 300CE
Yeah man up here you will want to put that clip back on, when I was younger and dumper I pulled my clip off for a few months and the explorer gradually ran crappier and crappier, then reconnected it and the idle was so much better again! You might want to get a chip and when its being programmed let the programmer know your in high altitude mile high elevation. I learned that my ex ran best when it did idled over 1k rpms. Get a bigger throttle body if you can where you can adjust them.
__________________ 305/40r22 Nittos, KMC Rims, K&N, Granatelli MAF, BBK TB, Borla muffler & headers, Magnaflow Cat, 4" lift (Assorted Parts), 2 15" Eclipse Subs+Amps, 4.56 gear ratios, SCT 5 Program Chip, Warn Hubs, Paxton Supercharger SN2000, Port & Polished 95TM Heads+Lower Intake, 422 Cam, 30lbs Injectors, Snow Water Methanol Kit, Ready to Race!!! IF YOU GOTTA BE A MONKEY BE A GORILLA |
#7 |
92 xl
Yea I did put the clip back on.where would I get a larger throttle body at.and where would I find a chip and a tuner
#8 |
Michigan
'94 XLT 4x4
Turbo will solve all of your thin air problems. As a more practicle solution upgrade the MAF housing, not the sensor, with one from a 4.6L or 5.0L.
__________________ '94 Explorer XLT - Warn Manual Hubs, Pro Comp Trail lights and agressive tires, 4.6L MAF, Spectre cone filter, flowmaster exhaust '07 F150 - MBRP Exhaust, AEM Cold Air Intake '78 Nova - LSX engine, Ford 9" rear end, Custom roll cage and suspension 2012 Mustang Boss 302 - AM
#9 |
Denver, CO
good luck with turbo searching and all, cause you will really then need a chip and custom tuning then......
I believe there is a jet chip or tuner on sale in the for sale forum right now, and some times throttle bodys too! I don't know if you can get them new anymore but they pop up on ebay now and then too!!! __________________ 305/40r22 Nittos, KMC Rims, K&N, Granatelli MAF, BBK TB, Borla muffler & headers, Magnaflow Cat, 4" lift (Assorted Parts), 2 15" Eclipse Subs+Amps, 4.56 gear ratios, SCT 5 Program Chip, Warn Hubs, Paxton Supercharger SN2000, Port & Polished 95TM Heads+Lower Intake, 422 Cam, 30lbs Injectors, Snow Water Methanol Kit, Ready to Race!!! IF YOU GOTTA BE A MONKEY BE A GORILLA |
| Thread Tools | |
