Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
02 Mounty loud snap sound in front end when turning
Reply
Thread Tools
Old 06-13-2011, 07:57 AM   #1
LukeOmalley
connecticut
02 Mountaineer V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Dk Exp 02 Mounty loud snap sound in front end when turning
Team, I'm in a jam! I've had somewhat of a rubbing sound (rear I think) when pulling in & out of parking spaces or during K turns... Just recently i was pulling into a parking space turning left and a LOUD snap sound appeared to have come from the left front. the sound has now duplicated itself now when turning left & right... typically at slow speeds during hard not gradual turns...
Whats up? please advise...
Many Thanks!
Luke
LukeOmalley is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-13-2011, 09:15 AM   #2
LukeOmalley
connecticut
02 Mountaineer V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US
Also, the snap sound isn't as pronounced during gradual turns at moderate speeds... Anything that could help would be genuinely appreciated
Old 06-13-2011, 09:47 AM   #3
d.cheverie
Ontario
99 Explorer sport
Vehicle Specs
Quoted: 0 Post(s)
I have the same problem with my explorer, when pulling slowly into a parking space or whatever. Seems that if i do it faster it doesnt make the clunking sound. WTF could this be?
d.cheverie is offline   Reply With Quote
Old 06-13-2011, 10:35 AM   #4
joecrna
Las Flores, CA
98 XLT 4X4 sohc
Vehicle Specs
Quoted: 28 Post(s)
First thing is to check to see if you are stuck in 4 WD.
__________________
Joe
98 XLT 4X4 sohc
TT, Custom Deaver leafs, 31x10.5 BFG's
Custom skid plates, recovery shackles
Defender rack, Warn transformer mount
and winch
joecrna is offline   Reply With Quote
Old 06-13-2011, 10:47 AM   #5
LukeOmalley
connecticut
02 Mountaineer V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
thanks for the response.... My 02' Mounty isan AWD, 4.6L...
Old 06-13-2011, 10:52 AM   #6
joecrna
Las Flores, CA
98 XLT 4X4 sohc
Vehicle Specs
Quoted: 28 Post(s)
Yep, simply meant the center differential may not be allowing enough slip and sending near equal power to the front and rear. Binding is a common problem that causes the front end to pop while turning.
__________________
Joe
98 XLT 4X4 sohc
and winch
Old 06-13-2011, 11:12 AM   #7
LukeOmalley
connecticut
02 Mountaineer V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US
Sound appears to be Mechanical in that the noise is that of snapping metal
Old 06-14-2011, 01:12 PM   #8
d.cheverie
Ontario
99 Explorer sport
Vehicle Specs
Quoted: 0 Post(s)
how do i check if im stuck in 4wd? I have the selector switch on my dash, and that is in auto.
Old 06-16-2011, 08:24 PM   #9
LukeOmalley
connecticut
02 Mountaineer V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
joecrna, im going to find out tomorrow if the snap/pop sound goes away after i change my differential fluid. its probably a long shot, but if its the differential, what's the solution?
thanks!!!!!
Old 06-16-2011, 09:21 PM   #10
cross6
Baton Rouge, LA
2004 Mountaineer
Vehicle Specs
Quoted: 31 Post(s)
If you rule the 4wd out, then the pop/snap is from a ball joint. Check the upper/lower balljoints and the inner/outer tie rods.
cross6 is offline   Reply With Quote
Old 06-22-2011, 04:17 PM   #11
LukeOmalley
connecticut
02 Mountaineer V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
911 02 Mounty 4.6L AWD
The crack/snap/clunk/pop sound is even worse after changing the diff fluids... How do I know if my AWD is screwed up and is destroying something and if it is, what am I looking at? This guys at a shop said its probably my transfer case. What the heck is it? and how do i get the car to quiet down???
My left front bearing is roaring, I hear a loud crack/snap/clunk/pop sound from the Left Front when turning, and now when pulling forward from a dead stop. My car binds up at slow speeds when cold, and its worse after the car has bee driven on a highway at high sppeds and then i try to negotiate parking lots at slow speeds. Hey when pulling into a parking spot the rubbing/binding is extreme.... So what do I need to do? Please help
Old 06-24-2011, 06:34 PM   #12
LukeOmalley
connecticut
02 Mountaineer V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Apparently & according to a shop I dropped my 02 AWD 4.6 mounty off to I had a bunch of subframe bolts loose causing my differential to shift. I'm out of town so I haven't picked up my ride yet but they torqued them to spec and test drove my Mounty and the noise is supposedly gone... I'll find out tomorrow, but is this possible? They apparently located the source by placing electronic chasis ears on the frame and test drove the Mounty duplicating the problem. They were then able to pinpoint and isolate the source. The first thing they did was install an upper control arm. The sounds remained then they noticed the loose bolts... Thoughts?
Old 06-24-2011, 06:42 PM   #13
Ronin8002
Virginia
2008 XLT Ironman
Vehicle Specs
Quoted: 127 Post(s)
Kinda makes sense. The front diff is held on by 3 bolts and if those were to get loose I think it could be shifted around on an AWD during the conditions you described resulting in noise. Post up if their repair fixed the problem.
Ronin8002 is offline   Reply With Quote
Old 06-24-2011, 07:02 PM   #14
LukeOmalley
connecticut
02 Mountaineer V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US
Ronin8002, I've been waiting for you BigRondo & BrooklynBay to chime in. You guys have genuinely helped me in the past and I do appreciate it! I'll keep you and the rest posted. Could I have screwed anything up by having the bolts loose and driving a few hundred miles? I do have a roaring FL wheel bearing so I'm going to order a replacement and jump on that soon. Do I get one from PC or do you recommend another & should I do both front hub assemblies? Thanks!
Old 06-25-2011, 09:42 AM   #15
stuartr
Richlands, VA
2002 Mercury Mountaineer
Vehicle Specs
Quoted: 1 Post(s)
Check out autoparts123.com for the bearing. I saved a bunch on my rear bearings there.
STU
__________________
Mountianeer family I have a 2002 and she has a 2008. Both AWD V6.
stuartr is online now   Reply With Quote
Old 06-27-2011, 12:52 PM   #16
Ronin8002
Virginia
2008 XLT Ironman
Vehicle Specs
Quoted: 127 Post(s)
Quote:
Up to you on replacing one or both hubs. If it were my I'd just replace both for peace of mind, but if money is an issue, then just replace the bad one.
As far as the front diff hard to say if it damaged anything. Guess I'd just have the mounting points tightened up and see how it goes after that...."cross that bridge if/when you get there" and all that.
Old 06-27-2011, 09:28 PM   #17
LukeOmalley
connecticut
02 Mountaineer V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
keep you all posted. Got my Mounty this morning and all is quiet except for my LF wheelbearing. I fix that in a few...
Old 06-27-2011, 09:57 PM   #18
jleehoyle567
LENOIR, NC
2003 MOUNTAINEER
Vehicle Specs
Quoted: 0 Post(s)
i have a similar problem with my 03 awd 4.6 mounty. the difference is that mine popped while in forward motion on the highway. the faster i went the louder it got. i changed my cv axles in the front but the problem was still there. the only way i could get it to stop was to remove my front driveshaft. the noise stopped. makes me think that i have something binding in the front diff or transfer case. no one has been able to give any advise so i will welcome all suggestions
jleehoyle567 is offline   Reply With Quote
Old 06-27-2011, 10:39 PM   #19
2004Merc
Vehicle Specs
Quoted: 0 Post(s)
popping noise
I have the same issue too with a clanking/ popping sound when I turn out from a parking spot, make a u-turn, and backing up into/out of a parking spot while turning. Sounds and feels like its coming from the left side under my foot.
Truck feels like its binding on something and I have to get on the gas to keep it moving backwards. Its been like this for about a year now......
2004Merc is offline   Reply With Quote
Old 06-28-2011, 01:33 AM   #20
351mustang65
04 Mountaineer premier
Vehicle Specs
Quoted: 0 Post(s)
I to get the rubbing sound but I don't think there is any popping.
__________________
Had a 1997 EX XLT 4.0 4X4 that took a bump . It will buff out right?
http://s888.photobucket.com/albums/ac84/MustBass/
2002 Mountaineer AWD 4.6 sold
2004 Mountaineer premier AWD 4.6 with 3.73 gears and 3 12's in the back.
351mustang65 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
