#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
2003 Explorer. Window problems.
Reply
Thread Tools
Old 06-13-2011, 10:58 PM   #1
tbone51merc
N Idaho
2003
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Dk Exp 2003 Explorer. Window problems.
Hello, I am new to the site and am happy to be hear. I have a 2003 Ford Explorer AWD. Last year around October I rolled my electric windows down in front and could not get them working again? I pulled the door panel on the drivers door and checked for power at the switch and did not find any power. I have power to the door locks and they work fine. I replaced just about any and all fuses that I could find but no change. I am at a total loss. I read some of the forums and the only thing that I could figure is the ground to the door but I could not find a ground. Any help with this I would greatly appreciate. I thank you for your time. Tom in N Idaho.
tbone51merc is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-14-2011, 06:32 PM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! I've moved your thread into the stock 2002-2005 section. Check the wiring between the door, and the frame.
BrooklynBay is offline   Reply With Quote
Old 06-14-2011, 10:16 PM   #3
therover1991
Queens, New York
02 XLT
Vehicle Specs
Quoted: 2 Post(s)
Quote:
Check the rubber boot between the door and frame, and see if there is a broken ground wire.
__________________
2002 Ford Explorer XLT 4.0L V6 4x4 SOLD
2005 Ford Freestyle Limited 3.0L V6 AWD
2013 Ford Focus SE Black Appearance Package
2014 Ford Explorer Sport 401A Package
therover1991 is offline   Reply With Quote
Old 06-15-2011, 11:35 AM   #4
tbone51merc
N Idaho
2003
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
2003 window problems
Thanks for the reply, I will check the boot.
Old 06-16-2011, 06:43 PM   #5
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Welcome aboard!
I had similar electrical issues with my 02 xlt. The dome lights would stay on until the battery saver feature turned them off, the driver side puddle light didn't work, the keypad on the door would set off the alarm when I pressed it, the door ajar light would flash and beep at highway speeds, the radio would shut off as soon as I turned the key off, etc. Most recently all 4 windows stopped working.
A lot of electrical issues can be traced back to broken/damaged wire(s) in the boot between the body and the driver's door. I found 2 broken wires and repaired them. The thin black ground wire was broken and after repairing it all was back to normal. When the windows stopped working, I repaired the thick black ground wire and the windows now work like a champ.
Here is the thread for removing the door panel: http://www.explorerforum.com/forums/...d.php?t=303524
Here is a great thread for checking for broken/damaged wires, thanks to synyster for this awesome write-up: http://www.explorerforum.com/forums/...d.php?t=270081
Be sure to take your time when looking for broken/damaged wire(s). Check all the wires for breaks/damage. When you think you're done looking, look again, and again, and again. A bright flashlight can be very helpful.
If all else fails, here is a great link for troubleshooting the power windows, thanks to theofam for this great link http://www.scribd.com/doc/14896086/2...stem-Diagnosis
Hope this helps out!
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is offline   Reply With Quote
Old 06-19-2011, 11:34 PM   #6
tbone51merc
N Idaho
2003
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
03 window problems
I thank you BigRondo. I will check the boot and I appreciate all the info. I will check back in after I do my inspection of the door boot. Thanks again. tbone51merc
Old 06-19-2011, 11:38 PM   #7
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Good luck. Hopefully you can get it fixed without too much trouble!
__________________
Old 07-12-2011, 12:43 AM   #8
tbone51merc
N Idaho
2003
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thumbs up Window problems
I have to thank you again BigRondo. You were correct on the broken wires in the drivers door boot. I had two main wires that went to my main window control that had been pinched in two. Windows work fine again after reconnecting them. Thanks again and I hope to return the favor some day. Take care.
TBone
Old 07-12-2011, 09:58 AM   #9
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 380 Post(s)
Thanks for the update! I figured that this was the problem in post # 2.
Old 07-13-2011, 09:59 AM   #10
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
NIce work! Glad you were able to get it fixed. It's nice when stuff works outQ
__________________
Old 09-10-2011, 09:20 PM   #11
jq0311
PA
2003 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
Hello Gents!
I am a new user and appreciate the Great insights. I have followed the advice about checking the wires in the boot and found what I thought was the answer to my window problems. It turns out that after fixing the broken blue with black striped wire that it only allows me to lower the front windows and only using the driver switch. None of the other switches work and the rear window still don't go down.
What could be the problem with the other switches? And why don't the rear windows work when I had no issues with the window before they suddenly stopped working?
P.S. Rondo... nice to see another Marine out there! I served from 2006-2010 with 2/8,
jq0311 is offline   Reply With Quote
Old 09-11-2011, 01:21 PM   #12
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Quote:
Originally Posted by jq0311 View Post
Hello Gents!
Thank you for your service! I spent some time at Camp Lejeune, I believe that's where 2/8 is headquartered? Engineer School out at Courthouse Bay & 8th Engineer Support Battalion at French Creek.
Here is a great link for troubleshooting the power windows, thanks to theofam for this great link http://www.scribd.com/doc/14896086/2...stem-Diagnosis
__________________
Old 12-29-2011, 08:54 AM   #13
Nakoa
Everett, PA
2003 Explorer
Vehicle Specs
Quoted: 0 Post(s)
Great Thread.
Been putting off fixing the Door Ajar prblem for awhile now... (About 5 years. LOL) However I will now look into it. Also recently had all the windows quit working which is my new motivation. Now if I could get the gas gauge to work all the time time, sntead of when it wants to, and the ABS light to either come on or stay off, not come on once a week. Any Ideas?
Nakoa is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
