Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Modified 1995-2001 Explorers
Notices
Modified 1995-2001 Explorers Questions related to modified 1995-2001 Explorer, Mountaineer, Ranger and 2002+ Sports (2dr). Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, torsion twist, lift kits, engine swap, transmission swap.
V8 Swap Advice, any advice welcome
Reply
Thread Tools
Old 08-28-2011, 09:01 PM   #1
Tubstinator
Mesick, Michigan
1995 Eddie Bauer Edition
Vehicle Specs
(Original Poster)
So here is what I got:
1995 Eddie Bauer 4x4 V6
and
1996 XLT 4x2 V8
I want to swap the engine into the 95 because of 4wd and drop the V6 in the 4x2 to make a summer driving truck. I need help, advice on what I am going to need to accomplish this so please post links or direct advice right on here. Thanks a bunch and God bless!
~Tubs~
Tubstinator is offline   Reply With Quote
Old 08-29-2011, 02:31 PM   #2
Tubstinator
Mesick, Michigan
Vehicle Specs
(Original Poster)
bump*
Old 08-29-2011, 04:07 PM   #3
vroomzoomboom
Elite Canuck STOCK SUCKS!
selkirk, manitoba
vroomzoomboom's Avatar
98 5L sport
Vehicle Specs
do a search, and you will find all the info on here.
__________________
NOS is nice, but i'd rather be BLOWN
evils elite registry
roll pan build for 1st and 2nd gen explorers
door switch LED convention
vroomzoomboom is online now   Reply With Quote
Old 08-29-2011, 07:25 PM   #4
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
2000 Sport SOHC 2WD
Vehicle Specs
incompatibilities
The V8 engine is not compatible with the V6 transmission and the V6 engine is not compatible with the V8 transmission. That means both engine/transmission pairs would have to be swapped. However, the 2WD transmission is not compatible with the 4WD transfer case.
I suggest that you sell your 95 4WD V6 and purchase a 96 or later 4WD V8. They are readily available and that way you will have the later OBD diagnostics. Your 96 2WD V8 is not that common, has a robust drivetrain, and will get decent gas mileage if you drive it like it only had a 150 hp V6.
__________________
My Helpful Threads, Registry, 16.4/23 mpg, 3900 lbs, 5R55E, 3.73:1, 175 rwhp, Henson custom tune, CAI, Spectre air filter, Lightning 90mm MAF, 75mm throttle body, A/F ratio meter, synthetic oils, Accusump, 2 row radiator, 3+1 leaf springs, .75 inch drop, Edelbrock IAS lowering shocks, engine oil & ATF temp gauge & remote filters & coolers, remote crank
2000StreetRod is online now   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
V8 swap data- CHECK IT OUT james t Offroad Explorer - Ranger Projects 8 06-21-2011 11:28 PM
Why dont we have a V8 swap Thread? POST A V8 SWAP LINK ITS GONNA BE A STICKY!!! Chief34 Offroad Explorer - Ranger Projects 16 02-20-2009 12:14 AM
Test Drove (Need Advice) 98 Mountaineer V8 BrianV Stock 1995 - 2001 Explorers 21 01-31-2006 10:46 PM
V8 swap BislamJoe Offroad Explorer - Ranger Projects 25 07-18-2001 12:36 PM
tranny swap and other advice..?? Chad Summers Offroad Explorer - Ranger Projects 4 07-17-2001 02:19 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
