| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Modified 1991-1994 Explorers Questions concerning modifications to the 1991-1994 Explorer, Mountaineer, Ranger and Navajo. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Kennesaw ga
1994 limited
94 limited build
I decided to start a build thread and list all the costs to date.
I still have no name for her yet, But i think I got a semi unique idea for it's design. 94 limited( with bad passenger side bearings) $200 + a 1980 bmw with a blown transmission. ![]() It looks like everything on this is factory issue. $160 to replace the rotors brake pads and calipers on the front disk brakes. $70 f150 leaf springs $65 front coils from LBarr2002 $13 rattle can paint job for the red door. __________________ 94 limited Last edited by Spicycook; 07-12-2011 at 03:19 PM. |
#2 |
Kennesaw ga
1994 limited
my suspension lift
jamscal rear bumpers jamscal winch bumpers Shock mount air intake radiator flush http://www.explorerforum.com/forums/...d.php?t=287596 http://www.explorerforum.com/forums/...r+bucket+seats __________________ 94 limited Last edited by Spicycook; 07-30-2011 at 12:10 AM. |
#3 |
Kennesaw ga
1994 limited
Future plans:
Fan blade and clutch---done trans flush----done fuel filter---done oil change----done serpentine belt---done Radiator clean out---done Head lights-----done New bumpers---done 2nd gen 4.10 rear end trans filter Cat converter Spark plugs and wire set replace current trans cooler for a larger one Alternator HO New battery Longer battery cables Front knuckle swap Rear locker Warrior Shackles F150 coil seats F250 shock mounts. New shocks Air intake Front driver and passenger window motor and door locks (price check, maybe just new doors?) front seats from a 2nd gen 15x8 32's roof rack __________________ 94 limited Last edited by Spicycook; 10-12-2011 at 01:35 PM. |
#4 |
Greensboro, NC
93 ExElTee
nice plans. Stickin with a 2" lift? those bumpers will probably negate some of that and lower your truck.
#5 |
Kennesaw ga
1994 limited
I'm still debating, but I do want to go a little higher to compensate for the bumper weight.
I think that will make her a good trail vehicle for when I go camping/shooting as well as still being road worthy enough mpg wise when I need a dd or towing. __________________ 94 limited |
#6 |
Kennesaw ga
1994 limited
So I needed to replace the brakes on my ex, they were looking worn down and the fluid looked way to dark. I think when i took it in to get it's oil changed by a "walmart pro" they thought my master brake cylinder was something else.
Here's what came out of my lines. ![]() The lines have now been flushed and new fluid put in. __________________ 94 limited |
#7 |
Lake Elsinore California
94 EB
Do you guys know about how much those bumpers weigh?
#8 |
94 EB
Also spicy.....what year f150 did you snag those leafs from?
#9 |
Kennesaw ga
1994 limited
For one of Jamscal bumpers? 70lbs for the basic model.
As for the leaf springs it was a 1990 f150 with a 3800lb rear gawr. __________________ 94 limited |
#10 |
Kennesaw ga
1994 limited
Took a trip up to Kentucky and back in one day. I got pretty decent mileage going 65-70 with cruise control I got roughly 20mpg. Over all pretty impressed with the mileage.
My city mileage still sucks but that could be the 1/2 hour or more I have to spend circling parking decks on campus to find a spot. Got some new bumpers to put on and then re-check my suspension and see how much of a change it made and then get that alignment I've been putting off done. alignment done. Also the truck has now been painted so I no longer have the red and green look. once the bumpers are painted I'll put them on and take some pics. edit: No noticeable difference in lift on the front end. pics ![]()
__________________ 94 limited Last edited by Spicycook; 09-10-2011 at 01:14 PM. |
#11 |
Kennesaw ga
1994 limited
So over the past few months I've been having issues with vibration while driving. After trying several different things it has turned out to be the roof rack. After removing the rear cross member the vibration has been reduced by 75%. Once I get the camber on my wheels adjusted I figure it should almost disappear.
#12 |
Kennesaw ga
1994 limited
It's a sad day for my explorer. She started having loss of power in the middle of stop and go traffic and discovered she was bleeding transmission fluid all over 75N. Was able to pulled over though and get it towed home. I'll have to check when it's light out and see what happened. Crossing fingers hoping it's just a blown seal or hose.
If not I may have to sell off my jamscal bumpers to pay for a new transmission. __________________ 94 limited |
#13 |
memphis, tn
'92 XLT
That bites man, sorry. Happened to me too a while back, 5 speed though.
__________________ 2001 4x4 Sport Trac. it's new to me, so no mods yet. 1992 XLT 4 door 4WD: 32s on 17" Mustang GT rims, 4.56 w/ modified LS in rear, 2.5" lift from F150 coil springs, F250 shock mounts, shackles, Pro comp shocks, hard way rear disc conversion, Ported and polished intake, Dynomax exhaust, e-fan, + other mods I've done since this edit. (Switches, Black,) |
#14 |
Denver Colorado
'93 Explorer XLT
Ouch! I'm so sorry, any news yet?
#15 |
Knoxville, TN
98 Mountaineer A4WD
Modulator valve bad, check the vacuum line coming up from the trans?
__________________ Don 91 Lincoln LSC/SE, 99/93 Explorer Limited 4WD, 98 AWD Mounty with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors. Soon a BW4406, built trans, stereo and interior. The best thing that could help us all, is the Fair Tax Plan. Be American, Buy American (Manufacturer)
#16 |
Kennesaw ga
1994 limited
Kinda, haven't had much chance to look it over yet but the fluid that came out was still nice and red. No burnt smell and the loss of acceleration was rather sudden with no standard signs of transmission failure. This morning before work I added two quarts to see if would leak via gravity on to cardboard while I was gone. But the cardboard was clean when I got home. So I'm hoping at this point that It will be something cheaper than a new transmission. My dad will be coming down Saturday and I'll have a set of eyes on the engine when I start it and move through the gears to see if we can locate the source of the leak since it only seems to appear while running. __________________ 94 limited |
#17 |
Denver Colorado
'93 Explorer XLT
Cool! keep us posted.
#18 |
Middle GA
91 Mazda Navajo
I Would like to Have your Front if you decide to sell , I'm In Ga and can pick up too , Also any other explorer related parts and Etc If You do not want or need Ill Take ! , Good Luck With The Trans , I have Had a Hard Time With 2 Going Bad On My Navajo !
__________________ 1999-Exdpedition Xlt 4.6 Silver-Grey- OIL LEAKING .haha ZAPV#161, 91 Navajo, 3" Bodylift , 2.5"skyjacker coils,skyjacker shocks , 2" ext shackels, . home made CAI.no muffler's straight cat's ,warn locking hub's,throttle cable mod ,deleted rear swaybar , front sway bar disco's ,custom cut front bumper ,deleted front fender flare's ,clear turn's ,clear tail's,33" Pro Comp AT's 1953 Ford F-100 Restoration Project |
#19 |
Knoxville, TN
98 Mountaineer A4WD
Check the vacuum line for ATF in it. The modulator valve is a well know part to fail and cause a leak or have ATF pulled into the engine. Check it, it's easy.
#20 |
Kennesaw ga
1994 limited
I have a front passenger door just lying around. It's in good condition except for the missing wiring harness for all the auto features.
| Thread Tools | |
