#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Vibration above 65 mph
Reply
Thread Tools
Old 07-26-2011, 04:57 PM   #1
barberjb
Vineland, NJ
'94 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hi all,
Got a relatively new problem on my '94 X with 190k. When hitting 65 mph, i start to get a significant increase in the vibration in the vehicle. It's very noticible in the steering wheel, and I think it's coming from the driver's front. I have had the alignment done and the wheels balanced, but that hasn't seemed to address it. Any thoughts? And yes, I know the first solution is to not drive over 65, but who can do that?
For what it's worth, I've had the ball joints taken care of in the last year or two, and a steering linkage.
barberjb is offline   Reply With Quote
( Join the Elite Explorers )
Old 07-27-2011, 12:23 PM   #2
rustbucketMI
Michigan
'94 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
My X does this too, and I've heard a lot of other people having the same issue. For me the shaking does away at about 70/72. I drive at 75 so I usually don't notice it. I think in most cases it is a combination of part wear and the natural frequency of the vehicle when those parts wear. (For those who don't know everything has a natural frequency, which is essentially the frequency in which the object vibrates.) Automakers were smart enough in the 90s that they tested for this condition, but no one tests for when parts have had 100k+ miles on them.
My suggestion is to eliminate the driver seat suspision. When cruising at 65 take your hands off the wheel (make sure you can still back get to the wheel really quick). If the steering wheel is shaking then its the truck, if its not then its probably the seat. If it is the seat it probably just needs to be tightened down. if its the truck try driving faster/slower
__________________
'94 Explorer XLT - Warn Manual Hubs, Pro Comp Trail lights and agressive tires, 4.6L MAF, Spectre cone filter, flowmaster exhaust
'07 F150 - MBRP Exhaust, AEM Cold Air Intake
'78 Nova - LSX engine, Ford 9" rear end, Custom roll cage and suspension
2012 Mustang Boss 302
- AM
rustbucketMI is offline   Reply With Quote
Old 07-27-2011, 12:40 PM   #3
LONO100
Bay Area CA
03 sport trac XLT
Vehicle Specs
Quoted: 22 Post(s)
before you do anything, figure out when was the last time you rotated your tires. if its been a while you probably developed some bumps on your tread. run your hand over the tread and see if you feel any bumps. in fact, have a les schwab guy or some other tire guy look at it. this is always overlooked and people always drop tons of dough on other fixes before looking at this. good luck!
LONO100 is offline   Reply With Quote
Old 07-27-2011, 12:41 PM   #4
Roadrunner777
Bemidji, MN
94 4x4 Sport 88k
Vehicle Specs
Quoted: 14 Post(s)
Try rotating your tires and see if it changes anything. Balance is really only the first and easiest thing to check on a tire. Anyway, rotation is cheap, and always a good thing to do on a 4-wheel drive.
EDIT: Lono beat me by a minute!
Roadrunner777 is offline   Reply With Quote
Old 07-27-2011, 12:42 PM   #5
LONO100
Bay Area CA
03 sport trac XLT
Vehicle Specs
Quoted: 22 Post(s)
btw, another way you could check if its your tire tread thats causing the wobble, take the front wheel off and roll it down the street as you walk along side it. if it has a hard wobble to it, wiggles side to side or cant stay upright on its own, theres your problem.
Old 07-28-2011, 01:47 PM   #6
mhallack
Rockland, Maine
94 XLT
Vehicle Specs
Quoted: 0 Post(s)
I get the same vibration at near 65mph, but I have also had 3 new tires put on in May. Before and after the tires were replaced, same vibration. New tires were professionally replaced and balanced. (AKA: not done by me )
Since where I live I do very little freeway traveling I keep the speed under 65mph 99% of the time, so it's not a really big deal, I'll check on the seat suspension. I've never noticed the steering wheel vibrating too with the truck.
mhallack is offline   Reply With Quote
Old 07-28-2011, 01:58 PM   #7
Baddecision93
Orrville, OH
92 XLT
Vehicle Specs
Quoted: 0 Post(s)
I've heard tons of different ideas from looking around this site but it's worth noting that if your bearings haven't been maintenanced or replaced in a long time they could be contributing.
__________________
It's nothing time and money can't fix...
Trying to reverse rust, time, and the work of a crazy Amishman
My Explorer
Quote:
Originally Posted by DeRocha View Post
I can tell you Jesus is very popular when working on 10+yrd vehicles in the rust belt.
Baddecision93 is offline   Reply With Quote
Old 07-29-2011, 09:26 AM   #8
barberjb
Vineland, NJ
'94 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
I think it might be the bearing too. If that's the case, it will get worse eventually and I'll have it replaced. I had that bearing replaced a number of years ago in some guy's front yard in the middle of nowhere Pennsylvania once. His buddy who was helping him repair it offered me a Busch while they were working on it...
Old 07-29-2011, 10:19 AM   #9
Baddecision93
Orrville, OH
92 XLT
Vehicle Specs
Quoted: 0 Post(s)
Wow, that's about as good as it gets. Someone offering help on your truck AND beer .
I just know that after I did my lift I had a terrifying vibration. Mine was so bad in fact that I couldn't go over 20 without being scared of destroying the truck or running it off the road. When I took it in for my alignment (I was scared to drive it so I trailered it there) the said that the bearing preload was way out of whack. They said essentially it was in there "crooked". They set it back to spec, did my alignment, and all was right with the world.
At $20ish a pop it's definitely worth looking into.
__________________
My Explorer
Old 07-29-2011, 11:03 AM   #10
westfield
San Antonio, TX
94 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
I was going to suggest wheel bearings as well..Mine had a similar problem...changed the bearings and all is well...
westfield is offline   Reply With Quote
Old 05-19-2013, 10:31 PM   #11
Chrisman889
Gypsum, KS
1993 Ford Explorer xlt
Vehicle Specs
Quoted: 24 Post(s)
I have a 93 Explorer that does the same exact thing. I have replaced the shocks but the problem still continues. I also have a lot of chopping on the inside tread of my front tire. Does anyone know how to adjust the camber on these vehicles? Do I need to buy one of those adjustment kits?
Chrisman889 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
