EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
94 explorer brakes
Reply
Thread Tools
Old 07-28-2011, 07:16 AM   #1
madmongodog
Pittsburgh, Pennsylvania
1994 explorer eddie bauer
Vehicle Specs
(Original Poster)
94 explorer brakes
I have a 94 the problem is with the brakes. The brakes a heating up so bad that they smell like they are burning, and the manual hub centers melted (plastic). The bearings were changed, the calipers, the rotors,
Brake pads. The wheels rotate freely when the truck is lifted off the ground so the calipers are not hanging up. I just don't
Know where to turn, even the dealer does not know. Any help would be greatly appreciated. Jim
madmongodog is offline   Reply With Quote
Old 07-28-2011, 03:31 PM   #2
OneBadExplorer
Michigan
'94 Sport
Vehicle Specs
Oh my favorite the phantom brake hangup.
The first thing I look at is the calipers. If they are free and the pads are on right the only thing left is the hoses. I would assume this is only on one side? The liner of the brake hase over time deteriorates and closes in on itself without any outside wear. When the pedal is depressed the fluid has enough pressure to push by this closure but when you come off the brakes the fluid cannot get back by causing the caliper to hang. If this has been going on for some time I would replace the calipers again. The heat melts the seals inside the caliper and will cause leaks.
Cheers
OneBadExplorer is offline   Reply With Quote
Old 07-28-2011, 03:48 PM   #3
BendixAnswerMan
Vehicle Specs
A few items that might have a look-see. One of the best times to find out what's up is after the brakes are heated up. Get the wheels off the ground and check the resistance. The dragging will be caused by mechanical binding or residual hydraulic pressure remaining in the system. If you crack open a bleeder and the drag releases then it is hydraulic pressure. Hoses are a common cause of this as suggested in the previous post. You can go to the front line from the master cylinder and loosen it after the brakes have been reapplied to create the drag. If the calipers release, then the vent ports in the master are being covered holding in the pressure. Brake light switch adjustment or contamination behind the rear snap ring in the master can create this issue.
If you loosen the bleeder and the caliper does not release then it is mechanical drag from the caliper. Pin bores usually get gunked up and stiff. Also any rust or corrosion in the pad sliding areas of the abutments where the pad ends rest can create drag also. Be thorough, it has to be just right.
BendixAnswerMan is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
