#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
Help: Upgrading Warn Borg 4412
Reply
Thread Tools
Old 06-17-2011, 06:36 AM   #1
The Electrician
Makkah
2008 XLT 4WD V6
Vehicle Specs
Quoted: 9 Post(s)
(Original Poster)
Hi every one
Is there a way to beef up WB4412 transfer case?
Stronger clutches?
Higher gear ratio?
Stronger magnetic coupling?
Stronger driving chain?
Transfer-case oil cooler?
can I swap it (direct bolt on) with gear driven transfer case? (I like the electric shift and computerized control and I don't want to loose it)
any help?
with all gratidudes
__________________
- Allaa' -
Basic Off-Road Techniques
2008 Explorer XLT 4WD V6 - Lifted & Loaded
2000 Crown Victoria P71: 4.6 PI Engine Swap, MZT, 70mm TB, P&P Plenum, Steeda UDP, J-Mod, B&M Trans Deep-Pan, External Trans Oil filter, BOC Tuning
The Electrician is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-17-2011, 10:18 AM   #2
Ronin8002
Virginia
2008 XLT Ironman
Vehicle Specs
Quoted: 125 Post(s)
A good place to start might be to search for the kinds of mechanical failures people experience with these transfer cases, then plan your upgrades to address those failures.
I don't recall hearing very much about mechanical problems with these transfer cases, however, so perhaps it is strong enough for the application.
Ronin8002 is offline   Reply With Quote
Old 06-17-2011, 01:41 PM   #3
The Electrician
Makkah
2008 XLT 4WD V6
Vehicle Specs
Quoted: 9 Post(s)
(Original Poster)
the problem I had with WB4412 is burned clutches, because there is no oil cooler for the transfer case
also i would like have higher transfer case ratio
__________________
- Allaa' -
Old 06-17-2011, 02:01 PM   #4
Ronin8002
Virginia
2008 XLT Ironman
Vehicle Specs
Quoted: 125 Post(s)
Not sure on the solution for the ratio.
As far as the cooling, perhaps you should try replacing the transfer case lubricant (Mercon) witha high quality synthetic fluid such as Amsoil Torque-Drive. Torque-Drive is supposed to be very resistant to high temperatures and may help to provide better protection in your climate.
Old 06-17-2011, 04:09 PM   #5
The Electrician
Makkah
2008 XLT 4WD V6
Vehicle Specs
Quoted: 9 Post(s)
(Original Poster)
I did this already after replacing the clutches, I'm using Mecron V
but still the oil reach a high temperature, which still threatening the clutches
__________________
- Allaa' -
Old 06-17-2011, 04:55 PM   #6
Ronin8002
Virginia
2008 XLT Ironman
Vehicle Specs
Quoted: 125 Post(s)
I think that the Torque-Drive fluid is said to hold up better in higher temperatures and provide better protection for things like clutches. Might be worth a try. I don't know how you would route the fluid to a cooler and back unless there is a pumping mechanism in the transfer case.
Old 06-17-2011, 05:15 PM   #7
The Electrician
Makkah
2008 XLT 4WD V6
Vehicle Specs
Quoted: 9 Post(s)
(Original Poster)
there is an oil pump, but not sure if the pump can deliver enough pressure to push the oil through a cooling loop.
also I'm not sure, but because I was in lack off torque before re-gearing the axles. I was abusing the low range (driving in low range up to 55mph for long distance)
was this the cause of high temp and burned clutches?
__________________
- Allaa' -
Old 06-17-2011, 05:21 PM   #8
Ronin8002
Virginia
2008 XLT Ironman
Vehicle Specs
Quoted: 125 Post(s)
It is possible that abusing the low range led to your issue. I am also assuming that the ambient temperatures your transfer case is exposed to lead to a faster than normal degradation of the fluid and less protection for the moving parts. Hence, my suggestion to use a fluid that is rated for high temperatures and that exceeds the Mercon V in that area.
I have been looking for specific comparisons between the two but if you contact the techs at Amsoil they could probably give you that information.
I just used the vehicle search function on their site and the Torque-Drive was one of the options. An email to them would help you identify the best product of theirs to use for your application.
Old 06-17-2011, 07:01 PM   #9
The Electrician
Makkah
2008 XLT 4WD V6
Vehicle Specs
Quoted: 9 Post(s)
(Original Poster)
I've check and found that:
AMSOIL Torque-Drive® Synthetic Automatic Transmission Fluid Product Code: ATD1G-EA
Is recommended for use in applications specifying:
  • Allison®
  • TES-295 or C4
  • DEXRON® III
  • MERCON®
  • Voith G-1363
  • ZF®
  • TE-ML 14C
While MERCON V® exceed MERCON®
on the other hand
AMSOIL Synthetic Multi-Vehicle Automatic Transmission Fluid Product Code: ATFQT-EA
Is recommended for transmissions, hydraulics, power steering and other applications requiring any of the following specifications:
  • GM DEXRON® III-H
  • Ford MERCON® & MERCON V®
  • Chrysler ATF+4®
  • Toyota Type T-III and T-IV
  • Honda Z-1 (Not CVT)
  • Diamond SP II & III (Mitsubishi/Hyundai/Kia)
  • Mazda ATF-III, ATF-MV
  • Subaru ATF, ATF-HP
  • Nissan Matic D, J & K
  • Idemitsu K-17
  • BMW LA2634
  • LT 71141
  • Audi G-052-025-A2 & G-052-162-A1
  • Volvo 97340
  • MB 236.1, 236.2, 236.5, 236.6, 236.7, 236.9 & 236.10
  • JWS 3309
  • NAG 1
  • ETL-7045E, ETL-8072B & N402
  • Voith 55.6335.XX (G607, G1363)
  • ZF TE-ML 03D, 04D, 09, 14A, 14B, 14C, 16L, 17C
  • Allison C-4, TES 389
  • Mopar AS68RC
Note: Not for use with CVT or Ford Type F applications.
__________________
- Allaa' -
Old 06-17-2011, 07:19 PM   #10
The Electrician
Makkah
2008 XLT 4WD V6
Vehicle Specs
Quoted: 9 Post(s)
(Original Poster)
from the above I choose to use MOTORCRAFT Synthetic Automatic Transmission Fluid MERCON V® because it is engineered by ford with official ford approval and certification
__________________
- Allaa' -
Old 06-17-2011, 07:46 PM   #11
Ronin8002
Virginia
2008 XLT Ironman
Vehicle Specs
Quoted: 125 Post(s)
Can't go too wrong with the manufacturer recommended fluids then.
I'd say just be careful about going too fast in low range and see what happens.
Old 06-17-2011, 07:51 PM   #12
Ronin8002
Virginia
2008 XLT Ironman
Vehicle Specs
Quoted: 125 Post(s)
Interesting. My 2004 manual states to use MERCON in the transfer case and MERCON V in the transmission. So the torque-drive fluid would be compatible.
EDIT: It looks like your 2006 manual says the same thing.
Old 06-17-2011, 08:44 PM   #13
The Electrician
Makkah
2008 XLT 4WD V6
Vehicle Specs
Quoted: 9 Post(s)
(Original Poster)
true but for better protection, I used MERCON V in both transmission and transfer case and hoping for best
after re-gearing and dyno tuning I have enough torque to to wheel in 4H (through very soft and thick sand similar to wheel through mud) and I don't abuse 4L like before
hope this will prevent the pervious issue
__________________
- Allaa' -
Old 06-17-2011, 08:52 PM   #14
Glen4X4
Lewistown, Pa
2000 XLS
Vehicle Specs
Quoted: 3 Post(s)
Ok as far as making the clutches stronger, not sure there is actually a solution to this, that's the reason 2nd gen owners swapped to the old fashioned manual version. You may want to examine your extension housing and compare it to that of a 91-01 and if it is similar and you want the electric shift you could add a t-case from a 1st gen Explorer since it has a stand alone unit for the 4wd shifting. Just an idea throwing out to you as its gear driven and no worries of burning up the t-case. Never seen you're tail housing to see if this is possible or not.
__________________
96 Explorer XLT Gone
03 Silverado 1500 LS 4X4
00 Subaru Outback Limited SDN
Glen4X4 is offline   Reply With Quote
Old 06-18-2011, 08:18 AM   #15
The Electrician
Makkah
2008 XLT 4WD V6
Vehicle Specs
Quoted: 9 Post(s)
(Original Poster)
to do this I think I need to change the transmission
here is the transmission tail
and here is the transfer case
__________________
- Allaa' -
Old 06-18-2011, 08:51 AM   #16
Glen4X4
Lewistown, Pa
2000 XLS
Vehicle Specs
Quoted: 3 Post(s)
Oh ok....that's quite different....guess that option is out.....
__________________
Old 09-26-2012, 06:55 PM   #17
Sport Trac 08
'13 Toyota Tacoma
Vehicle Specs
Quoted: 1 Post(s)
Bw 4412
Allaa'
Did you ever get anywhere with the transfer case upgrade? I am currently running a re-manufactured unit after the original broke a chain and cracked the housing. Now I'm having intermittent trouble shifting from 4LO to 4HI. Could be an electronics issue, but I'd consider going to a cable-shifter, old-school. Did you discover what we can replace the 4412 with? Atlas doesn't appear to have an application for us...
Sport Trac 08 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
