Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
AC issue
Reply
Thread Tools
Old 08-02-2011, 07:00 PM   #1
4.6EXPLORERFAN
Cedar Rapids, Iowa
2002 Explorer Eddie Bauer
Vehicle Specs
(Original Poster)
AC issue
So, I've done some searching for this issue and I'm not seeing anything so here goes. A couple of weeks ago my air didn't feel quite so cold and was warm on the passenger side. I let it go until today and stopped by to pick up a can of 134 figuring I was just a little low. Problem is the air never got cold and the PSI showed 25. It got close to 40 and then dropped but it didn't feel like the can was emptying so I gave up. I noticed that all of the lines in the engine bay were actually frosted over. I'm pretty sure that the compressor was running but never actually heard it cycle, just heard it turn on when I turned the AC in the truck. The air is cool on the driver side but not cold. Any ideas? This seems to be the year of the Explorer in this family as she is been rackin' up the bills since February. Any help on this would be greatly appreciated, especially if it will save me a few bucks!!
4.6EXPLORERFAN is offline   Reply With Quote
Old 08-02-2011, 07:25 PM   #2
EXPLORER04
Clearwater, FL
04 XLT
Vehicle Specs
My guess would be to check the blend door. It is a common problem and might not be fully opening of closing.
EXPLORER04 is online now   Reply With Quote
Old 08-03-2011, 08:58 PM   #3
4.6EXPLORERFAN
Cedar Rapids, Iowa
Vehicle Specs
(Original Poster)
Just so that I understand...The blend door would be possibly not closing all the way allowing it to mix warm air and the air conditioned to go together? Guess I just don't get why I get 2 different temps and why it didn't seem to be taking any of the 134 in even though pressure is low. I will look into the blend door thing for starts though. Thanks.
Old 08-03-2011, 10:10 PM   #4
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Check out this thread: http://www.explorerforum.com/forums/...d.php?t=323725
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is online now   Reply With Quote
Old 08-04-2011, 08:21 AM   #5
jrford
Birmingham, MI
'10 Sport Trac
Vehicle Specs
i just did this, same symptom too. Yes its slow going in adding freon. Couple of tips that might help? When i first open and start adding freon the pressure will jump to like 70psi but as the systems distributes what you add it will come back down; also make sure the A/C clutch is constantly running; it does take a long time to get stuff in there; i also find that as the can gets cold it loses pressure, so what i do is try it over several days so the can warms up. Plug it in for 5-10 minutes or when the can gets cold remove and repeat the next day till the can is empty or when all the vents get cold.
By the way if you have Rear Air the system takes about 56oz each can is like 8oz. It might take a few cans. . .
__________________
Jim
2010 Mercury Mountaineer Premier, V8 AWD, 15k
2010 Sport Trac Limited, V8 4WD, 55k
2004 EB Quad Buckets V8 AWD, 105k
jrford is offline   Reply With Quote
Old 08-05-2011, 09:27 AM   #6
4.6EXPLORERFAN
Cedar Rapids, Iowa
Vehicle Specs
(Original Poster)
Ok, so I'm gonna attempt to add the rest of the can today and probably pick up another one. Little worried about where it all went, but haven't used it that much since I ride the motorcycle in the summer most of the time. Is there a common place these things spring leaks or is this pretty typical of these things? Also, I'm using Prestone Synthetic 134 that's $12 a can. I've seen others for $6 to $8 a can. Safe to use?
Old 08-05-2011, 10:38 AM   #7
jrford
Birmingham, MI
'10 Sport Trac
Vehicle Specs
from what i understand any 134a is the same, 'synthetic' might be more marketing then anything else. If it says 134 its gota be 1,1,1,2-Tetrafluoroethane. . .not sure about the additives. I'd save the money get the cheapest 134a, imo. or i buy the one with the sealant and dye as additives.
its a big system with a lot of little o-rings everywhere. One tip on detecting a leak, if you add it and it get cold for a day or two, then warms up - most likely its a leak. Usually when i fill it up it will last for a long time. But as these get older the seals start to leak. Also the Condenser in front might have taken a hit which most often has been the cause of my leaks. If it doesn't seem to ever fill up you want to be sure to add the dye (some cans have it) and pick up a UV light and check for leaks. Sometimes they are obvious, other time not. Best time to check is at night or in the dark the dye (green usually) will stick out more.
__________________
Jim
Old 08-05-2011, 12:54 PM   #8
Javadog123
Hilo ,Hawaii
2004 XLS AWD
Vehicle Specs
put your can of r134a into hot water as you add it to the system.
Javadog123 is offline   Reply With Quote
Old 08-05-2011, 01:49 PM   #9
Elessar65
Wichita, Ks
Elessar65's Avatar
98 Sport, 95 Ranger SAS
Vehicle Specs
If the lines are frosting over its because of one of two reasons in my experience.
A. There is a restriction in the line and pressure is building behind it, and when it passes the restriction the pressure is much lower and it evaporates chilling the line instead of doing this at the orifice tube and evaporator.
B. The evaporator is flooded from too much freon or a faulty orifice tube allowing too much through, and can't evaporate all of it and liquid freon flown out of it into the accumulator, where it accumulates as it should so as not to allow liquid into the compressor (very bad news, because liquid is not compressible) and evaporates there, frosting the line.
Which line is frosting over, the low side or the high side.
__________________
Wheel it, Break it, Fix it, Repeat...
Elessar65 is offline   Reply With Quote
Old 08-05-2011, 08:53 PM   #10
4.6EXPLORERFAN
Cedar Rapids, Iowa
Vehicle Specs
(Original Poster)
Don't remember which line was frosting but picked up another can today after finishing the first. Warming up the can definately made a difference. After most of the second can went in the air finally turned cold on both sides. Passenger side is just slightly off from the driverside, but guessing if it was out on the highway and not just sitting in the heat idling it would be much better. Thanks for all the advice. I'll be posting another question real soon.
Old 08-06-2011, 09:07 PM   #11
ivrb
southern cal
2000 xls
Vehicle Specs
are thses condensors prone to leak easily?
ivrb is offline   Reply With Quote
Old 08-06-2011, 11:54 PM   #12
Elessar65
Wichita, Ks
Elessar65's Avatar
Vehicle Specs
I wouldn't say that they are prone to leaking, but its not all that uncommon either. The most likely places for leaks are at the fittings throughout the system.
__________________
Old 08-07-2011, 02:45 PM   #13
ivrb
southern cal
2000 xls
Vehicle Specs
I'm gonna have to shoot some dye in there and see what I find
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
