| General Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum |
Thread Tools |
#1 |
Wannabe Elite Explorer
Royal Oak, MI
1996 Sport
1996 Explorer Heat Problem - Blend Door Actuator Plenum
Been reading the postings on the A/C Heater issues. I have a 1996 Explorer with about 65K miles. In early 2000, I noticed that it was only blowing hot air. I had it checked out and Ford Service told me it was the blend door actuator plentum that was cracked and would cost about $750! I decided not to get it fixed since it was winter time. In the summer, I realized that the Max A/C blew out cool, a/c air, so I used that in the summer. Just a couple days ago, my Max A/C stopped working, and the truck is blowing only hot air (even with the controls set to "off" - hot air is blowing out of my floor and at the windshield). There is a TSB (Technical Service Bulletin) written addressing the issue (#97-24-25), but Ford still will not pay for it. I heard that Ford actually mixed up the doors for the Automatic and the Manual Temp. systems which caused the blend door actuator to fail prematurely. I would think Ford would assist in the repair cost since it sounds like a manufacturing defect. I have written to Ford, and they turned my request down. Has anyone had any experience with this issue and received some assistance? Would love to hear some advice as the repair cost is out of sight, and it's 90 degrees in Michigan right now!! THANKS!!
#2 |
London, Ontario
2003 Explorer XLT 4wd
Hey,
My car just started doing the same thing last fall. The heater / A/C worked fine, now the heater doesn't cool down, and the A/C does not work in the low setting, only max A/C! Any suggesions? What happened to you with Ford and the service bulletin? __________________ White 2003 Explorer XLT sport appearance package - Awesome 17" alloy wheels, 4.0 litre V6 |
#3 |
Royal Oak, MI
1996 Sport
Seems like a lot of people are having the same trouble with their '96 and '97 Explorers. I have had no luck with Ford and the service bulletin. They told me last summer that the bulletin is not a recall notice and that it is just for dealer techs to reference when making repairs. To me, it seems like they knew (know) of a problem, but won't fess up.
Meanwhile, my vehicle is still not fixed because of the high cost. Under normal circumstances, I have just heat blowing out of my vents (uncontrollably), but I had a mechanic at a heating and cooling shop help me rig it so that I can have just cool air come out if I want. There is some type of sensor under the hood where you can engage it with a tie strap and the vehicle will blow cool air and A/C will work. I'm not a mechanic, so I don't know what this thing is, but it allows me to have heat in the winter (without the tie strap) and cool in the summer (without it). Kinda sucks when it is "in between" weather because I have to go under the hood and tie strap it up when it gets warmer, but I can't afford the repair, so I'm dealing with it. If you want me to get more specific with that, I can let you know what to do. |
#4 |
Boonville, CA
'95 Sport
'95 SPORT HEATER PROBLEM
I was glad to see this thread, although it doesn't appear to have any solutions at the moment.
MY PROBLEM: My heater sometimes doesn't put out hot air. It appears that if I turn the mode switch to OFF, then turn it back to HEAT, the heater output air remains off. A/C works, as well as the air flow. Its just always cold! This has happened several times now. After a few hours to a few days, it returns to normal. I think the problem is an actuator or door sticking, but can't find where it is. My Haynes manual doesn't show anything about the heater duct & valving system. Also didn't find anything helpful in the archives. Any suggestion as to where to look would be appreciated. Its still winter-even in N. California! Thanks, Jerry __________________ JerryB 1995 Sport ControlTrac 4x4, 4.0L OHV, 3.73 LS axle, Edelbrock IAS shocks Bosch Plus 4 plugs, Splitfire wiring, 112,000 miles |
#5 |
Allendale, MI
2001 Eddie Bauer V-8 AWD
ESPNFreak's Dad has the same problem in his 98 XLT. they wanted like $1,000 to fix it.
Also Willndtw, I noticed your from michigan. If you'd be interested in meeting up with some other explorer guys on this board and do a little off roading, you can join uo at Silver Lake Dunes (South of Ludington) in April. Visit the "Serious Explorations" forum for details. It'll be a great time! __________________ 2001 Eddie Bauer 5.0L V-8 AWD 152,000 miles...K&N drop-in...P275/70R16 Dueler A/T REVO (second set..first ones lasted 98,000 miles! ), OME rear suspension, TT in front, aletzzas, white gauges, painted interior
#6 | |
Allendale, MI
Re: 1996 Explorer Heat Problem - Blend Door Actuator Plenum
#7 |
RAMajama
Pleasant Valley, NY
05 RAM 2500 TURBO DIESEL
I got the blend door syndrome in my 98 XLT. It sucks and there is no way in hell I'm gonna pay $1,000 to fix Fords mistake. That is $1,000 worth of mods I could do.
#8 |
Allendale, MI
I'm gonna try to look at Jason's dad's truck over spring break and see what I can figure out....it wouldn't be that hard to get to..remove radio and stuff is easy
i just dunno about under the passanger side of dash..gonna explore that. I'll keep ypu all posted..2 weeks till spring break! Woo hoo! __________________ 2001 Eddie Bauer 5.0L V-8 AWD 152,000 miles...K&N drop-in...P275/70R16 Dueler A/T REVO (second set..first ones lasted 98,000 miles! ), OME rear suspension, TT in front, aletzzas, white gauges, painted interior
#9 |
Royal Oak, MI
1996 Sport
Damn! I posted that original message last summer -- kewl to get some responses. And yes, it was hotter than hell in Michigan
Thanks for the off-roading invite 95XLT . . .sounds like a blast. I'll check it out. When you figure out a solution to the "blend door fiasco", as I am now referring to it, I'll be ready. I have had my '96 Sport since new and I still love the thing (not to mention it's paid off . ) It's been flawless except for this. Till later....
#10 |
Kansas City
96 XLT
You could always bypass the heater core in the summer to keep the interior temp down... Could the correct plunum be found at a salvage yard?
pmassch, is your blower just not working at lower speeds? Maybe you have an electrical problem. __________________ 96 4DR 4.0 XLT KKM, Bosch 4+, Rancho 5Ks, Borla Cat, 2" body lift, torsion twist and shackles |
#11 |
Pittsburgh, PA
'98 Eddie Bauer
Blend Door Fiasco
I have the same problem with my '98 EB.
Someone on the "problems with 98 Eddie Bauer heater" thread suggested using Dremel tool to cut hole in the plenum and tape/glue the blend door shut to get heat. I was thinking of going to the junk yard to do an autopsy on a donor truck to see if I can find a way to force door closed with a smaller hole, a coat hanger and some duct tape. Maybe I can find a "Firestone" victim to work on. __________________ Paul F. '98 Eddie Bauer 4.0L |
#12 | |
Allendale, MI
Re: Blend Door Fiasco
#13 | |
Fairmont, WV
'97 Sport
Quote:
__________________ '97 Explorer Sport 5 speed '72 Mustang Mach 1 |
#14 |
Pittsburgh, PA
'98 Eddie Bauer
Thanks for the tip.
Does the blend door stay by itself once you position it or do you keep something in there to keep it open/closed? __________________ Paul F. '98 Eddie Bauer 4.0L |
#15 | |
Fairmont, WV
'97 Sport
#16 |
RAMajama
Pleasant Valley, NY
I was talking to a guy at my ford dealer and he said that once a certain % of people have a problem that it automatically becomes a recall. I think he said something very low like 1.5% or something. Does anyone know if that is true? If it is that I wont mind waiting it out.
#17 |
Allendale, MI
You guys should all report it to ford then...maybe people just fix itthemselves like some of you did and ford never adds you to the statistic.
#18 | |
Mesa, AZ
'97 4x4 Sport
Quote:
__________________ 4.56 Powertrax No-Slip, SOHC V6, SuperChip, K&N FIPK (#57-2513-1), Borla cat-back (#14748), 2" torsion lift, 3" PA body lift (#853), Monroe Reflex shocks, 285 75R16 BF Goodrich T/A ko, 2WD mod Earnhardt Ford, Berge Ford, U-Haul ![]() My Explorer |
#19 |
RAMajama
Pleasant Valley, NY
Ok ill have to bug them about it then. I think they all run away when they see me coming
I do my homework on here first and then go to them. That way, I know what I'm talking about. They wont pull any fast ones on me |
#20 |
Boston, MA
'96 Eddie Bauer
I think it is a saftey issue
Because the problem with the heater plenum etc. can mean you have no defrost capability - it's not just a comfort issue!
I have a 96 Eddie Bauer and just paid $900 to have mine fixed. I'm calling Ford tomorrow to see if they will help pay for it. |
| Thread Tools | |
