#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Battery died--now alarm keeps going off...
Reply
Thread Tools
Old 06-26-2011, 02:06 PM   #1
cngizbleevng
Boiling Springs, PA
'03 XLT 4.0 Flex
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
Red face Battery died--now alarm keeps going off...
A couple weeks ago the dome light was left on and my wife's explorer's battery died. I recharged it, but ever since then the alarm will go off sporadically for no apparent reason. We have to leave the car unlocked to avoid the alarm sounding, which is pretty inconvenient.
I tried the search, but couldn't get it narrowed down to my problem.
Has anyone else experienced this and is there a fix? Thanks.
cngizbleevng is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-26-2011, 04:10 PM   #2
SeekerFor
2003 Ford explorer Eddie
Vehicle Specs
Quoted: 2 Post(s)
Hi
My alarm would go off at 4 am in the morning to the point where I started to leave it unlocked.
However after reading the manual found that if you hit the fob lock button and it beeps twice than there is an open switch (one of the doors open).
So now i just single lock it without putting the alarm on.
Sent it for a tune up and now it beeps once and the alarm no longer goes off waking up the neighbors.
SeekerFor is offline   Reply With Quote
Old 06-27-2011, 09:34 AM   #3
jad2411
El Paso, TX
blue 02 xlt & white 02xls
Vehicle Specs
Quoted: 1 Post(s)
Seems odd that the battery would die from the dome light, on mine it turns off by itself after a while, thought that was the batt saver feature....
But yeah most likely, you have a bad switch, spray wd40 on all 5 locks hopefully that'll fix it
__________________
If interior is to exterior and
include is to exclude, then
increment is to:
jad2411 is offline   Reply With Quote
Old 06-27-2011, 09:38 AM   #4
PEAR0119
Ottawa, Ontario
2006 Explorer XLT 4.0 4x4
Vehicle Specs
Quoted: 2 Post(s)
Yeah, I left the glove box open and the light on for 48 hours and she started right up when it came time to go to work. This was also in -30 Celsius weather at that. I will admit though it was a brand new battery.
__________________
2006 Explorer XLT V6 4x4 --> mine
2005 Mustang GT --> mine
2003 Explorer limited 100th anniversary 4.6L 4x4 --> Dads
2009 Expedition Limited 5.4L 3V 4x4 --> Dads
PEAR0119 is offline   Reply With Quote
Old 06-27-2011, 09:49 AM   #5
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
I had similar electrical issues with my 02 xlt. The dome lights would stay on until the battery saver feature turned them off, the accessory delay wasn't working, the driver side puddle light didn't work, the keypad on the door would set off the alarm when I pressed it, the door ajar light would flash and beep at highway speeds, the radio would shut off as soon as I turned the key off, etc. Most recently all 4 windows stopped working.
A lot of electrical issues can be traced back to broken/damaged wire(s) in the boot between the body and the driver's door. I found 2 broken wires and repaired them. The thin black ground wire was broken and after repairing it all was back to normal. When the windows stopped working, I repaired the thick black ground wire and the windows now work like a champ.
Could also be related to the door ajar switch.
Here is the thread for removing the door panel: http://www.explorerforum.com/forums/...d.php?t=303524
Here is a great thread for checking/replacing the door ajar switch, thanks to borland for the awesome write-up: http://www.explorerforum.com/forums/...d.php?t=249253
Quote:
Originally Posted by thepotroast View Post
That is a great write up.
On a side note, before going through a complete replacement of the switch, you can spray WD40 into the door latch opening on each door, as these become stuck sometimes....and this can alleviate the issue.
This worked for me, after going for more than a year of the "door ajar" light coming on occasionally...mainly after a car wash, high humidity, or rain....making me unable to lock/arm the vehicle from the door keypad and keeping the dome lights on. Worth a try....it worked for me
Here is a great thread for checking for broken/damaged wires, thanks to synyster for this awesome write-up: http://www.explorerforum.com/forums/...d.php?t=270081
Be sure to take your time when looking for broken/damaged wire(s). Check all the wires for breaks/damage. When you think you're done looking, look again, and again, and again. A bright flashlight can be very helpful.
Good luck with the fix and be sure to keep us posted!
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
