Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Cracked Head 5.0 (pics)
Reply
Thread Tools
Old 08-06-2011, 03:58 PM   #1
spacecadebt
Geneva FL
99 Ranger 2.5
Vehicle Specs
(Original Poster)
I was doing a tune up before a 2000 mile road trip and i noticed coolant leaking out the side of the head and sure enough there is a nice crack across three of the plugs. I said eff it and went on the road trip anyways. Truck ran great, didnt leak any coolant or over heat or anything.
So my question is can i keep driving on this or is this head trash?
The red line represents the crack
004 by Spacecadebt, on Flickr
spacecadebt is offline   Reply With Quote
Old 08-06-2011, 04:17 PM   #2
yavapaires
Dewey, Az
1996 XLT
Vehicle Specs
The head is probably too far gone to repair. 302 heads should be pretty cheap, relatively speaking. But for now, if you are not experiencing any leaking, I would go ahead and drive it. K&W block sealer is a very good product for leaking heads/gaskets. Are you sure it is a crack, and not a casting flaw?
yavapaires is offline   Reply With Quote
Old 08-06-2011, 04:28 PM   #3
spacecadebt
Geneva FL
99 Ranger 2.5
Vehicle Specs
(Original Poster)
Its clearly a crack being that its where the coolant is coming from. Ill have to give K&W a try. Thanks for the input
Old 08-06-2011, 08:50 PM   #4
spacecadebt
Geneva FL
99 Ranger 2.5
Vehicle Specs
(Original Poster)
There are a few u pull and pay junkyards around here with several 5.0 explorers. Would you recommend i buy two new heads or could i replace the one cracked head with one from the junkyard?
Old 08-06-2011, 10:16 PM   #5
yavapaires
Dewey, Az
1996 XLT
Vehicle Specs
I would replace the cracked one with a used head. Just be sure you take it to a machine shop, have it cleaned, and magnafluxed to check for cracks. If you have the funds, go for them both. Just buy a head set for the gaskets. It'll save you money in the long run. You can also pull the other head, and have the shop check it. I would go that route, since you will have it all but pulled anyway.But if you made the trip without a problem,and don't want to get into this big a project at this time, give the sealer a try. My 96 4.0 OHV has a bit of a leak, was getting water in one cylinder, plus leaking from under a head. I put Bars Leak in it. Worked OK. Drove it to AZ and back last month, has a slight leak from under the right head. I am going to drain, flush refill with anti freeze and add K&W this time. It is just a band aid, but until I get the funds to pull the heads, it will have to do for now. I have heard the factories use the K&W when new.
Old 08-06-2011, 10:36 PM   #6
spacecadebt
Geneva FL
99 Ranger 2.5
Vehicle Specs
(Original Poster)
I would love to try the sealer but im about to go on a cross country road trip on a very tight budget. If i break down on the road i wont have the money to get it fixed so i want to get this taken care of before i go. I dont think any kind of sealer is going to hold up for long haul highway driving.
Its funny you mentioned driving to AZ. Thats my first stop on my roadtrip
Old 08-07-2011, 08:32 AM   #7
yavapaires
Dewey, Az
1996 XLT
Vehicle Specs
What part of AZ are you going to? I visited my Mom in Dewey. It was her 87th birthday. I lived in AZ for46 years. Mostly Prescott/Verde Valley area.
Old 08-07-2011, 05:40 PM   #8
spacecadebt
Geneva FL
99 Ranger 2.5
Vehicle Specs
(Original Poster)
Well im going to explore the west and my first stop is the grand canyon and Kaibab national forest, then im gonna work my way north from there. Might go all the way to alaska if i can find a job halfway.
Old 08-08-2011, 07:28 PM   #9
4df150
Monticello, MS
2010 Explorer EB 4x4 4.0
Vehicle Specs
Quote:
Man I wish I had that freedom... Good Luck on your trip...
__________________
Bill Ford
Monticello, MS
2010 Explorer Eddie Bauer 4x4 4.0 (Wife's) : 1997 Explorer XLT 5.0
2005 F150 XLT Scab 5.4 : 2004 Triton TR-21x 225 hp Merc Optimax
2012 Yamaha Grizzly 700 EPS
4df150 is offline   Reply With Quote
Old 08-08-2011, 10:04 PM   #10
spacecadebt
Geneva FL
99 Ranger 2.5
Vehicle Specs
(Original Poster)
Thanks man. Been wanting to do this for a long time. Figured its time to put up or shut up. I just hope my 300,000 mile exploder makes it.
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
