#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
How do I know if I have a limited slip rear end?
Reply
Thread Tools
Old 08-07-2011, 12:09 PM   #1
wisneski7
Green Bay, WI
'01 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
How do I know if I have a limited slip rear end? Im changing rear axle bearings and I know there's a difference in the oil that I need to put in. Is there a way to see this visually, or is it somewhere in a code on the door jam? Thanks
Aaron
wisneski7 is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-07-2011, 12:26 PM   #2
LONO100
Bay Area CA
03 sport trac XLT
Vehicle Specs
Quoted: 22 Post(s)
look up your axle number on the door jamb, then search on the forum for the axle guide. then you can find out. good luck!
LONO100 is online now   Reply With Quote
Old 08-07-2011, 01:17 PM   #3
jlsparky7
Woodhaven, Mi
1996 5.0 XLT AWD
Vehicle Specs
Quoted: 0 Post(s)
He nailed it ^
Check out the links in my signature. I did a differential fluid flush vid and it has a vid of where the tags are on the axle. The numbers are on the door and the axle.
__________________
Explorer how to videos Brakes, Intake, Seafoam, Coolant Flush, Oil change, Differential Flush, Inertia Switch, Thermostat, Transfer Case Flush, Throttle Mod, and more!
http://www.youtube.com/user/jlsparky7
If you like/use my vids you can thank me by subscribing to my youtube page! Thanks!
jlsparky7 is offline   Reply With Quote
Old 08-07-2011, 03:03 PM   #4
yavapaires
Dewey, Az
1996 XLT
Vehicle Specs
Quoted: 0 Post(s)
Easiest way is to jack up both rear tires, put trans in neutral, park brake released, spin left tire forward. If posi, the right tire will spin forward also. If right tire spins backward, it is an open diff.
yavapaires is offline   Reply With Quote
Old 08-07-2011, 03:36 PM   #5
snoranger
Jackson, NJ
snoranger's Avatar
94 limited on 35's
Vehicle Specs
Quoted: 67 Post(s)
Quote:
Thats easier then reading the code off the door jam?!?!?
__________________
94 limited: 4.0l, 5spd swap, 6" skyjacker lift, 35x14.5 thornturds, 4.56s. 5.0 swap started (94 cobra 5.0, zf 5spd, np205)
95 xlt: stockish (SOHC swap, 30,000miles and I blew up the 3rd 4r55e...now collecting parts for a Cummins swap.)
Cummins 4BT swap thread
Ranger bed trailer build
snoranger is offline   Reply With Quote
Old 08-07-2011, 03:41 PM   #6
ranger-93
Fayetteville, GA
93 ranger, 01 f-350
Vehicle Specs
Quoted: 1 Post(s)
Quote:
a burn out might be more fun tho lol
__________________
'93 ranger splash 4x4. 6'' suspension 3'' body. 35x12.50x15. 4.88's, LS rear, open front - '01 f350 4x4 tow/work vehicle.
ranger-93 is offline   Reply With Quote
Old 08-07-2011, 03:44 PM   #7
spacecadebt
Geneva FL
99 Ranger 2.5
Vehicle Specs
Quoted: 0 Post(s)
punch it on a dirt road and see if both tires spin lol
spacecadebt is offline   Reply With Quote
Old 08-07-2011, 05:04 PM   #8
SoNic67
Newport News, VA
2001 V8 (Eddie Bauer) AWD
Vehicle Specs
Quoted: 454 Post(s)
They will spin both on a dirth road with an open diff too...
Now, if you are with a tire on asphalt and other on gravel, that is momething else
SoNic67 is offline   Reply With Quote
Old 08-07-2011, 08:00 PM   #9
yavapaires
Dewey, Az
1996 XLT
Vehicle Specs
Quoted: 0 Post(s)
No, but how do you know someone has not changed the rearend at some point???????
Old 08-07-2011, 08:05 PM   #10
spacecadebt
Geneva FL
99 Ranger 2.5
Vehicle Specs
Quoted: 0 Post(s)
Very good point
Old 08-07-2011, 08:13 PM   #11
snoranger
Jackson, NJ
snoranger's Avatar
94 limited on 35's
Vehicle Specs
Quoted: 67 Post(s)
How do you know the clutches arent worn out?
__________________
Old 08-07-2011, 10:23 PM   #12
SoNic67
Newport News, VA
Vehicle Specs
Quoted: 454 Post(s)
It should have tags on it. At least one line the one below, specific for limited slip.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
