Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
95 Ford Explorer Fuel Pressure
Reply
Thread Tools
Old 08-28-2011, 08:17 PM   #1
N2bnfunn
1995 Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I went to Auto Zone today and got my fuel pressure check and it was 30 while running according to the auto zone book it should have been between
35-48.. (I just replace the fuel pump regulator before they checked it)
My questions are how much on a average should I paid to get the fuel pump
replace, and since the pressure is only at 30 should I be in a hurry to fix it?
N2bnfunn is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-28-2011, 09:42 PM   #2
Lube
Oklahoma
95 XLT
Vehicle Specs
Quoted: 0 Post(s)
Can't answer the cost part cuz I do it myself, but yes you should get it fixed soon. It won't get better by itself, and it well deteriorate fairly rapidly.
Lube is offline   Reply With Quote
Old 08-29-2011, 05:47 AM   #3
ranger7ltr
Great State of Texas
1999 Sport
Vehicle Specs
Quoted: 35 Post(s)
Was that pressure at idle?
I ask because the vacuum is highest at idle and that will pull the hardest on FPR and lower the pressure...If you remove the vacuum line or open the throttle the pressure should increase up to 35-40 psi...
Is the truck running normally or is it hesitating on acceleration or something else? That pressure at idle is pretty close to, if not, normal...Also when was the last time the filter was replaced? A restricted fuel filter will cause pressure drop as well...
__________________
When in doubt, use a bigger hammer!
2014 Jeep Compass Limited [Company Vehicle]
2003 Ford F-150 XLT Supercab
1999 Ford Explorer Sport [new playtoy]
1983 Ford Ranger V8 [soon to be gone]
ranger7ltr is online now   Reply With Quote
Old 08-29-2011, 11:35 AM   #4
N2bnfunn
1995 Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks and yes it was at idle and I will next get the fuel filter change and this time check it with giving it some throttle...
Old 08-29-2011, 07:33 PM   #5
ranger7ltr
1999 Sport
Vehicle Specs
Quoted: 35 Post(s)
If you accelerate the engine under a load does the engine stumble or hesitate? If not, the fuel is probably at the correct level...
But I would still check the fuel pressure...
__________________
Old 08-29-2011, 11:23 PM   #6
N2bnfunn
1995 Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
No it does not ever stumble or hesitate, my problem is the SUN if I leave it out in the SUN it is hard to start but only then..
Old 08-30-2011, 08:44 AM   #7
ranger7ltr
1999 Sport
Vehicle Specs
Quoted: 35 Post(s)
Let's look at the symptoms...
So if you drive the truck and it is hot outside it is hard to start? If it sits in the sun for 30 mins or 4-6 hrs does it change the condition? If you run into a store for 15-20 mins and it is hot outside is it hard to start as well?
Is it only hard to start when the engine is hot? I am not sure where you are but here in Texas we are routinely seeing 105-115 F daily and I drive my truck in that everyday with no hot startup issues...
I would measure the resistance of the engine coolant temperature sensor if the engine is only hard to start when the engine is up to temperature...As the coolant temp changes this sensor feeds info back to the PCM and at cold start and hot re-startup will enrichen the fuel amount to aid startup...And yes it is possible that the sensor reads properly at engine cold and not when the engine heats up...I recently replaced this same sensor because it was not reading hot enough when measured with my code scanner...I run a 195 F thermostat and I was only seeing 168-172 F engine tempearture from the ECT...
Since I don't believe you have a code scanner the one at AZ might be able to read engine coolant temps as delivered by the ECT and might point in that direction...
__________________
Old 08-30-2011, 11:03 AM   #8
N2bnfunn
1995 Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Old 08-30-2011, 11:10 AM   #9
N2bnfunn
1995 Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
No it is not when I drive it and the engine get hot, I am just talking about the truck itself sitting in a parking space in the sun, then it is hard to start, never when I drive it and from the engine heat hard to start. Put I did replaced the engine coolant sensor, and yes I do I had code reader, and when it would not start I connected it, and the error it found was a 327 on both side, so I replace the DPFE sensor and now shows nothing wrong from the code reader.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Jakee's 4.0 SOHC Build up discussion and motivation thread Jakee Need for Speed! 1549 04-09-2013 07:22 PM
Where is the fuel pressure test port on '03 ford explorer ? nirvanaws Under the Hood 2 05-05-2011 01:41 PM
How To: 12/95 or 1996 Ford Explorer V-6 4.0 4 dr Fuel Pump Replacement rockchucker Stock 1995 - 2001 Explorers 0 04-14-2009 03:09 PM
12/1995 Explorer V-6 4.0 starts then dies after 2-3 seconds rockchucker Stock 1995 - 2001 Explorers 7 04-14-2009 02:55 PM
2002 Explorer: Many refinements and new devices Rick Auto Industry News 2 03-08-2004 01:26 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
