Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
1994 Ford Explorer. Ignition key cylinder replacement.
Reply
Thread Tools
Old 07-20-2011, 12:28 PM   #1
GPTRealty
Houston, TX
1994 Ford Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US 1994 Ford Explorer. Ignition key cylinder replacement.
I was wondering if anyone has endeavored to remove and replace a bad key cylinder in a Ford Explorer. It is a V6, XLT, no air bags, does have a security system. I had 5 or 6 keys and now only one will fit the ignition. Pretty sure it needs a new cylinder which I bought at Advanced Auto Parts. I have a steering wheel puller. In reading some other literature on newer autos it makes me fear trying to do it myself. Maybe the older 94 Ford is easier. If anyone has removed and replaced a cylinder in a 94 Explorer any advice or tips would be appreciated. Would you recommending trying it or just letting an auto service company do it for me??
GPTRealty is offline   Reply With Quote
( Join the Elite Explorers )
Old 07-24-2011, 11:04 AM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 411 Post(s)
Welcome to this forum! I've moved your thread into the stock 91-94 section. You could replace the cylinder yourself, and save some money in the process.
BrooklynBay is online now   Reply With Quote
Old 07-24-2011, 12:42 PM   #3
something9000
naples fl
1994 navajo
Vehicle Specs
Quoted: 0 Post(s)
cars without airbags are easier so you shouldnt have any problems doing it yourself just be very careful of the wiring in the column
something9000 is offline   Reply With Quote
Old 07-24-2011, 02:23 PM   #4
Roadrunner777
Bemidji, MN
94 4x4 Sport 88k
Vehicle Specs
Quoted: 14 Post(s)
Copied from a thread I found searching for 'ignition lock'. It also appears that, if you have a tilt column, it may need to be tilted all the way up or down to get to the pin in step 7. The factory manual says to remove the steering wheel, but apparently not.
Replacing Ignition Lock Cylinder - 7 easy steps.
1. Disconnect battery
2. Make sure battery is disconnected
3. Remove steering column cover (3 screws IIRC)
4. Place key in the ignition and turn it to the "run" position
5. On the underside of the ignition there is a 1/8" dia. hole, push in with a
punch/awl/small screwdriver/etc. This pushes the release pin for the lock
cylinder. (sometimes it takes a bit of pressure to move the pin)
6. Pull cylinder toward passenger side, and remove electrical plug (if it has
one)
7. Install is reverse of removal.
Roadrunner777 is offline   Reply With Quote
Old 07-24-2011, 04:16 PM   #5
Jason94sport
South FL
93 Sport 2WD 5 speed
Vehicle Specs
Quoted: 49 Post(s)
I had to remove the steering wheel to get to the pin hole. I was unable to see it from either all the way up or all the way down. I know some say you don't, I was not one of them.
And here's a trick. If you take your VIN to a ford dealer & buy a ignition cylinder from them, they can match up a cylinder that is keyed to the doors. Then you will have the same key for both.
__________________
1993 2WD Sport 5 speed
BBK TB, Flowmaster Force II Cat Back, CAI
Pioneer HU, Clarion speakers, RF R300 powered 10" sub
Jason94sport is offline   Reply With Quote
Old 11-17-2013, 06:18 PM   #6
Tsalagiman
1994 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
No Access Holes
one)
I'm trying to do this on my '94 Explorer Sport, 5-speed and tilt. I can go as far as #4 , but there is no hole on the underside of the casting. I have seen posts on other sites by people having the same problem. One solution was to use a coat hanger to access the release pin via a tube in the casting on top. I didn't have any luck with that either as there are still no openings.
Tsalagiman is offline   Reply With Quote
Old 11-18-2013, 12:07 AM   #7
awood
Kaysville, utah
94 XLT
Vehicle Specs
Quoted: 4 Post(s)
http://www.explorerforum.com/forums/...d.php?t=197697
Scroll down to post #15 .
__________________
_______________________
90 Ranger (retired)
92 Explorer 4X4 (wrecked)
94 Ranger 4X4 (retired)
94 Explorer 4X4 (current)
awood is offline   Reply With Quote
Old 05-17-2015, 09:58 AM   #8
smegun
florida
1994 ford explorer xlt
Vehicle Specs
Quoted: 11 Post(s)
any suggestions for AUX i replaced my cylinder but cant seem to get auxillary power to function the key goes back but no power to instrumentation
smegun is offline   Reply With Quote
Old 05-17-2015, 11:59 AM   #9
natenkiki2004
North Idaho
"Blue Bomb"
Vehicle Specs
Quoted: 260 Post(s)
Sounds like it's out of adjustment. I replaced the steering column in mine, the internal part, not the housing that bolts to the dash. The only thing that changed was the cylinder and rod. The ignition switch was the same but I re-adjusted it. Didn't have Aux before and now I do.
Check my video, I go over what I think is proper adjustment of the switch:
https://www.youtube.com/watch?v=d7W0pzd6sdA
__________________
1991 Ex "Blue Bomb" @ 230k [Owners Guide] [Videos]: Overhauled A4LD, Mile Marker hubs, 3.73 LS, LT235/75-15 Cooper AT3's on factory alloy, KYB Gas-A-Just, NGK PTR5F-11, synthetic oil everywhere.
Mods: silicone vacuum hose, 4-hole Mustang injectors, roof spot lights, LED interior lights, Jensen CDH900 Filters: trans (spin-on), coolant
1994 Ex "Albino Bomb" @ 190k [Videos]: Parts vehicle
natenkiki2004 is offline   Reply With Quote
Reply
Tags
1994 explorer 4x4, cylinder replacement, ignition key
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
