Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
gas leak and gas fumes
Reply
Thread Tools
Old 08-19-2011, 05:56 PM   #1
skater488
93 explorer eddie bauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i has just filled my tank with gas and its a hot day ive been having problems with coolant usage and i was driving up a steep hill and i noticed my temperature gage was pretty high and as i was pulling into my driveway i went over a speed bump and it slipped and wouldnt go anywhere then kicked back into gear i had just replaced my transmission this summer and replaced my engine last summer. i has notice when i got out that there was a line of something i had been dripping for like 500 feet. i check all my fluids i was low on transfer case fluid and theres signs of fluid dripping all over the speed sensor, then i re filled it tryed to start it and its running rough now, i cant go anywhere it wont go forward or reverse, theres white smoke coming outta the exhaust and i smell gas fumes, so i open the hood and look around and i see theres a leak on the driver side exhaust manifold leaking gas i can smell it, i have no clue whats going wrong? can anyone help?
skater488 is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-19-2011, 07:14 PM   #2
arco777
arco777's Avatar
1994 Explorer 2dr 4x4
Vehicle Specs
Quoted: 99 Post(s)
Sounds catastrophic. Sounds like you blew the head gasket and overheated the tranny too. Hate to sound like a sleazy mechanic trying to steal your money.
Figure out what the fluids all involved are for sure. Give us all the info you can on what exact fluid came from exactly where. If the Check Engine light is on, tell us and pull the codes if you know how or can get Autozone to do it for you. If you don't know what a particular fluid is, wipe it on a paper towel and take some pictures. If you can, take as many good pictures of the carnage as possible and post them. It's the closest that someone on a forum can be without being beside you so give us as much information as possible.
__________________
-1994 Explorer 2DR 4x4 - Explorer Express X-Spec swaybars/shocks, BBK throttle body, Dynomax exhaust, misc trans upgrades.
-2008 Mustang GT Bullitt #5560 - Brenspeed tuned
-1995 fullsize Bronco 5.8L - intake, exhaust and trans mods, cosmetic mods.
arco777 is offline   Reply With Quote
Old 08-19-2011, 07:15 PM   #3
arco777
arco777's Avatar
Vehicle Specs
Quoted: 99 Post(s)
Also post where you are located physically, maybe a forum member in your local area will see it and can give you a hand.
Old 08-22-2011, 02:13 PM   #4
skater488
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i found out the main problem is my right driver side 3 cylinders i dont think are firing because i took off the spark plugs and all 3 had gas on them and i can see the gas coming outta the exhaust manifold, but i cant seem to find out anything about what it can be or why its doing it, i know the plugs and wires are good i just changed them not long ago
Old 08-22-2011, 04:33 PM   #5
Roadrunner777
Bemidji, MN
94 4x4 Sport 88k
Vehicle Specs
Quoted: 14 Post(s)
Spark check, figure out if it's ignition or fuel.
Roadrunner777 is offline   Reply With Quote
Old 08-22-2011, 08:06 PM   #6
skater488
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
its not the ignition the coil pack is good, its leaking through the exahust and coming out the pipe
Old 08-23-2011, 11:18 AM   #7
dtack
fort myers florida
Vehicle Specs
Quoted: 0 Post(s)
sounds like a head gasket or exhaust manifold gasket needs replaced, and regardless of if your plugs are new or not even new ones go bad at times, i would replace them, i think ford used motocraft plugs from the factory, try a set of those, you can get them at advanced for pretty cheap. i would replace the plugs, check your gaskets and check your tranny fluid and see if it smells burnt.
dtack is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Gas leak... more like pouring out BlkSquad Stock 1995 - 2001 Explorers 10 07-10-2011 04:40 PM
Gross Gas Leak [ code P0455] mulea Stock 1995 - 2001 Explorers 1 04-02-2008 01:33 PM
95 Explorer Gas Leak LWeston Under the Hood 4 02-11-2008 01:11 PM
Gas leak on top of gas tank and other problems KBoomBoxx Stock 1991 - 1994 Explorers 2 09-20-2006 03:03 PM
1993 V6 xlt gas leak from line or pump...safe? eclark93xlt Elite Explorer 911! 4 10-02-2004 12:26 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
