Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Ranger - Mazda B-Series Forum > Ford Ranger - Mazda B-Series Forum
Notices
Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well.
Ford Ranger map sensor.
Reply
Thread Tools
Old 08-25-2011, 09:15 AM   #1
dedrick
1997 ford ranger
Vehicle Specs
(Original Poster)
how can u troobleshoot a map sensor on a 97 ford ranger
dedrick is offline   Reply With Quote
Old 08-31-2011, 04:24 PM   #2
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Welcome to this forum! I've moved your thread into the Ranger section.
BrooklynBay is online now   Reply With Quote
Old 09-01-2011, 12:57 PM   #3
tmwalsh
suburban atlanta, ga
85
Vehicle Specs
You can use a DVOM with a frequency counter. The Hz will change with the change in manifold vacuum. There is a table in the shop manual that will indicate 'normal' ranges for given ambient atmospheric pressures or altitudes. The Hz should change as the throttle is opened and closed. A 'snap' of the throttle should show definite and quick response.
Generally, they go bad or work. When bad, the idle can go all over the place as the MAP is telling the computer the engine is under load and then .not., leading to a wandering and unstable idle.
tom
tmwalsh is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Jakee's 4.0 SOHC Build up discussion and motivation thread Jakee Need for Speed! 1549 04-09-2013 07:22 PM
Pulling a stuck o2 sensor Stick_man Stock 1995 - 2001 Explorers 20 02-14-2010 09:35 AM
Ohio Dept. of Education and Ford Motor Company Fund Join Forces on Education Program chriswells78 Ford Industry News 0 06-08-2006 12:56 PM
Ford Fearful for Explorer's Reputation Stephen Ford Industry News 23 08-26-2000 11:00 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
