Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
2000 Explorer. Windows stopped working.
Reply
Thread Tools
Old 08-22-2011, 09:04 PM   #1
pevecch
2000 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i have a 2000 ford explorer 4 door. all of a sudden my windows will not go up from any switch the lock switch works on the driver door yet the windows will not. i ripped the door panel off and checked the fuses, they are all good, please help someone!!!!!!!!!!!!! is there any way to at least get my windows up in case it rains????? thank you
pevecch is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-22-2011, 09:26 PM   #2
helphos
maryland
2002 Limited V8
Vehicle Specs
Quoted: 0 Post(s)
power windows kaput
My daughter has the same problem in her 2002 explorer. It's intermittent, so the dealer won't even try.
Others on the forum have suggested a broken wire in the bundle where it goes from the door to the body. I tried but couldn't find any bad wires.
I'm disappointed in ford that they have so many problems- wheel bearings don't last, windows don't work reliably and coil springs break.
Maybe the dealer will help if your windows are not intermittently broke. I'm sure that's not the advice you sought, but at least you can try taking off the door panel and seeing if a broken wire is visible.
Good luck.
helphos is offline   Reply With Quote
Old 08-22-2011, 09:27 PM   #3
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 411 Post(s)
Welcome to this forum! I've moved your thread into the stock 95-01 section. Check the wiring in the rubber boot between the door, and the frame of the vehicle.
BrooklynBay is offline   Reply With Quote
Old 08-22-2011, 09:36 PM   #4
pevecch
2000 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
will you be able to notice a broken wire????
Old 08-22-2011, 09:41 PM   #5
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 411 Post(s)
The wires crack inside of the insulation, so you will need a continuity tester.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Top search phrases for this site Rick Suggestion Box - Forum Feedback 11 09-12-2011 09:22 AM
Ford Explorer 1995 Tranny stopped working. OzzE Stock 1995 - 2001 Explorers 4 02-19-2010 12:19 AM
2000 explorer #26 fuse blown R146Rick Stock 1995 - 2001 Explorers 1 01-04-2010 07:20 PM
97 Explorer, no power windows working IndyDurango Stock 1995 - 2001 Explorers 7 11-06-2009 10:13 AM
94 Explorer - Both front speakers stopped working KiloWatts Explorer Audio & Navigation 2 09-14-2006 12:46 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
