Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Body Swap Vs Engine swap
Reply
Thread Tools
Old 06-18-2011, 01:09 AM   #1
tycmills3
Lincoln, NE
97 AWD V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I am in need of advice.
I got a 97 explorer v8 awd (rebuilding the tranny and engine) it needs new fenders up front and hood, also needs doors fixed.
And ive got a 98 sohc bad motor but body is perfect.
Which is going to be the best route?
Swap the v8 and the tranny and transfer case? or swap the bodies?
tycmills3 is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-18-2011, 03:30 AM   #2
StryctNy9e
Beaverton OR/ hayward CA
1993 XLT Exploder
Vehicle Specs
Quoted: 0 Post(s)
I would say it would be easyier to swap the engines, but I dont know how much needs to be swapped. Like do you have to swap full wiring harness and re wire all electrical. I have not done the research but it sounds like the engine swap would be the way to go. GOOD LUCK
Or take the doors, hoof, fenders off the 98 and put them on the 97, might be missmatched colors, but that is just more of a reason to learn how to paint, or have her painted.
__________________
Stryctny9e's 1993 Ford Exploder XLT
on the menu.... Snorkel...Gauges.... Rhino line roof....Manual Hubs 32x11.50 M/T
http://www.explorerforum.com/forums/...d.php?t=313060
StryctNy9e is offline   Reply With Quote
Old 06-18-2011, 06:07 AM   #3
boominXplorer
Elite Ranger
Virginia Beach, Va
boominXplorer's Avatar
00 4x4 Mounty
Vehicle Specs
Quoted: 191 Post(s)
Do you have titles to both vehicles and do you have a shop w/lift to work in? If yes to both questions I would do the body swap. With a lift I could do it in a day.
If your at home with some good tools and engine lift you might as well stick to swapping drivetrain. Its alot more work this way but its doable.
__________________
2002 F250 Crew Cab SB 7.3 Diesel 4x4 - 4" MBRP exhaust, AIH delete, SCT Livewire
2001 Ranger ext cab 4x4 - 5.0 swap, FMS headers, 4406, 4.88s, 5" lift with Coilovers, 3" body running 315/75/16 MTZs
2007 Ford Focus ST Black - FS Intake, SVT brakes F&R, Fiesta ST 17s
My eBay auctions
boominXplorer is online now   Reply With Quote
Old 06-18-2011, 07:49 PM   #4
maeistero
Wichita, KS
'96 Bauer
Vehicle Specs
Quoted: 0 Post(s)
I'm with the motor swap, easy if you can do the electric. BUT, also consider the title, is it salvage? resale thoughts....
maeistero is offline   Reply With Quote
Old 06-19-2011, 01:34 AM   #5
tycmills3
Lincoln, NE
97 AWD V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i got both titles both are clear, and yes i have acces to a lift. If body swap, what all needs to be done to lift the body? (Steering linkage wise)
Old 06-24-2011, 12:01 AM   #6
tycmills3
Lincoln, NE
97 AWD V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
anyone ever done a body swap?
Old 06-24-2011, 06:01 AM   #7
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Vehicle Specs
Quoted: 191 Post(s)
Yeah Section525 has. Well he did a frame/drivetrain swap.
You undo the top steering linkage at the bolt where it goes into the fire wall.
Make sure you get all the wire connectors undone, there are a few ground straps to find also.
Brake lines from ABS pump, Parking brake cable, A/C lines from compressor, throttle and shift linkage.
I am sure I am missing something but undo the body bolts and then lift the body off the frame with the lift and roll the frame out. Then you just have to figure out how to move the body off the lift and do the same thing to the other truck.
__________________
My eBay auctions
Old 06-24-2011, 07:25 AM   #8
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 699 Post(s)
I would get the body off the donor frame first and start selling stuff off it to get some $$ flowing.
Then prep the frame good, and while it is all opened up do the routine hard to get to maintenance.
This way it is ready to roll under the good body once it is up in the air. The old body can lay on the ground.
If you try to lift the good body first, you will end up with 2 truck bodies in the air
__________________
Jon
9 mile skid, on a ten mile ride. Hot as a pistol but cool inside.
2000 Mountaineer
1998 Mountaineer "Turdle"-gone
1993 Convertible "Vitamin D Wagon" Sold also
Turdle is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
