Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Flywheel scraping noise.
Reply
Thread Tools
Old 07-09-2011, 03:49 PM   #1
terrymac
lovettsville va
1995 xlt
Vehicle Specs
(Original Poster)
US Flywheel scraping noise.
Hi, I just replaced the starter after hearind a scraping noise that started a week earlier. The new starter seemed to eliminate the noise totally for three or four days then it stareted scraping again but three times louder than usual. Does it about every 5th startup or so.
I'd appreciate some feedback. Thanks!
terrymac is offline   Reply With Quote
Old 07-12-2011, 10:22 PM   #2
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Welcome to this forum! I've moved your thread into the stock 95-01 section. Your crankshaft to flexplate spacer might be cracked.
BrooklynBay is offline   Reply With Quote
Old 08-01-2012, 10:02 PM   #3
2009KVFD976
Kaufman, TX
2001 Ford Explorer
Vehicle Specs
Im having almost the same problem. but mine makes a knocking sound when its idling. i got under it with a pc of hose and checked under oil pan and trans pan, its right in between motor and trans.. Any ideas?
2009KVFD976 is offline   Reply With Quote
Old 08-01-2012, 10:12 PM   #4
deweyville65
Dewey,Az
96 EXPLORER XLT
Vehicle Specs
Terrymac, just what do you mean by "scraping sound"? First check the bolts for being tight.
2009KVFD976, sounds like you have a cracked flexplate.
deweyville65 is online now   Reply With Quote
Old 08-02-2012, 12:36 AM   #5
2009KVFD976
Kaufman, TX
2001 Ford Explorer
Vehicle Specs
Thanks for the reply!! I just put a tranny in it mid feb.. How does the flexplate crack?? It has about 165k mi on it. Is it just old or was something done wrong?
Old 08-02-2012, 08:37 AM   #6
deweyville65
Dewey,Az
96 EXPLORER XLT
Vehicle Specs
Tough to say what causes the flexplate to crack. Could have been a misalignment when you reinstalled the torgue convertor. Tightened bolts all at once instead of crisscross pattern, age fatigue, defect when stamped at factory, hard to say. I had a Chevy p/u that cracked two flexplates within just a few months. That was 30 years ago, so I dont remember the cause. And, that may not be whats wrong, but thats where I would look.
Old 08-02-2012, 09:20 AM   #7
BrooklynBay
Brooklyn, NY
Vehicle Specs
The Ford powdered iron spacers are brittle, and eventually crack. Get a Sonnax billet steel spacer.
Old 08-03-2012, 07:43 PM   #8
2009KVFD976
Kaufman, TX
2001 Ford Explorer
Vehicle Specs
Got under it and took starter out today. turns out torque converter nuts came loose. noise is gone...
Reply
Tags
flywheel, starter
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
