Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
2005 Brake lights not working after towing trailer.
Reply
Thread Tools
Old 08-06-2011, 11:55 AM   #1
WHATAWhata
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Used the wifes 2005 Explorer to tow a trailer. I hooked up the trailer lights to the Explorer factory plug on the tow bar. Now, brake lights nor the rear turn indicators do not work. Any help?
WHATAWhata is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-07-2011, 03:32 PM   #2
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Welcome aboard!!
WHATAWhata, here is the info from my owner's manual, which is the second printing. I have an early model '02 XLT, and I see you have an '05, so I don't know if this info will match your vehicle. If you need an owner's manual it can be downloaded here.
According to my owner's manual, there are no fuses for towing located in the fuse panel under the dash.
The Power Distribution Box under the hood contains a couple fuses related to towing. #13 is a 30A Maxi Cartridge Fuse labeled "Trailer Tow Battery". #27 is a 20A Mini Fuse labeled "Trailer Tow Lamps".
The Rear Relay Box & The Auxiliary Relay Box also contain items related to towing:
The fuse panel under the driver side dash contains 3 fuses related to the brake/turn lights:
#5 is a 15A Mini Fuse labeled "Flasher Relay (Turn, Hazards)", #21 is a 5A Mini Fuse labeled "Instrument Cluster, Compass, Flasher Coil", #23 is a 15A Mini Fuse labeled "Brake Pedal Position Switch"
Like I said, this info is for an '02 and might not be the same for your '05. I would start by checking the fuses in the fuse panel under the driver side dash, then the fuses in the battery junction box under the hood.
Hope this helps out!!
Please keep us posted as feedback helps others reading this post, looking for a fix to the same or similar issue!
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
