Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Loud humming noise
Reply
Thread Tools
Old 08-31-2011, 12:22 PM   #1
ammodoug
2003 Explorer 4.6
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US Loud humming noise
I have a 2003 explorer with the 4.6 engine. It was stalling out on me when I released the gas pedal. I replaced the IAC value and it ran great for about 2 weeks. Then a loud humming noise started. It is coming from the air filter box. It doesn't do it when I'm driving just while I'm idle while in gear. But it will do make the noise sometimes while in park. Sometimes it stalls out too.
ammodoug is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-31-2011, 12:59 PM   #2
PEAR0119
Ottawa, Ontario
2006 Explorer XLT 4.0 4x4
Vehicle Specs
Quoted: 2 Post(s)
Did you unplug the battery for 20 minutes or so after changing the IAC? If not then I would try that, which will force the PCM to relearn the fuel trims. The PCM has adapted the fuel trims to the bad PCM to keep the car running and now with the new one the air/fuel tables are going to be off. Disconnecting the battery will reset this and the PCM will relearn the fuel trims.
EDIT: Here is the procedure that was in my 06 owners manual which should be similar to yours.:
Because your vehicle’s engine is electronically controlled by a computer,
some control conditions are maintained by power from the battery. When
the battery is disconnected or a new battery is installed, the engine must
relearn its idle and fuel trim strategy for optimum driveability and
performance. To begin this process:
1. With the vehicle at a complete stop, set the parking brake.
2. Put the gearshift lever in P (Park), turn off all accessories and start
the engine.
3. Run the engine until it reaches normal operating temperature.
4. Allow the engine to idle for at least one minute.
5. Turn the A/C on and allow the engine to idle for at least one minute.
6. Drive the vehicle to complete the relearning process.
• The vehicle may need to be driven to relearn the idle and fuel trim
strategy.
• If you do not allow the engine to relearn its idle trim, the idle
quality of your vehicle may be adversely affected until the idle
trim is eventually relearned.
__________________
2006 Explorer XLT V6 4x4 --> mine
2005 Mustang GT --> mine
2003 Explorer limited 100th anniversary 4.6L 4x4 --> Dads
2009 Expedition Limited 5.4L 3V 4x4 --> Dads
PEAR0119 is offline   Reply With Quote
Old 03-02-2012, 07:57 PM   #3
neo1973
Vancouver, WA
1999 EX
Vehicle Specs
Quoted: 0 Post(s)
This
could be the best information on the forum.
We have a brand new IAC and it still wasn't working. Being smarter than the Chilton's manual, and not wanting to have to reprogram all the radio stations, I did NOT disconnect the battery, though the manual told me to.
Seems secondary, or like a "safety" precaution, but if that explanation were in the book, people wouldn't skip that step.
TYVM
neo1973 is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Humming Noise Front End- Any Ideas? 98 EddieB Stock 1995 - 2001 Explorers 21 04-06-2015 01:16 PM
Humming noise changes with rpm mechjames Stock 1991 - 1994 Explorers 4 01-01-2011 02:10 PM
Loud humming noise increases with speed? wisneski7 Stock 1995 - 2001 Explorers 13 01-21-2009 07:59 AM
loud cycling noise coming from rt frt wheel (3/28/05) garynitad Elite Explorer 911! 10 03-31-2005 05:07 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
